opengl in mohaa
  • 107 views sinds 30-01-2008
volgend probleem
GLW_StartOpenGL() - could not load OpenGL subsystem
full details :
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
C:\games\MOHAA\main\Pak5.pk3 (259 files)
C:\games\MOHAA\main\Pak4.pk3 (593 files)
C:\games\MOHAA\main\Pak3.pk3 (669 files)
C:\games\MOHAA\main\Pak2.pk3 (4722 files)
C:\games\MOHAA\main\Pak1.pk3 (772 files)
C:\games\MOHAA\main\Pak0.pk3 (11175 files)
C:\games\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 11
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...39 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: failed
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
Iemand een solution voor dit probleem? wolfenstein 3D ea werken wel. Ik heb al veel info gevonden en al vee lzaken geprobeerd oa hier op tweakers maar ze werken niet.
ik werk op een dell latitude c600 met ati mobile rage 128 met 16mb video ram. bij autoconfigure zegt moh dat ik een opengl based videokaart heb maar toch wil ze niet werken. help !!
Crosspost! [topic=388144/1/25]
  • steveman
  • Registratie: Mei 2001
steveman
Comfortabel ten onder
Dat gezever heb ik ook gehad met m'n voodoo2 met kweek3 (tijdje terug)
  • 0siris
  • Laatst online: 07-02 23:33
Op dinsdag 22 januari 2002 12:04 schreef steveman het volgende:
Ramms+ein! Ramms+ein gemist in HMH?? Boek dan FeuerEngel info @: http://www.Feuerengel.de | Codename Ealge regeert!!! | rm God error: " 'God' does not excist"
excist --> exist
Ealge --> Eagle
:D
ach...in een volgend leven lach je er om!
