Asio drivers voor SB Live!
Say what???!!! Wat is Asio??
  • A3-D
  • Laatst online: 13-09 11:53
Thanx man! Op deze manier kan ik de latency naar beneden halen onder Cubase 3.7 VST24.
Ik wist niet dat zoiets bestond! ;)
Most important is the fact that you will get ASIO drivers on your SBLive - this means you can get 10ms latency in Cubase - this is as good as realtime :) so if you use a vst instrument on your keyboard you can play and hear it without any delay
You don`t need to rewire or solder anything to get analogue Input/Output as written sometimes
the APS has some different dsp effects (Compressor, EQ, ...), routing possibilities ...
you can install and uninstall the APS drivers without any problems
Kickuh!
EV Skoda Enyaq | cv Wallbox Pulsar Plus V6.7.36 | PV 4720WP Zuid | PIB 2 x Marstek Venus E 5.12 kWh V157.3 - CT003 V118 | Landis+Gyr E360 SMR5.0 | Tibber
