Ik heb curl gevonden en ook de documentatie doorgelezen, nu is het volgende probleem daar dat de .bat files die in de omschrijving staan niet bestaan in de archive..
http://curl.haxx.se/docs/install.html
http://curl.haxx.se
Hoe moet ik um installerenWin32
Without SSL:
MingW32 (GCC-2.95) style
Run the 'mingw32.bat' file to get the proper environment variables
set, then run 'make mingw32' in the root dir.
If you have any problems linking libraries or finding header files, be
sure to verify that the provided "Makefile.m32" files use the proper
paths, and adjust as necessary.
Cygwin style
Almost identical to the unix installation. Run the configure script in
the curl root with 'sh configure'. Make sure you have the sh
executable in /bin/ or you'll see the configure fail towards the end.
Run 'make'
Microsoft command line style
Run the 'vcvars32.bat' file to get the proper environment variables
set, then run 'nmake vc' in the root dir.
The vcvars32.bat file is part of the Microsoft development
environment.
IDE-style
If you use VC++, Borland or similar compilers. Include all lib source
files in a static lib "project" (all .c and .h files that is).
(you should name it libcurl or similar)
Make the sources in the src/ drawer be a "win32 console application"
project. Name it curl.
With VC++, add 'ws2_32.lib' to the link libs when you build curl!
Borland seems to do that itself magically. Of course you have to make
sure it links with the libcurl too!
For VC++ 6, there's an included Makefile.vc6 that should be possible
to use out-of-the-box.
Microsoft note: add /Zm200 to the compiler options to increase the
compiler's memory allocation limit, as the hugehelp.c won't compile
due to "too long puts string".
http://curl.haxx.se
