weer online spelen op GAMESPY!!!!
  • 58 views sinds 30-01-2008
i believe i found a way to play MOHA online without reinstalling gamespy (maybe someone else already did too..)
anyways..
there is a "support.cfg" file in GameSpy Arcade\Profiles folder and in that file you can see every command or path gamespy has to look for a cerain game...
here is how the MOHA part looks after a fresh install of gamespy before running it the first time
[mohaa]
rsrcvers=7
commonname=Medal of Honor Allied Assault
findregkey=HKEY_LOCAL_MAC
HINE\Software\Microsoft\W
indows\CurrentVersion\App
Paths\MOHAA.exe\@
findexename=MOHAA.exe
group=Games
productid=854
rver=a8a8109f886be6667eb0
978f5c4dd998
here is how the same part looks after running gamespy and closing it
[mohaa]
rsrcvers=8
findregkey=- HKEY_LOCAL_MACHINE\Softwa
re\Microsoft\Windows\Curr
entVersion\App Paths\MOHAA.exe\@
group=Games
productid=854
rver=7654a35653afe8f65652
73e66af83177
Do you notice a "-" sign after "findregkey="?
well ..that what gamespy adds (at the first connect) to that file so the Game wont be recognized after first run...
simply removing negative sign will make ur Medal Of Honor MUTLIPLAYER work online again with GameSpy...or you can set "support.cfg" to Read-only mode so you wont have to alter the file each time..
Works for Me...
Thought that might help for some of ya.....
also that might work for any game in GameSpy
Is engels komt van isonews.com vandaan.
heb het nog niet geprobeerd zal wel werken denk ik.
verbetering: het werkt wel !! zie print screen hier beneden op 16-1-2002 om 21:08
Afbeeldingslocatie: http://www.minimax.f2s.com/mohaa.GIF
  • M@NIC
  • Laatst online: 23-09 09:24
Kon toch ook wel in dat andere draadje :?
  • IceStorm
  • Laatst online: 14-10 22:20
IceStorm
This place is GoT-like!!!
Op woensdag 16 januari 2002 21:21 schreef Manic het volgende:
Ja.
