Chaintech GF2Ti.. wie heeft em (gezien) ?
  • RedruM
  • Laatst online: 05-02 15:44
Ik kan op internet misschien 2 sites vinden over de chaintech gf2ti.. net uit oid? Ik ben er in geinteresseerd omdat hij cheap is.. maar is ie net zo goed als een merk gf2ti?
De officiele site geeft deze specs:
Afbeeldingslocatie: http://www.chaintech.com.tw/IMAGES/AGP/RI92T.jpg
Afbeeldingslocatie: http://www.chaintech.com.tw/IMAGES/AGP/AG220BOX.jpg
A-G220
Box Picture
Specification
Interface - AGP interface
- 4x/2x AGP supports
Chipset - nVIDIA GeForce2 Ti
Memory - 32/64 MB DDR SDRAM
General Features - 128-bit Memory Interface
- 256-bit 2D and 3D graphics accelerator
- 350MHz RAMDAC
- 250 MHz Core Clock
- 400 MHz Memory Clock
- 350 MHz RAMDAC
- 1000 Mtexel fill rate
- 20 M triangles/sec setup
- 6.4GB/sec memory bandwidth
- nVIDIA Shading Rasteriser
- 4 texels per Clock
- Integrated second-generation transform and lighting engine
- 32-bit color with 32-bit Z/stencil
- Optimized for Direct3D acceleration with complete support for MicrosoftR
- DirectTM X 5.0, 6.0, 7.0 and 8.0
- Cube Environment mapping
- DirectX and S3TC texture compression
- Supports NTSC, NTSC-EIA (Japan), and PAL (B, D, G, H, I, M and N) TV formats
- 15-pin D-sub VGA connector
High Quality Video Playback - DVD and HDTV ready motion compensation for MPEG-2 decoding up to 1920x1080i ATSC format
- Supports for VIP 2.0 interface
Full Software Support - WindowsR 95 / 98 and WindowsR ME Display Drivers
- WindowsR 2000 and XP Display Drivers
- OpenGL ICD support for WindowsR 95 / 98 / 2000
- Linux
Special Features - Video-Out function (S-Video connectors)
-TV-out Connector (Optional)
-TV-out Cable (Optional)
- DVI-I Connector (Optional)
Supports Super High-resolution Graphics Resolution Colors Refresh Rate
640x480 8/16/32 bit 150Hz
800x600 8/16/32 bit 150Hz
1024x768 8/16/32 bit 120Hz
1152x864 8/16/32 bit 120Hz
1280x1024 8/16/32 bit 100Hz
1600x1200 8/16/32 bit 85Hz
1920x1200 8/16/32 bit 75Hz
2048x1536 8/16 bit 60Hz
Maar is dit allemaal waar aangezien ik van iemand gelezen heb dat hij er een kreeg met ram op 333 mhz.. ?
  • Unex
Hm, ziet er goed uit, helemaal voor 289 gulden. Is toch een stuk goedkoper dan de andere GF2ti'en.
Denk wel dat ie hetzelfde is, als het niet zo is neem ik aan dat jem wel kan terugsturen aangezien het niet is wat het zou moeten zijn.
Trouwens ook nog niet gehoord van een gf2ti die lagere specs heeft.
specs
289 gulden..ik denk dat ze het niet over dezelfde GF2 Ti hebben..
of het is idd een 333Mhz versie..das ongeveer gelijk aan een GF2 GTS..
  • Unex
Ja, ik heb die vorige post ook ff doorgelezen. Die gast zei dat hij ook geen heatsinks op zijn mem had....
Je kan ook ff gistron mailen.
specs
  • RedruM
Op zondag 30 december 2001 20:24 schreef UneXisT het volgende:
Jep heb ze al gemaild..
maar zoals gewoonlijk nix ontvangen nog..
  • Unex
Op zondag 30 december 2001 21:18 schreef RedruM het volgende:
Nee daar zijn ze niet de snelste in nee :)
specs
  • erikdeperik
  • Laatst online: 25-07-2024
ik wil em ook kopen.
kheb ook al gemaild naar griston maar zijn waa\rschijnlijk
vanddag dicht ofzo dus het zal wel woensdag worden. :Z
ik zeg maar zo "zeg maar niks"
  • erikdeperik
ik heb hier gekeken pdf op de usa site daar staat niks over ti uitvoering het zal dan wel een pro versie zijn. http://www.chaintech-excel.com/Literature/Line%20Card%20Chain%20Multimedia080701.pdf
  • erikdeperik
toch wat gevonden hier
http://www.chaintech.dk/PROD/AGP/AG220.htm
dus het zou type AG220 moeten zijn?
edie/ ik kon niet wachten en heb em besteld bij gistron, onder voorwaarde dat het type a-g220 is. :9
ik bedoel idd 220
  • BlizzarD
BlizzarD
Hooooooh
neej ag220 toch?
en hopelijk reageerd gistron wel :)
iStockphoto
  • Fzeven
  • Laatst online: 07-04-2021
Ik heb er een idd geen heatsinks op het geheugen.
Core = 250Mhz, Mem = 400Mhz.
Op de PC dumpdag gekocht voor 295 gulden bij Hacom.
zelf heb ik de Chaintech Ti kaart al een paar weken. Ben er dik tevreden over, vooral na een upgrade van een TNT2.
Begin zelf effe problemen gehad met het aansluiten. Moest in de bios de I/O voltage met een paar tiende verhogen om hem tot leven te wekken.
Heb hem zelf uit helmond van de site www.pcvoordeel.nl.
Had daar zelf de Gforce 2 pro 64 ddr tv-out besteld, maar kreeg voor dezelfde prijs de Chaintech Ti tv-out.:)
kost daar fl. 349,-
  • erikdeperik
Op maandag 31 december 2001 13:41 schreef Fzeven het volgende:
dan zal het wel type a-g220 zijn ...wel goed die speed zonder xtra cooling
kloppen die specs met die van de topicstarter?
edie/ ik heb net een order bevesteging gehad bij gistron,
ik had erbij vermeld dat het wel die a-g220 moest zijn en anders eerst info moest hebben...geen vermelding erbij,dus
zal dit hem zijn! :9
  • Fzeven
Ja die kloppen.
  • BlizzarD
BlizzarD
Hooooooh
jep dat moet um zijn :D ik heb nu een ati rage 128, die overgang naar een gf2ti zal ik ook wel merken >:) :D
iStockphoto
  • Sir Vega
  • Laatst online: 05-01-2022
Ik heb chaintech geforce ti 2 bestelt en kreeg een 333mhz versie dus terug gestuurd ik w8 nog 1 week en kijk dan welke ik dan van hun krijg :) heb er wel vertrouwen in.. verder is het een super kaart met 4400 3dmark voor 300 piek
Sick Nick : " K, ik ben net wakker en ik geef mijn ongelijk nu toe, jammer alleen dat ie het niet kan lezen. Wanneer komt ie m'n spullen halen"
  • RedruM
Op maandag 31 december 2001 14:22 schreef erikdeprik het volgende:
Laat het me weten als je em binnen hebt please!
37597380 of p.smid@chello.nl
thx :)
  • -=MOL=-
  • Laatst online: 27-11-2019
-=MOL=-
R.I.P. TEC 172W 23-10-2002 :(
Ik heb hem in een pc van een klant gezet, en die zit blij unrela en quake te spelen. Alles draait soepel op 1280x1024 32 bit full detail. Dus het is wel een lekker kaartje. Beeld zag er ook allemaal goed uit. Alleen de kleur van de heatsink vind ik niet om aan te zien, maar die zie je bij de meesten toch niet.
Oja, het is trouwens een p3 1Ghz met 256 sdram.
[Asus A7V266-E][AMD XP 1700+ (water cooled)][Hercules GF3 Ti500][256 MB Crucial DDR][SB Live 5.1][2 x 40GB][3com 3c905ctx-m]
  • Sir Vega
die kleur is juist een van de mooiste!!!
Ik heb zelf een chaintech geforce2mx400 ben er dik tevredenover.
mijn scoren in 3dmark2001 zijn dan ook 3188punten.
dus als je die ti versie zou pakken kan je er vast wel veel van verwachten.
Mijn raad geving gewoon bestellen!!!
Je zult er geeen spijt van hebben!! *D
  • Sir Vega
Mijn ti haalde 4400 punte hehe
