Zo heb ik hem ingevuld: Maar het mag nog steeds niet baten
Ifconfig kan ik niet intikken als ik ben opgestart want hij wacht bij dhcpoffer. Wanneer ik hem opstart in config-mode dan kom ik niet uit het menu. Ctrl-C werkt ook niet. Brakke Freesco die 027 of....?
In ieder geval dit heb ik ingevuld-->
*711 Hostname of this computer [router]? router, clientnaam van Wanadoo: c5*******@wanadoo
*712 Domain name [inet]? inet
... Autodetect modems now ? y/n? n
*8xx How many ethernet cards do you have [1-3]? 2
*811 I/O port address of 1st ethernet card [0x300]? 0x320
*812 IRQ line of 1st ethernet card []? 5
*821 I/O port address of 2nd ethernet card [0x320]? 0x340
*822 IRQ line of 2nd ethernet card [7]? 7
*720 Use DHCP client for configuring 1st network interface y/n [y]? y
*721 Interface name of 1st network, eth0/eth1/eth2 etc [eth0]? eth0
*722 Enable DHCP client message logging y/n [y] ? n
*723 Update DNS server settings by DHCP y/n [y]? y
*731 Interface name of 2nd network, eth1/eth0/eth2 etc [eth1]? eth1
*732 IP address of 2nd network interface [192.168.1.1]? 192.168.0.1
*733 Network mask [255.255.255.0]? 255.255.255.0
*734 IP range [192.168.1.100 192.168.1.110]? 192.168.0.100 192.168.0.110
*411 Enable caching DNS server y/s/n [s]? s
*412 Enable DNS requests logging for debug purpose y/n [y]? n
*421 Enable DHCP server y/s/n [s]? s
*422 WINS address (if you have one, otherwise '-' n) [10.0.0.2]? -
*423 Default-lease-time, max-lease-time (sec) [604800,604800]? 86400,86400
*424 Do you want to create/edit static dhcp leases y/n []? n
*431 Enable public HTTP server y/s/n [n]? n
*441 Enable time server and router control via HTTP y/s/n [n]? n
*451 Enable print server(s) y/s/n [n]? n
*46 Enable telnet server y/s/n [n]? s
*14 Savers - Screen(min),hdd(x5 sec) 0 -off [0]? 0
*15 Swap file size in Megabytes (on boot device). 0 - disable [0]? 0
*13 Do you want to enable extra modules/programs y/n [n]? n
*16 Log sizes in bytes. Syslog, logins_log [50000,5000]? 30000,3000
*911 Host gateway (if exists, otherwise - '-') [] ? -
*912 Primary DNS address (usually your provider's DNS) [123.123.123.123]? 195.96.96.97
*912 Secondary DNS address (otherwise - '-') [233.233.233.233]? 195.96.96.33
*914 ISP http proxy address, (otherwise '-') []? niets ingevuld of anders:
http://proxy.wanadoo.nl:8080
*47 Do you want to export services y/n []? n
Verder bij Advance optie 32 kan je je provider invullen + loginname en password. Heb ik al geprobeerd echter doet het ook niet.
Verder heb ik met het 3com tooltje de poortadressen en irq's handmatig ingesteld. Ook heb ik de addressen van de kaarten omgedraaid mochten ze elkaar tegen spreken in freesco. (eth1 0*320 naar 0*340 en irq 5 naar 7)
Heb ik iets over het hoofd gezien of kan Freesco niet met Wanadoo Premium (kabel
