KT133a chipset @183Mhz
http://www.hardware.fr/html/articles/lire.php3?article=319
Ik kan hier uit opmaken dat ze een KT133a chipset op 183Mhz hebben draaien, maar ik kan 0,0 Frans..wie kan me een beetje uitleggen wat er gezegd wordt?
Whereas ourselves nŽarrivions not at exceed the MHz about the cards mother basée about a chipset testées jusquŽalors, ABIT ourselves did parvenir a KT7A- RAID directly exit any R&D thanksggiving according the put any builder could hold about greatly high FSB. Sceptical in a capital temps, we have been surprised about behold as the put dŽABIT were proper since her card allows dŽaller jusquŽau maximum authorised by the cŽest at put MHz! For thanksggiving making , we have utilisé her setup following : - Card mother ABIT KT7A- RAID Mo about Tonicom Athlon GHz Taisol CGK742092 (Aqua 680) Creative Ultra Disc callous IBM 75GXP
LOL
Op woensdag 09 januari 2002 14:51 schreef NoStra het volgende:
Whereas we did not nx27arrivions to exceed the 150-160 MHz on the mother boards based on a chipset KT13Á tested jusqux27alors, ABIT forwarded to us a very right KT7A-RAID output of the R&D which according to statements' of the manufacturer could hold of very high FSB. Sceptiques initially, we were surprised to see that the statements dx27ABIT were true since the card allows dx27aller jusqux27au maximum authorized by SoftMenu, cx27est with saying 183 MHz! With this intention, we used the following configuration: - Mother board ABIT KT7A-RAID - 128 Mo of SDRAM PC166 Tonicom - Athlon 1.33 GHz - Taisol CGK742092 (Aqua 680) - Creative Ultra GeForce2 - hard Disk IBM 75GXP And as you can see it... that boot! With with the passage light a overclocking of lx27Athlon 1.33 GHz. Of course, we nx27avons not been able to prevent us dx27effectuer some rapids benchmarks. Why fast? Quite simply because in spite of I/O Voltage of 3.9V, this FSB of 183 MHz did not nx27était 100% stable. For a perfect stability, it is necessary to go down to 177 MHz. Quake III Arena 640*480 16 bits: 1000 MHz Fsb 133, Sdram 133 2-2-2: 156.6 fps 1008 MHz FSB 183, SDRAM 183 3-3-3: 177.1 fps 1.33 GHz FSB 133, SDRAM 133 2-2-2: 179.3 fps 1.46 GHz FSB 133, SDRAM 133 2-2-2: 185.8 fps 1.46 GHz FSB 183, SDRAM 183 3-3-3: 211.8 fps As you can see it the profit can be very interesting, since at frequency equalizes the passage dx27un FSB of 133 to a FSB of 183 makes it possible to gain approximately 14% of performances under Quake III, which is rather greedy in bandwidth. For the aficionados of CPU Mark, know qux27a 1.46 GHz with a FSB of 183 MHz, one obtains a score of 135. Now, remains to know if these KT7A especially indicated to support large FSB will be born on the market, which is still far dx27être some. In any case, that enabled us to check that the KT13Á can reach rather high frequencies, and this on the condition of laying out dx27un adequate design of mother board. Faded dx27overclocking nx27ont from now on more qux27a to hope that these special KT7A unload one day in the retailers...
zow, ff vertaald... :)
volgende deel
All right agreed , ourselves nŽavons not pu ourselves bar dŽeffectuer some rapids tests about performance. Why rapids? All merely because although him I/O Voltage about 3.9V, thanksggiving FSB about MHz nŽétait not 100% stable. For a stability That's all right , he must alight at 177 MHz. Quake Arena 640*480 16 bits : MHz FSB 133, SDRAM 133 2-2-2 : fps MHz FSB 183, SDRAM 183 3-3-3 : fps GHz FSB 133, SDRAM 133 2-2-2 : fps GHz FSB 133, SDRAM 133 2-2-2 : fps GHz FSB 183, SDRAM 183 3-3-3 : fps As you tin him behold him gain tin be greatly interesting , since at frequency equal him changeover dŽun FSB about 133 at a FSB about 183 allows about earn about 14% about performance below Quake III, thanksggiving am enough greedy at band busy. For the aficionados about CPU Mark sachez quŽa GHz with a FSB about on achieves a score about 135. Now , remainder namely if these KT7A especially designate for abide about big FSB will see day about him walked , what am again away dŽêtre certain. Anyway , thanksggiving ourselves has allowable about audit as him KT133A tin affect any frequency enough exalted , and thanksggiving at condition about dispose dŽun design about card mother adequate. The fanas dŽoverclocking nŽont from now on anymore quŽa expect as these KT7A particular débarquent someday at the dealers...
hmm mijne is beter :P
Op woensdag 09 januari 2002 14:56 schreef -DD- het volgende:
YO welke Online vertaler is dat??? want die is nogal beter dan INtertran zo te zien
Op woensdag 09 januari 2002 14:57 schreef -KOD- het volgende:
deze:
http://world.altavista.com/
ik zoek extreme KT133a overkloks..en dan vooral wat meer info erbij..zoals wat voor een koeling, wat voor een board het is en welke versie van het bord het is.
Iemand toevallig nog wat URLS?
  • Termi
  • Laatst online: 18:20
Ze draaien wel een ouwe bios YH :).
Ik denk echter wel dat dit dan wel de laatste versie is (versie 1.3 dacht ik) van het moederbord is... Enige maanden geleden waren er al geruchten dat de KT7A mobo's van abit nieuwe overklok opties hadden...
aan de andere kant... 3,90 volt voor het geheugen vind ik wel ERRUG hoog...
Op woensdag 09 januari 2002 14:58 schreef -DD- het volgende:
deze:
ik wou net zeggen altavista doet het goed wat dat betreft
