2. Error Message "Couldn't Load Default.cfg":
If you try to run Return to Castle Wolfenstein and receive the error message,
"Couldn't Load default.cfg", the game is basically telling you that it cannot
find the \main directory that is part of Return To Castle Wolfenstein. This
error commonly occurs when the game is installed with no directory specified.
For example, if you choose to install it to a hard drive or partition other than
the C: drive (that is, D:,E:, etc.), but fail to specify a folder, the game will
install everything to the root of the hard drive and the game will not launch.
If you want to install the game to a hard drive other than the default setting
(C:), please make sure you specify a folder when choosing the other drive
(i.e.: D:\RTCW).
RETURN TO CASTLE WOLFENSTEIN MINIMUM SYSTEM REQUIREMENTS:
3-D Hardware Accelerator (with 16 MB VRAM) with full OpenGL® support*
Pentium II® 400Mhz processor or Athlon® processor
English version of Windows® 95 OSR2/98/ME/NT4.0(SP6)/2000(SP2)/XP Operating System
128 MB RAM
16-bit high color video mode
800 MB of uncompressed hard disk space for game files, plus 300 MB for the Windows® swap file
A 100% Windows® 95 OSR2/98/ME/NT4.0(SP6)/2000(SP2)/XP compatible computer system (including compatible 32-bit drivers for CD-ROM drive, video card, sound card and input devices)
DirectX® 8.0a (included)
100% DirectX® 3.0 or higher compatible sound card and drivers
100% Microsoft®-compatible mouse/keyboard and drivers
Quad-speed CD-ROM drive (600K/sec. sustained transfer rate)
128MB ram dus
