No trees were killed in the sending of this message. However a large number of electrons were terribly inconvenienced.
Bij mijn proxyper zat een changelog, dat zegt het volgende:
=== build 319c (12 Sept 2000) ===
win32 version can now be signalled to flush, quit, or reload its
configuration by an external program that opens and signals events
named "ProxyperConnectEvent", "ProxyperShutdownEvent", or
"ProxyperReloadEvent" respectively. [319b fixed permission problem
when the proxy is running as a service on NT/Win2k]
fixed regression bug introduced in 316 that prevented reload signals
from properly reloading all contest configuration options.
optimal block selection algorithm on personal proxy modified to
no longer search the entire in-buff for a block large enough when an
incoming client requests a block. Now only searches the first 32
blocks for a work unit large enough.
participation in contests can now be entirely disabled by setting
the "contestclosed" entry within your INI to a negative value.
[keyserver]/serveridletimeout added to allow persistent server
connections to time out more rapidly, particularly for people on ISDN
or dialup connections.
minimum blocksize enforcement code removed from personal proxy builds,
only fullserver enforces minimum sizes now.
=== build 318 (14 Jul 2000) ===
experimental minimum blocksize enforcement code added to fullserver
and personal.
Ah. Merci..
Geen echt schokkende veranderingen volgens mij.
Dan kan de upgrade mooi wachten tot ik weer eens in de buurt ben van de proxy. (Proxy staat niet echt op een easy-access locatie)
Best een snelle ontdekking hoor, na 15 maanden
Ik ben zo hard bezig met het uitrollen van nieuwe clients,
dat ik geen tijd heb om ook nog eens op de proxy te letten.
