[RTCW] Patch 1.1 nu te downloaden!
  • 136 views sinds 30-01-2008
http://www.planetmirror.com/pub/bluesnews/rtcw/patches/Wolf_1_1.exe
ftp://fragland.net/mirror/ftp.gamingfiles.com/Return%20to%20Castle%20Wolfenstein/Official%20Releases/Patches/wolf_1_1.exe
This patch will upgrade your retail Return to Castle Wolfenstein game to version 1.1. This update for Return to Castle Wolfenstein is primarily to resolve multiplayer server specific issues that have come up.
- Zombie Clients issue resolved
- Lieutenant grenade issue solved
- Issue with loading single-player maps in multiplayer fixed
- Various server stability issues fixed
- Added Voice-Chat abuse fix
  • BasieP
  • Laatst online: 19-10-2025
wat doet ie patch?
This message was sent on 100% recyclable electrons.
  • klomp
  • Laatst online: 22-11-2025
klomp
Zooi...
Op maandag 14 januari 2002 23:00 schreef Flippo-dealer het volgende:
langzaam servertje
  • Fietsbel
Fietsbel
¯\_(ツ)_/¯
bedankt voor de link :)
39
  • NightCruiser
Op maandag 14 januari 2002 23:01 schreef basiep het volgende:
wat doet ie patch?
|:( moeilijk he lezen
  • klomp
klomp
Zooi...
Op maandag 14 januari 2002 23:10 schreef Revision het volgende:
uhm ff voor die opmerking, dat stond er nog niet bij toen hij poste, dus in jouw geval zeg ik: moeilijk he lezen...
er staat toch echt duidelijk onder z'n post: gewijzigd op...
  • Tcq
  • Laatst online: 15-09 15:01
Tcq
Voor de luie mensen:
ISSUES ADDRESSED IN 1.1
1. Zombie Clients issue resolved:
The reported issue with zombie clients filling spaces on servers left running for more than 24hrs has been resolved.
2. Lieutenant grenade spamming solved:
The bug allowing Lieutenants to throw grenades while in binoculars has been resolved.
3. Issue with loading single-player maps fixed:
There were many problems caused by launching single-player maps in multiplayer since they were not intended for multiplayer use. It is no longer possible to launch single-player maps from within a Multiplayer game.
4. Various server stability issues implemented:
Several bugs that caused servers to crash when left on for more than 24hrs were fixed. These fixes should greatly increase the potential number of servers available on a daily basis.
5. Link to easily find future updates:
Once you install the update, a new link will be added to your start menu. You will be able to use this to check in with www.CastleWolfenstein.com to view any additional updates, maps, and other official downloads.
6. Added Voice-Chat abuse fix:
The max number of voice chats you can issue within 30 seconds is now defaulted to 4. Every time you issue a voice-chat, it looks back 30 seconds to make sure you haven't already issued the maximum number in that time period. In other words, if you repeatedly hit "VRA", you will get 4 "I need ammo!" calls in a row, and from then on, it will only issue one every 8 seconds with the default setting.
This will allow for normal usage of voice-chats, but NOT allow someone to just continually holler requests a dozen times in a row (we all hate that).
If a server would like to change the setting, the new cvar is "g_voiceChatsAllowed." The number given is how many voice-chats within 30 seconds. So the default is 4. A higher number will allow for more chats, while a lower number will allow even less.
Row row row your boat, quickly down the stream, see a croc and shit yourself, don't forget to scream!
  • NightCruiser
Op maandag 14 januari 2002 23:12 schreef kl0mp het volgende:
staat toch duidelijk onder z'n post gewijzigd op...
Ja weet ik veel wat er gewijzigt is
  • klomp
klomp
Zooi...
mwah... :)
edit: ik zie net dat jij een minuut daarna gepost hebt
en dat je dus vrijwel zeker nog in het "typ hier je bericht" scherm zat en dus niet kon weten dat het geédit was...
sorry dus, ik zal me wel weer stil houden |:( :)
  • NightCruiser
Op maandag 14 januari 2002 23:14 schreef kl0mp het volgende:
mwah... :)
en dat je dus vrijwel zeker nog in het "typ hier je bericht" scherm zat en dus niet kon weten dat het geeidt was...
  • klomp
klomp
Zooi...
Op maandag 14 januari 2002 23:17 schreef Revision het volgende:
haha hhmmzz, hoe moet ik dat opvatten :) >:)
Medic!!!!!!!! :P
  • klomp
klomp
Zooi...
Op maandag 14 januari 2002 23:30 schreef Ender het volgende:
Medic!!!!!!!! :P
uh ? die snap ik niet??
  • Saekerhett
  • Laatst online: 31-10 20:42
Medic!!!!!!!! :P
I'm a medic :D
Kijk daar heb ik wat aan. En bedankt voor de link!
  • Dracul
  • Laatst online: 11-02 19:55
Dracul
Ooh yeah!
  • RedTop
  • Laatst online: 28-01-2024
Beter!!!
ik had op ClanBase nog gelezen dat het volgens een bepaalde site een foutje was van de PR afdeling... gelukkig was dat nieuws dus BS.
Ik heb hem al geïnstalleerd :) Bedankt!
  • scorpionv
  • Laatst online: 30-10 22:30
scorpionv
This space for rent
Hah great. Ben ik eindelijk van dat atomme '\vid_restart' af ;)
Fun while it lasted: World Community Grid!
As usual installeert hij zich bij mij weer niet :(
Dat flikte die Mappack ook al.. Zijn er al losse verkrijgbaar? voordat ik zelf van alles ga zitten overschrijven en daarmee de boel om zeep help .
  • DrNo
  • Laatst online: 27-12-2024
DrNo
100Mbit zuigt ;)
Bij mij crasht ie tijdens het scherm waar je kan zien welke map je gaat spelen, maar mijn servers draaien wel prima :?
Wie heeft hier nog meer last van ?
IDE just wastes loads of the computer's time with a stream of "just a mo, I'm nearly there ..."
  • Sjah
  • Laatst online: 05:46
op t gevaar af mezelf belachelijk temaken: 't lijkt wel dat de ping beter is geworden......?
  • PWM
PWM
Heb ik nu risico, met mijn geleende key?
Dit is erg goed. Ik haat het als er iemand continue achter m'n reet aanloopt en roept "Medic, Medic, Medic, Medic, Medic, Medic, Medic, ...." terwijl m'n power bar leeg is.
  • CyberTijn
  • Laatst online: 31-10 12:58
Zijn alle servers al overgestapt naar versie 1.1 ? Is ook zo lastig als de helft nog de oude draait :(
  • scorpionv
scorpionv
This space for rent
Op dinsdag 15 januari 2002 09:49 schreef CyberTijn_ het volgende:
Gisteren niet iig, toen waren er nog volop van die voice-chat flooders.
  • Soef
  • Laatst online: 03-02-2023
Soef
-Soef^IO-
Ga ik downen asa i'm home!!!
Some things can not happen until they happen...
  • eGo2K
  • Laatst online: 01-05 20:12
eGo2K
De vraag .. (zie sig)
errr!.. Ligt het aan mij of heb ik geen response van de Master Server sinds die patch? :(
... die alle andere vragen overbodig maakt: BIERTJUH?!
Zorgt die patch ervoor dat het meer op cs gaat lijken? ;) Ik vind de mp gameplay namelijk niet zo denderend van rtcw. Maar ik moet zeggen dat ik ook nooit zal toegeven dat er beter spel is dan cs. hehe.
  • eGo2K
eGo2K
weird shit!!!!!
blijkt dus dat er helemaal geen servers zijn? :?
  • NightCruiser
hhmz dat niet te hopen, heb ik niks te doen vanmiddag ;)
naja zit nu toch op school :P
  • knightofn1
  • Laatst online: 22-07-2025
knightofn1
Don't say that word
nergens last van die master server die uit zou zijn
het loopt goed hier
Then, when you have found the shrubbery, you must cut down the mightiest tree in the forest... with... a herring!
  • NightCruiser
Werkt die patch wel :?
Ik heb em echt geinstalleerd, maar ik kan nog steeds voice chat flooden en die granaat bug doen.
Of moet de server ook updaten wil het werken?
Btw:
Dit heb ik niet getest op een pub ofzow
  • Crash
Binnen.... eindelijk >:)
  • eGo2K
eGo2K
Ik krijg HEEEEEEEEEEEEL langzaam die servers binnen.. 6 per minuut ofzo :( !
Gaat net als dikke shit door een trechter :r
  • Pjotrik
  • Registratie: Juli 1999
  • Laatst online: 29-10 22:02
Pjotrik
Wat ben je aan het doen?
Help, ik krijg geen response van de master server meer! :(
Gevonden!! Tip: verander eens van connection type, dan lijst opvragen en weer terugzetten. *D
  • Bert-Jan
  • Laatst online: 17-02-2024
sinds ik die p4tch heb ge1nstalleerd willen mijn scriptje niet meer werken :( ik had zo'n class-kies script en een respawn en partij kies script maar die doen het niet meer lekker :(
