[RTCW] Opengl Probleem....
Hallo mensen, ik heb net (laat he) RTCW gekocht en nu krijg ik de volgende foutmelding:
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Return to Castle Wolfenstein\main\sp_pak2.pk3 (232 files)
C:\Program Files\Return to Castle Wolfenstein\main\sp_pak1.pk3 (1342 files)
C:\Program Files\Return to Castle Wolfenstein\main\pak0.pk3 (4775 files)
C:\Program Files\Return to Castle Wolfenstein/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Dit probleem heb ik ook gehad met Q3.
Wie kan mij hiermee helpen :?
  • NightCruiser
Zie -> [topic=369970/1/25]
slotje dus
  • ralfbosz
  • Laatst online: 30-10 09:04
ralfbosz
xm create bosz -c
Installeer de nieuwste driver van je videokaart. Probleem had ik ook, nieuwste driver van nvidia en probleem was opgelost !
rm -r *
  • chucky666
chucky666
d.y.w.play?
je vergeet te vermelden wat je specs van je compu zijn :)
altijd makkelijk ;)
een OW voor blaten in de IT? laat IT dan maar voortaan links liggen :(
Alweer |:( Als je een Nvidia chipset , heb download dan effe de 21.83 of de 23.11 drivers van Nvidia.com
Of zoek effe in de search over dit o zo bekende 'probleem' met de Quake 3 engine.
