(smoothwall)lilo problemen
  • Japie.G
  • Laatst online: 19:33
Japie.G
Colour Classic
Na instalatie van smoothwall blijft lilo steken bij de "l". wie weet hoe dit voorkomen kan worden :?
Het scherm ziet er dus zo uit:
| L                         |
Het is een Pentium 75 met 16MB ram, en een hele oude 100MB hardeschijf
Renault Scenic E-Tech EV - PV-Output - 48kWh LiFePo4 op 15kVa Victron systeem
Surf eens naar http://groups.google.com en werp daar hetvolgende in de search :
 lilo "LI"
en verbaas u over de hoeveelheid vragen en antwoorden die u vindt ;)
Kleine aanvulling :
Problem: When I boot, all I get is 'LI'
This means the first-stage loader gained control; it thought it success-
fully loaded the second-stage loader; but it never got there. This most
often occurs when the second-stage loader, '/boot/boot.b', is not load-
able using the BIOS.
First, have you tried specifying 'lba32' in your 'lilo.conf' file? On
newer systems, this will almost always work, since the loader will now
use the newer EDD packet calls, which are not cylinder-limited.
Second, do you know your disk geometry? This means, do you know the
numbers of cylinders/heads/sectors of all your hard drives; and are these
the numbers that LILO is using when it installs the boot loader. Three
reports of the disk geometry may be obtained:
1. Run 'lilo -t -v5' and check the geometry reports for each device.
2. Run 'lilo -Tgeom' and see if the same numbers are reported. (This
may fail on some systems, where LILO has trouble running BIOS
calls in v86 mode.)
3. Create the diagnostic floppy (see README.disk) and check the
reported disk geometries.
If any of the geometry reports differ, then you may have to specify the
disk geometry to LILO using 'disk= heads= sectors='. Use the actual
numbers reported by the BIOS: #3 above, or #2.
The reports above will also indicate the BIOS device codes used by each
disk. LILO uses heuristics to obtain these device codes, and usually gets
the codes right on all-IDE or all-SCSI systems. However, systems with
multiple IDE controllers, mixed IDE/SCSI systems, and SCSI systems on
Future Domain controllers, will require you to tell LILO what disks are
assigned to what device codes. This can be done using 'disk= bios=' lines
in 'lilo.conf'.
  • Japie.G
Japie.G
Colour Classic
okee, veel oplossingen worden gegeven inderdaad, maar het komt altijd weer neer op het wijzigen van de lilo.conf en het probleem is dus dat ik linux niet kan booten :P en dus ook niet in /etc/lilo.conf kan komen. Het is smoothwall, en daarvan heb ik gen emergency bootdisk zeg maar, alleen die setupstarterdiskette die ik met rawrite had gemaakt.
Toch bedankt voor de info
