Al uw oplossingen voor sb 128 onder winxp
Ik had toen ik win xp installeerde een heel eind gepiep en gekraak in mijn geluid. ik heb een AOpen AK72 moederboard met via chipset, en ik hoorde dat meer mensen daar problemen mee hebben. Toen heb ik effe creative gemailt en die mailden een lijst door met mogelijke oplossingen:
There are numerous causes of and possible solutions to problems with bus noise with PCI soundcards. This can sound like scratching/hissing/crackling/popping and may sometimes get worse when eg. moving the mouse. Here are some possible solutions.
* Update the PC's BIOS.
* Enable "Enhanced Chip Performance" in the BIOS. This may not be present on all machines.
* In Device Manager, disable DMA for IDE Hard Disks and CD/DVD Drives - this is not relevant if they are SCSI drives. Unfortunately, this may also result in a performance decrease. To avoid this, the latest IDE Bus Master drivers should be installed for the system and DMA enabled. Here are the links to driver download pages of the majopr chipset manufacturers:
VIA/ETEQ: http://www.via.com.tw/drivers/index_new2.htm
AMD: http://http://www.amd.com/products/cpg/bin/
Intel: http://support.intel.com/support/chipsets/driver.htm
SIS: http://www.sis.com.tw/support/download/driver.htm
Please note that after installing any IDE driver other than that included with the operating system, DMA should no longer be enabled/disabled through Device Manager. Instead it will be possible either during the driver installation or with a utility provided with the IDE drivers.
* In the BIOS, ensure that DMA mode for IDE devices is not enabled but instead set to AUTO.
* Try moving the soundcard to different PCI slots - the farther away from components like the Hard-Drive and Processor, the better.
* In the BIOS, try changing the latency value of the PCI-Bridge or PCI Latency to 0 - the default is 32. This helps in some cases and shouldn't have any negative impact on other hardware. For more detailed information on this and ways to change this value if not present in your BIOS, please check here: http://www.deinmeister.de/mvp3_zlt_e.htm
* If there is a "Memory Hole" setting in the BIOS, try changing this from "disabled" to "15M-16M".
* If there is a PCI Graphic Card installed, ensure that both this and the soundcard are not sharing the same IRQ and try lowering the Hardware Acceleration of the Graphic Card. Also contact the Graphic Card manufacturer to see if there is a way to disable "PCI-retries" or similar. If the system has an AGP slot, it may be necessary to use an AGP graphic card instead of PCI.
Puntje 7 hielp bij mij.
  • MisterDon
  • Laatst online: 14-05-2024
MisterDon
Prefers Audiotrak
Mooi lijstje. Puntje 2 deed de truc bij mij. Ik had last van een hol geluid. Dat bleek daarmee op te lossen.
  • Han
Han
*zucht* :? [topic=382033/1/999]
  • MisterDon
MisterDon
Prefers Audiotrak
Wat is dat nou voor gezucht? Ik vind het wel zo sociaal om zo'n emailtje ff te posten!
Da's toch handig. Bovendien zullen veel mensen die deze problemen tegenkomen in een korte tijd ze kunnen verhelpen!
Op maandag 21 januari 2002 16:34 schreef MisterDon het volgende:
[frustie mode]
Dat is normaal op GoT. als er ooit 1 topic over tzelfde onderwerp is geweest, ook al is er geen oplossing gegeven destijds, wordt er al gezucht en SEARCH geroepen |:( . Dat weet je toch :+
[/frustie mode]
  • Han
Han
Eumm.. mijn reactie betrof het volgende; de topicstarter opende twee dezelfde topic's over één probleem. Oplossingen of suggesties zal ik nimmer bestrijden, alleen maar toejuichen. ;)
Sorry dat ik hier een nieuwe topic over starte, dit is de derde keer dat ik wat post, dus alle regels weet ik nog niet, maar het leek mij gewoon handig om dit onder een apartte topic te zetten, om het makelijker beschik baar te maken.
