Uninstall van freesco packages
Hoe doe ik dit?
  • Fanman
  • Registratie: September 1999
  • Laatst online: 13:35
Move [HA]>[NWO]
How do I remove a package?
Typing the command:
removepkg
will display a list of packages which can be automatically removed. To remove a specific package from this list, say ftp, use this command:
removepkg ftp
You will be asked if you are sure and if you answer Y, the package will be removed. You may need to reboot your router after this to ensure correct operation.
If your package does not appear on this list, the package author has not provided you a way to automatically remove the package and this needs to be done so manually.
  • Oscar the Grouch
  • Laatst online: 11:57
Oscar the Grouch
Ex-Admin
Question everything
Move HA->NWOS
 I don't know half of you half as well as I should like; and I like less than half of you half as well as you deserve
