SuDEfirewall2 laat poort 80 niet door
  • ThaDude
  • Laatst online: 20:33
ThaDude
Hang Loose
Heb hem zo ingesteld, shared internet goed. Alleen apache webserver komt er niet doorheen. Iemand van jullie die het wel weet???
# 1.)
# Should the Firewall be started?
# This setting is done in /etc/rc.config (START_FW2="yes")
# 2.)
# Which is the interface that points to the internet/untrusted networks?
# Enter all the network devices here which are untrusted.
# Choice: any number of devices, seperated by a space
# e.g. "eth0", "ippp0 ippp1 eth0:1"
FW_DEV_EXT="eth1"
# 3.)
# Which is the interface that points to the internal network?
# Enter all the network devices here which are trusted.
# If you are not connected to a trusted network (e.g. you have just a
# dialup) leave this empty.
# Choice: leave empty or any number of devices, seperated by a space
# e.g. "tr0", "eth0 eth1 eth1:1" or ""
FW_DEV_INT="eth0"
# 4.)
# Which is the interface that points to the dmz or dialup network?
# Enter all the network devices here which point to the dmz/dialups.
# A "dmz" is a special, seperated network, which is only connected to the
# firewall, and should be reachable from the internet to provide services,
# e.g. WWW, Mail, etc. and hence are at risk from attacks.
# See /usr/share/doc/packages/SuSEfirewall2/EXAMPLES for an example.
# Special note: You have to configure FW_FORWARD to define the services
# which should be available to the internet and set FW_ROUTE to yes.
FW_DEV_DMZ=""
# 5.)
# Should routing between the internet, dmz and internal network be activated?
# REQUIRES: FW_DEV_INT or FW_DEV_DMZ
# You need only set this to yes, if you either want to masquerade internal
# machines or allow access to the dmz (or internal machines, but this is not
# a good idea). This option supersedes IP_FORWARD from /etc/rc.config!
# Setting this option one alone doesn't do anything. Either activate
# massquerading with FW_MASQUERADE below if you want to masquerade your
# internal network to the internet, or configure FW_FORWARD to define
# what is allowed to be forwarded!
# Choice: "yes" or "no", defaults to "no"
FW_ROUTE="yes"
# 6.)
# Do you want to masquerade internal networks to the outside?
# REQUIRES: FW_DEV_INT or FW_DEV_DMZ, FW_ROUTE
# "Masquerading" means that all your internal machines which use services on
# the internet seem to come from your firewall.
# Please note that it is more secure to communicate via proxies to the
# internet than masquerading. This option is required for FW_MASQ_NETS and
# FW_FORWARD_MASQ.
FW_MASQUERADE="yes"
# You must also define on which interface(s) to masquerade on. This is
# normally your external device(s) to the internet.
# Most users can leave the default below.
# e.g. "ippp0" or "$FW_DEV_EXT"
FW_MASQ_DEV="$FW_DEV_EXT"
# Which internal computers/networks are allowed to access the internet
# directly (not via proxys on the firewall)?
# Only these networks will be allowed access and will be masqueraded!
# Choice: leave empty or any number of hosts/networks seperated by a space.
# Every host/network may get a list of allowed services, otherwise everything
# is allowed. A target network, protocol and service is appended by a comma to
# the host/network. e.g. "10.0.0.0/8" allows the whole 10.0.0.0 network with
# unrestricted access. "10.0.1.0/24,0/0,tcp,80 10.0.1.0/24,0/0tcp,21" allows
# the 10.0.1.0 network to use www/ftp to the internet.
# "10.0.1.0/24,tcp,1024:65535 10.0.2.0/24" is OK too.
# Set this variable to "0/0" to allow unrestricted access to the internet.
FW_MASQ_NETS="192.168.0.0/24"
# 7.)
# Do you want to protect the firewall from the internal network?
# If you set this to "yes", internal machines may only access services on
# the machine you explicitly allow. They will be also affected from the
# FW_AUTOPROTECT_SERVICES option.
# If you set this to "no", any user can connect (and attack) any service on
# the firewall.
# Choice: "yes" or "no", defaults to "yes"
# "yes" is a good choice # AANGEPAST!!
FW_PROTECT_FROM_INTERNAL="yes"
# 8.)
# Do you want to autoprotect all running network services on the firewall?
# If set to "yes", all network access to services TCP and UDP on this machine
# will be prevented (except to those which you explicitly allow, see below:
# FW_SERVICES_{EXT,DMZ,INT}_{TCP,UDP})
FW_AUTOPROTECT_SERVICES="yes"
# 9.)
# Which services ON THE FIREWALL should be accessible from either the internet
# (or other untrusted networks), the dmz or internal (trusted networks)?
# (see no.13 & 14 if you want to route traffic through the firewall) XXX
# Enter all ports or known portnames below, seperated by a space.
# TCP services (e.g. SMTP, WWW) must be set in FW_SERVICES_*_TCP, and
# UDP services (e.g. syslog) must be set in FW_SERVICES_*_UDP.
# e.g. if a webserver on the firewall should be accessible from the internet:
# FW_SERVICES_EXT_TCP="www"
# e.g. if the firewall should receive syslog messages from the dmz:
# FW_SERVICES_DMZ_UDP="syslog"
# For IP protocols (like GRE for PPTP, or OSPF for routing) you need to set
# FW_SERVICES_*_IP with the protocol name or number (see /etc/protocols)
# Choice: leave empty or any number of ports, known portnames (from
# /etc/services) and port ranges seperated by a space. Port ranges are
# written like this: allow port 1 to 10 -> "1:10"
# e.g. "", "smtp", "123 514", "3200:3299", "ftp 22 telnet 512:514"
# For FW_SERVICES_*_IP enter the protocol name (like "igmp") or number ("2")
# Common: smtp domain
FW_SERVICES_EXT_TCP="22 80 2064 3064 10000"
# Common: domain
FW_SERVICES_EXT_UDP="" # Common: domain
# For VPN/Routing which END at the firewall!!
FW_SERVICES_EXT_IP=""
FW_SERVICES_DMZ_TCP="22 80 2064 3064 10000"
# Common: domain
FW_SERVICES_DMZ_UDP=""
FW_SERVICES_DMZ_IP=""
# Common: ssh smtp domain
FW_SERVICES_INT_TCP="22 80 2064 3064 10000"
# Common: domain syslog
FW_SERVICES_INT_UDP="syslog"
FW_SERVICES_INT_IP=""
# 10.)
# Which services should be accessible from trusted hosts/nets?
# Define trusted hosts/networks (doesnt matter if they are internal or
# external) and the TCP and/or UDP services they are allowed to use.
# Choice: leave FW_TRUSTED_NETS empty or any number of computers and/or
# networks, seperated by a space. e.g. "172.20.1.1 172.20.0.0/16"
# Optional, enter a protocol after a comman, e.g. "1.1.1.1,icmp"
# Optional, enter a port after a protocol, e.g. "2.2.2.2,tcp,22"
FW_TRUSTED_NETS="192.168.0.0/8"
# 11.)
# How is access allowed to high (unpriviliged [above 1023]) ports?
# You may either allow everyone from anyport access to your highports ("yes"),
# disallow anyone ("no"), anyone who comes from a defined port (portnumber or
# known portname) [note that this is easy to circumvent!], or just your
# defined nameservers ("DNS").
# Note that if you want to use normal (active) ftp, you have to set the TCP
# option to ftp-data. If you use passive ftp, you don't need that.
# Note that you can't use rpc requests (e.g. rpcinfo, showmount) as root
# from a firewall using this script (well, you can if you include range
# 600:1023 in FW_SERVICES_EXT_UDP ...).
# Choice: "yes", "no", "DNS", portnumber or known portname, defaults to "no"
# if not set
# Common: "ftp-data", better is "yes" to be sure that everything else works :-(
FW_ALLOW_INCOMING_HIGHPORTS_TCP="yes"
# Common: "DNS" or "domain ntp", better is "yes" to be sure ...
FW_ALLOW_INCOMING_HIGHPORTS_UDP="yes"
# 12.)
# Are you running some of the services below?
# They need special attention - otherwise they wonŽt work!
# Set services you are running to "yes", all others to "no", defaults to "no"
FW_SERVICE_AUTODETECT="yes" # Autodetect the services below when starting
# If you are running bind/named set to yes. Remember that you have to open
# port 53 (or "domain") as udp/tcp to allow incoming queries.
# Also FW_ALLOW_INCOMING_HIGHPORTS_UDP needs to be "yes"
FW_SERVICE_DNS="no" #effies aangepast was yes!!!!
# if you use dhclient to get an ip address you have to set this to "yes" ! AANGEPAST!!! was no
FW_SERVICE_DHCLIENT="yes"
# set to "yes" if this server is a DHCP server
FW_SERVICE_DHCPD="no"
# set to "yes" if this server is running squid. You still have to open the
# tcp port 3128 to allow remote access to the squid proxy service.
FW_SERVICE_SQUID="no"
# set to "yes" if this server is running a samba server. You still have to open
# the tcp port 139 to allow remote access to SAMBA.
FW_SERVICE_SAMBA="no"
# 13.)
# Which services accessed from the internet should be allowed to the
# dmz (or internal network - if it is not masqueraded)?
# REQUIRES: FW_ROUTE
# With this option you may allow access to e.g. your mailserver. The
# machines must have valid, non-private, IP addresses which were assigned to
# you by your ISP. This opens a direct link to your network, so only use
# this option for access to your dmz!!!!
# Choice: leave empty (good choice!) or use the following explained syntax
# of forwarding rules, seperated each by a space.
# A forwarding rule consists of 1) source IP/net and 2) destination IP
# seperated by a comma. e.g. "1.1.1.1,2.2.2.2 3.3.3.3/16,4.4.4.4/24"
# Optional is a protocol, seperated by a comma, e.g. "5.5.5.5,6.6.6.6,igmp"
# Optional is a port after the protocol with a comma, e.g. "0/0,0/0,udp,514"
FW_FORWARD="" # Beware to use this!
# 14.)
# Which services accessed from the internet should be allowed to masqueraded
# servers (on the internal network or dmz)?
# machines must be in a masqueraded segment and may not have public IP addesses!
# Hint: if FW_DEV_MASQ is set to the external interface you have to set
# FW_FORWARD from internal to DMZ for the service as well to allow access
# from internal!
# Please note that this should *not* be used for security reasons! You are
# opening a hole to your precious internal network. If e.g. the webserver there
# is compromised - your full internal network is compromised!!
# of forward masquerade rules, seperated each by a space.
# A forward masquerade rule consists of 1) source IP/net, 2) destination IP
# (dmz/intern), 3) a protocol (tcp/udp only!) and 4) destination port,
# seperated by a comma (","), e.g. "4.0.0.0/8,1.1.1.1,tcp,80"
# Optional is a port after the destination port, to redirect the request to
# a different destination port on the destination IP, e.g.
# "4.0.0.0/8,1.1.1.1,tcp,80,81"
FW_FORWARD_MASQ="" # Beware to use this!
# 15.)
# Which accesses to services should be redirected to a localport on the
# firewall machine?
# This can be used to force all internal users to surf via your squid proxy,
# or transparently redirect incoming webtraffic to a secure webserver.
# Choice: leave empty or use the following explained syntax of redirecting
# rules, seperated by a space.
# A redirecting rule consists of 1) source IP/net, 2) destination IP/net,
# 3) protocol (tcp or udp) 3) original destination port and 4) local port to
# redirect the traffic to, seperated by a colon. e.g.:
# "10.0.0.0/8,0/0,tcp,80,3128 0/0,172.20.1.1,tcp,80,8080"
FW_REDIRECT=""
# 16.)
# Which logging level should be enforced?
# You can define to log packets which were accepted or denied.
# You can also the set log level, the critical stuff or everything.
# Note that logging *_ALL is only for debugging purpose ...
# Choice: "yes" or "no", FW_LOG_*_CRIT defaults to "yes",
# FW_LOG_*_ALL defaults to "no"
FW_LOG_DROP_CRIT="yes"
FW_LOG_DROP_ALL="no"
FW_LOG_ACCEPT_CRIT="yes"
FW_LOG_ACCEPT_ALL="no"
# only change/activate this if you know what you are doing!
FW_LOG="--log-level warning --log-tcp-options --log-ip-option --log-prefix SuSE-FW"
# 17.)
# Do you want to enable additional kernel TCP/IP security features?
# If set to yes, some obscure kernel options are set.
# (icmp_ignore_bogus_error_responses, icmp_echoreply_rate,
# icmp_destunreach_rate, icmp_paramprob_rate, icmp_timeexeed_rate,
# ip_local_port_range, log_martians, mc_forwarding, mc_forwarding,
# rp_filter, routing flush)
# Tip: Set this to "no" until you have verified that you have got a
# configuration which works for you. Then set this to "yes" and keep it
# if everything still works. (It should!) ;-)
FW_KERNEL_SECURITY="yes"
# 18.)
# Keep the routing set on, if the firewall rules are unloaded?
# If you are using diald, or automatic dialing via ISDN, if packets need
# to be sent to the internet, you need to turn this on. The script will then
# not turn off routing and masquerading when stopped.
# You *might* also need this if you have got a DMZ.
# Please note that this is *insecure*! If you unload the rules, but are still
# connected, you might your internal network open to attacks!
# The better solution is to remove "/sbin/SuSEfirewall2 stop" or
# "/sbin/init.d/firewall stop" from the ip-down script!
# Choices "yes" or "no", defaults to "no"
FW_STOP_KEEP_ROUTING_STATE="yes"
# 19.)
# Allow (or don't) ICMP echo pings on either the firewall or the dmz from
# the internet? The internet option is for allowing the DMZ and the internal
# network to ping the internet.
# REQUIRES: FW_ROUTE for FW_ALLOW_PING_DMZ and FW_ALLOW_PING_INTERNET
# Choice: "yes" or "no", defaults to "no" if not set
FW_ALLOW_PING_FW="yes"
FW_ALLOW_PING_DMZ="yes"
#hier was wat mee!!!
FW_ALLOW_PING_EXT="yes"
# END of rc.firewall
# EXPERT OPTIONS - all others please don't change these! #
# 20.)
# Allow (or don't) ICMP time-to-live-exceeded to be send from your firewall.
# This is used for traceroutes to your firewall (or traceroute like tools).
# Please note that the unix traceroute only works if you say "yes" to
# FW_ALLOW_INCOMING_HIGHPORTS_UDP, and windows traceroutes only if you say
# additionally "yes" to FW_ALLOW_PING_FW
FW_ALLOW_FW_TRACEROUTE="yes"
# 21.)
# Allow ICMP sourcequench from your ISP?
# If set to yes, the firewall will notice when connection is choking, however
# this opens yourself to a denial of service attack. Choose your poison.
FW_ALLOW_FW_SOURCEQUENCH="yes"
# 22.)
# Allow/Ignore IP Broadcasts?
# If set to yes, the firewall will not filter broadcasts by default.
# This is needed e.g. for Netbios/Samba, RIP, OSPF where the broadcast
# option is used.
# If you do not want to allow them however ignore the annoying log entries,
# set FW_IGNORE_FW_BROADCAST to yes.
FW_ALLOW_FW_BROADCAST="no"
FW_IGNORE_FW_BROADCAST="yes"
# 23.)
# Allow same class routing per default?
# Do you want to allow routing between interfaces of the same class
# (e.g. between all internet interfaces, or all internal network interfaces)
# be default (so without the need setting up FW_FORWARD definitions)?
FW_ALLOW_CLASS_ROUTING="no"
# 25.)
# Do you want to load customary rules from a file?
# This is really an expert option. NO HELP WILL BE GIVEN FOR THIS!
# READ THE EXAMPLE CUSTOMARY FILE AT /etc/rc.config.d/firewall2-custom.rc.config
#FW_CUSTOMRULES="/etc/rc.config.d/firewall2-custom.rc.config"
We're machines just like everything else in nature. (gasloos sinds 01-10-2020, WP: SW75YAA/ERSD-VM2D, DJG WPS 300, 18 hp CPC, 11,1 kWp
