Ik wil al tijden in mijn oude PI-mobo een AMD K6-2 draaien. qua busspeeds/multipliers kan dit.
nu zat ik met het voltage maar zojuist vond ik met GoogleGroups het volgende uit een ouwe newsgroep:
kan iemand me dit uitleggen/zeggen dat het werkt? (Bijv. wat ze bedoelen met power-musfet) Het betrept dus een Asus P/I P55TVP4 rev. 1.5.BF-2 trick works fine.
Voltage setting is NOT compatible. TVP4 has got a design failure in the
voltage regulator. The Power-MOSFET (NDP603, sometimes the one that is
mounted without heatsink) that bridges the two onboard voltages when no
dual voltage CPU is installed MUST be dismounted from the mainboard.
Without this the core voltage will never be lower than 2.6V, too much
for K6/2 at 2.2V. After dismounting this Power-MOSFET you'll see that
there's a double jumper 29 which must be set if a single Voltage CPU is
installed and which replaces the Power-MOSFET.
After that you must find out the jumper settings for 2.2V. This is only
possible if you mount a 270kOhm and a 47kOhm resistor near the voltage
jumpers. There are solder pins where it's easy to set them in. The
resistors must be mounted near Jumper 22 (47kOhm) and 21(270kOhm) which
are not active by default. After that the setting for 2.2V is (Jumper
22..18) 01111 (0=not set, 1=set).
> AFAIK the intel VX chipset was a 'HX light' and
> the settings described in the manual are the
> same as those on my T2P4.
> I want to run a K6 II-266.
Warning !!!
If you do not believe what I say you'll kill your CPU !!!
