GLXGEARS haalt ongeveer 1500 fps.
enne de output van glxinfo ziehier , weet iemand hoe ik dat overzichtelijker kan maken?
bash-2.04# glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.2
server glx extensions:
client glx vendor string: NVIDIA Corporation
client glx version string: 1.2
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_SGIX_swap_group, GLX_SGIX_swap_barrier
GLX extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce2 MX/AGP/3DNOW!
OpenGL version string: 1.2.2
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_transpose_matrix, GL_S3_s3tc, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_packed_pixels, GL_EXT_paletted_texture,
GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shared_texture_palette,
GL_EXT_stencil_wrap, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_cube_map, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_vertex_array, GL_EXT_vertex_weighting,
GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square,
GL_NV_evaluators, GL_NV_fence, GL_NV_fog_distance,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_register_combiners, GL_NV_texgen_emboss, GL_NV_texgen_reflection,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle,
GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SGIS_texture_lod
glu version: 1.2 Mesa 3.2
glu extensions:
GL_EXT_abgr
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 16 tc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 16 0 0 None
0x22 16 dc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 16 0 0 None
0x2a 16 tc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 16 0 0 None
0x2b 16 tc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 16 0 0 None
0x2c 16 tc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 16 0 0 None
0x2d 16 dc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 16 0 0 None
0x2e 16 dc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 16 0 0 None
0x2f 16 dc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 16 0 0 None
http://www.gjpvanwesten.nl
