opengl probleem in medal of honor
  • 106 views sinds 30-01-2008
volgend probleem
GLW_StartOpenGL() - could not load OpenGL subsystem
full details :
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
C:\games\MOHAA\main\Pak5.pk3 (259 files)
C:\games\MOHAA\main\Pak4.pk3 (593 files)
C:\games\MOHAA\main\Pak3.pk3 (669 files)
C:\games\MOHAA\main\Pak2.pk3 (4722 files)
C:\games\MOHAA\main\Pak1.pk3 (772 files)
C:\games\MOHAA\main\Pak0.pk3 (11175 files)
C:\games\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 11
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...39 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: failed
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
Iemand een solution voor dit probleem? wolfenstein 3D ea werken wel. Ik heb al veel info gevonden en al vee lzaken geprobeerd oa hier op tweakers maar ze werken niet.
ik werk op een dell latitude c600 met ati mobile rage 128 met 16mb video ram. bij autoconfigure zegt moh dat ik een opengl based videokaart heb maar toch wil ze niet werken. help !!
  • maddog_rvo
  • Laatst online: 08-04 14:13
hee dat heb ik ook, alleen dan met een gf3 en winxp
  • DR
DR
-->SP
Waarschijnlijk heb je geen drivers goede drivers van die kaart, of ondersteunen ze gewoon geen openGL, heb je al op de site gekeken van Ati? en /of op die van Moh:aa voor een eventuele patch/update?
  • Skeleton353
  • Laatst online: 11-01-2020
Skeleton353
Ik herken mezelf niet meer ...
Misschien werkt het 'WEL' op de legale versie ? |:(
Asus Cusl2-c - Intel P3-800 Mhz - 512 Mb Ram - Asus V7700 (Ge-force 2 GTS) - Plextor 40/12/40A CD-writer - SB-audigy - 2x40 Gb HD - Cambridge FPS-1000 Speakers - IIYAMA AS4611UT LCD Monitor - MS Optical Wheel Mouse - Windows XP Professional (Engels)
  • toastingnow
  • Laatst online: 07-10 16:19
Heb gewoon de 23.11 Nvidia drivers opnieuw geinstalleerd en 't werkt!
Maarruh, hoe kom jij nu aan MOHAA?
Ik heb 'm opgestuurd gekregen van een familielid, dus de mijn is iig legaal ;)
Asus P5K Pro, 2 Gb DDR2, Samsung 500 GB HD, XFX Alpha DOG 670Mhz, E8400
  • toastingnow
hmm..denk niet dat de nvidia drivers werken met je videokaart |:(
  • GeeBee
  • Laatst online: 13-10 19:18
GeeBee
Oddball
2e monitor uitschakelen?
Gewoon even de goede OpenGL drivers downloaden.
Op zondag 10 februari 2002 18:53 schreef Celtic het volgende:
Welke zijn de goeie :+ Kan je dan ff linkie geven, heb daar ook gezeik mee ;(
