[Debian] apt-get troubles (/usr/bin/regapi.so)
pc1:~# apt-get install
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these.
Sorry, but the following packages have unmet dependencies:
  wine: Depends: libwine (= 0.0.20011108-2) but 0.0.20011226-1 is installed
E: Unmet dependencies. Try using -f.
pc1:~# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  wine
1 packages upgraded, 0 newly installed, 0 to remove and 59  not upgraded.
103 packages not fully installed or removed.
Need to get 0B/607kB of archives. After unpacking 86.0kB will be used.
Do you want to continue? [Y/n]
Preconfiguring packages ...
(Reading database ... 134333 files and directories currently installed.)
Preparing to replace wine 0.0.20011108-2 (using .../wine_0.0.20011226-1_i386.deb) ...
Unpacking replacement wine ...
dpkg: error processing /var/cache/apt/archives/wine_0.0.20011226-1_i386.deb (--unpack):
 unable to stat `./usr/bin/regapi.so' (which I was about to install): Permission denied
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
pc1:~# apt-get install libwine
Sorry, libwine is already the newest version.
You might want to run `apt-get -f install' to correct these:
  wine: Depends: libwine (= 0.0.20011108-2) but 0.0.20011226-1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
pc1:~# apt-get install wine
wat nu?
  • Treenaks
  • Laatst online: 13:09
Permission denied als root? Raar.. draai je eoa extra-security-gepatchte kernel ofzo?
Purge wine eens, en kijk of het daarna (re-install) wel werkt?
ik heb een normale kernel [2.4.17] zelf gecompiled...van de source die ik gersync't heb van kernel.org...
pc1:~# apt-get remove wine
  wine-utils: Depends: wine but it is not going to be installed
pc1:~# dpkg -r wine
Removing wine ...
dpkg - warning: while removing wine, directory `/var/lib/wine/drivec/windows' not empty so not removed.
dpkg - warning: while removing wine, directory `/var/lib/wine/drivec' not empty so not removed.
dpkg - warning: while removing wine, directory `/var/lib/wine' not empty so not removed.
dpkg: error processing wine (--remove):
 cannot remove `/usr/bin/regapi.so': Permission denied
 wine
pc1:~# apt-get remove libwine
  wine: Depends: libwine (= 0.0.20011108-2) but it is not going to be installed
  wine-utils: Depends: libwine (= 0.0.20011226-1) but it is not going to be installed
pc1:~# dpkg -r libwine
dpkg: dependency problems prevent removal of libwine:
 wine depends on libwine (= 0.0.20011108-2).
dpkg: error processing libwine (--remove):
 dependency problems - not removing
 libwine
Wat geeft lsattr /usr/bin/regapi.so als output?
pc1:/usr/bin# ls | grep regapi.so
regapi.so
pc1:/usr/bin# ls -h | grep regapi.so
regapi.so
pc1:/usr/bin# ls -lh | grep regapi.so
ls: regapi.so: Permission denied
Op maandag 14 januari 2002 20:00 schreef sharpe het volgende:
pc1:/usr/bin# lsattr /usr/bin/regapi.so
lsattr: Permission denied while trying to stat /usr/bin/regapi.so
  • odysseus
odysseus
Debian GNU/Linux Sid
Hmm, die regapi.so staat op een gewoon filesystem? Lokaal, neem ik aan? Geeft hij wel iets met 'ls -hla regapi*'? Hoe is dat filesystem gemount?
* odysseus heeft nog nooit een bestand gezien dat niet eens zijn eigen permissies of attributes liet zien...bij mij is dat bestand gewoon rw voor root en r voor anderen, met eigenaar + groep root.
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
't is trouwens debian woody (testing)
Op maandag 14 januari 2002 20:10 schreef odysseus het volgende:
pc1:~# mount
/dev/hda2 on / type reiserfs (rw,notail,notail)
proc on /proc type proc (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
/dev/hdb1 on /pub type reiserfs (rw,notail)
/dev/hdb2 on /home type reiserfs (rw,notail)
pc1:~# ls -hla /usr/bin/regapi*
ls: /usr/bin/regapi.so: Permission denied
Op maandag 14 januari 2002 20:12 schreef compukid het volgende:
pc1:~# mount
2x notail?
pc1:~# cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>                <dump>  <pass>
/dev/hda2    /         reiserfs   defaults,notail 0  0
/dev/hdb1    /pub       reiserfs      defaults,notail 0  0
/dev/hdb2    /home       reiserfs     defaults,notail 0  0
/dev/hda1    none       swap    sw              0    0
proc        /proc        proc    defaults               0    0
/dev/fd0      /floppy      auto    defaults,user,noauto     0    0
/dev/cdrom  /cdrom      iso9660 defaults,ro,user,noauto    0     0
/dev/cdrecorder /cdrecorder     iso9660 defaults,ro,user,noauto    0     0
/dev/zip      /zip      vfat    defaults,ro,user,noauto    0     0
  • deadinspace
  • Laatst online: 16-08 16:08
deadinspace
The what goes where now?
En ls -ld /usr/bin en lsattr /usr/bin geven?
Op maandag 14 januari 2002 21:12 schreef deadinspace het volgende:
de output van 'lsattr /usr/bin':
(hier heb ik wat weg geknipt ivm lengte....)
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/pslatex
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/mysql_setpermission
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/pbmtozinc
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/g++-2.95
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/dpkg-name
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/psmerge
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/psselect
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/atktopbm
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/rletopnm
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/xscreensaver-demo
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/gnome-hint-properties-capplet
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/linuxdoc
lsattr: Inappropriate ioctl for device While reading flags on /usr/bin/xgnuboy
pc1:~# ls -ld /usr/bin
drwxr-xr-x    2 root     root     53399 Jan 14 19:47 /usr/bin
  • deadinspace
deadinspace
ehm.... HUH?
Op maandag 14 januari 2002 21:30 schreef compukid het volgende:
enz
Ik dacht dat lsattr de attributes op de dir zelf zou geven, niet op de inhoud, maar goed, dit laat iig zien dat er iets fout zit: 'Inappropiate ioctl for device' WTF? device?
Volgensmij zit er iets fout in je fs (reiser was nog niet helemaal stable iirc ook)... Heeft reiser een fatsoenlijk fsck? Zo ja, dan is het misschien een idee om naar single-user mode te gaan, je / read-only te remounten en te fscken...
  • active2
  • Laatst online: 17-07 21:56
active2
Google is your friend
'k weet niet of het helpt maar je kunt het allicht proberen:
ga naar /var/cache/apt/archives
rm *.deb
En vervolgens apt-get -f install
Het kan namelijk wezen dat de files in die dir een beetje naar de maan zijn en dat die ze toch probeert te installeren! En dat gaat niet.
Succes :)
Google, Het mirakel van de 21e eeuw!!!!
er waren idd problemen met reiserfs...maar of dat ook dit probleem heeft veroorzaakt...let's find out in a moment.
/me gebruikt weer ext2...
't probleem lag idd aan reiserfs....
  • deadinspace
deadinspace
Op zaterdag 19 januari 2002 22:30 schreef compukid het volgende:
ext3! :)
        ext2     ext3    reiserfs     xfs
quota   X      X       X
journal.         X     X       X
stable     X                     X
files > 2G             X       X
ext2 standaar linux fs
ext3 nieuwe versie met journaling
reiserfs journaling fs
xfs journaling fs van sgi
Ik weet bijna zeker dat deze table niet klopt...maar wat klopt er niet?
  • deadinspace
deadinspace
quota      X     X  X       X
journal.          X X       X
stable    X
files > 2G    X  X  X       X
Toelichting:
Quota is niet filesystem-specifiek; quota is iets wat net een laag daarboven ligt.
Stable... (dit afaik, iirc enzo)
In Linux is ext2 de enige die echt goed getest is.
Ext3 is een soort van toevoeging op ext2 en zou dus niet veel problemen moeten opleveren (ext3 is in mijn ervaring stabiel btw, maar ik draai ook geen hele zware mailservers ofzo)
Reiser was meen ik nog wat development.
XFS is bij mijn weten erg stabiel, maar de Linux drivers ervoor zijn nog development.
Alle vier de filesystems kunnen files ver boven de 2 gigabyte aan. De 2 gigabyte beperking waar jij het over hebt zitten in de kernel, de libc en de programma's.
Als je een 2.4 kernel een een redelijk recente libc gebruikt heb je gewoon support voor meer dan 2gig files (de programma's zelf moeten het wel nog aankunnen though).
