[PPStats] Wat doe ik fout ??
  • 113 views sinds 30-01-2008
  • Narf109
  • Laatst online: 15-10 12:00
Ik heb vangaag de nieuwe PPstats op m'n servertje gezet, hij maakt netjes alle pagina's aan (zelfs plot.gif ;)) maar de rest van de gegevens staan er niet :?
Ik heb zo het idee dat ie m'n log files niet goed verwerkt of gewoon helemaal niet leest.
Ik heb wel tig keer alle verwijzingen na zitten kijken en ik kom er niet meer uit :(
Hier een paar stukjes van m'n ini files:
pp-stats-rc5.ini:
LogDir = "/program files/dnet proxy/rc5/"
LogPre = "pproxyrc5"    # For rc5pkeyYYYYMMDD
LogSuf = "log"      # For rc5pkeyYYYYMMDD.log
# The personal proxy can read compressed log files after they have been
# rotated. If you have this proxy option enabled and want to use ppstats,
# configure the following settings. The defaults are for UNIX gzip. Command
# that unzips the logfile to stdout without deleting the file is required.
#ProcessZipLogs  = 0         # Ignore zipped log files.
ProcessZipLogs   = 1         # Unzip and process all log files.
LogZipSuf     = "log.gz"    # For rc5pkeyYYYYMMDD.log.gz
LogTmpSuf     = "log.tmp"     # For rc5pkeyYYYYMMDD.log.tmp
LogDecompressor  = "gzip -d -c"  # Command line zip decompressor.
# Maximum number of days to read log files. A value of zero means
# read all available log files without limit. A value of 365 would mean
# only read back blocks done in the last year and ignore anything older.
MaxDays = 365
# Set here the correct path to the proxyper.ini file.
# ppstats will try to read options out of it.
ProxyIni = "/program files/dnet proxy/proxyper.ini"
#--- Output Options ----------------------------------------------------------
# Full path to output file location. This should end in a "/".
HtmlDir = "/inetpub/wwwroot/"
en m'm proxyper.ini:
[console]
logfileconsole=console\logrc5
logfileconsolerotation=daily
consoleverbosity="general stats keyblock server client buffers timestamp attention errlow errsevere"
timestampflags=130
[rc564]
expertmode=1
logfilekeyblock=rc5\pproxyrc5
logfilekeyblockrotation=daily
minkeysready=2000
maxkeysready=30000
;minkeysdone=50000
maxkeysdone=25000
Wat heb ik over het hoofd gezien ?
De PerProxy draait op een P133 + NT4 + IIS4
  • radial
  • Laatst online: 18-10 13:13
radial
Watch out
Probeer eerst een volledige paden aan te geven overal naartoe en kijken of dat meer output geeft met benodigde data.
20xSF170s - ozo
  • Narf109
Heb ik gedaan zonder enig resultaat, als ik het volledige pad in 'proxper.ini' aangeef dan geeft 'ppstats' aan dat hij de consolelogs niet kan vinden, hij heeft dus wel mijn 'proxyper.ini' gelezen...
Als ik het volledige pad in 'pp-stats-rc5.ini' ingeef dan maakt dit niet uit.
Alle gegevens op de html pagina's blijven op 'none'
  • MeneerKrab
  • Laatst online: 29-06 07:05
run de stats.pl dan eens zo stats.pl -debug Hier kan je zien wat hij weergeeft en wat er eventueel misgaat
  • Narf109
Op vrijdag 28 december 2001 22:14 schreef PowerCow het volgende:
Ook gedaan en geen foutmeldingen, ik zie dat hij de proxyper.ini uitleest en wat gemummel in de trant van:
Read 13 domain consolidation entries ...
Read 3 IP consolidation entries ...
Read 2 names entries ...
Dus er komt wel iets binnen geloof ik, maar waarom krijg ik dit niet te zien op m'n statspage ???
  • MeneerKrab
en een link naar de site.
volgens mij leest hij gewoon de rclogs niet in.
maakt hij wel logfiles aan???
  • Narf109
Op vrijdag 28 december 2001 22:33 schreef PowerCow het volgende:
Die snap ik niet helemaal...bedoel je die verwijzing in de ppstats.ini ?
Ja, hij maak log files aan (daily)
  • NightBird
  • Laatst online: 18-10 21:03
NightBird
DPC-Crew Coding
Op vrijdag 28 december 2001 22:40 schreef Narf het volgende:
Hij bedoelt: waar kunnen we je output zien? (de html dus)
WatHoorJeWaar · Asobakken
Eerdere projecten: Leading Courses · Brandstof-zoeker.nl · Voertuig-zoeker.nl
  • Narf109
Op dit moment (als het goed is ;)) hier: http://62.251.2.203:8080/
  • stappel_
  • Laatst online: 08:41
Op vrijdag 28 december 2001 22:22 schreef Narf het volgende:
hij leest wel dingen, maar die dingen slaan op ppstats zelf. het probleem is waarschijnlijk dat je spaties in het path naar de rc5 logs files heb zitten.
probeer het eens in een andere dir zonder spaties.
Ubero: #2, Euler: #1, GOT: #1, Des: #1, Zeta: #1, Eon: #3, OGR-24: #3, OGR-25: #7,
LM: #7, AP: #5, DF: #19, D2OL: #37, SOB: #50, TSC: #63, RC5: #96
  • Narf109
YESS !!!!!!
Dat was hem idd :) :)
* Narf was hier al heel de avond mee bezig |:(
Hij pakt alleen de stats van de proxy zelf nog niet maar dat zal wel net zoiets zijn denk ik.
Bedankt allemaal }:O
  • FutureCow
  • Laatst online: 10:05
FutureCow
(C) FutureCow
dat had je ook wel kunnen weten je had gewoon de MS-DOS pad moeten opgeven gaat het altijd goed dus /Progra~1/Dnetpr~1/rc5/
  • Sir Abarth
  • Laatst online: 18-01-2024
Sir Abarth
The secret word is: ToeT!
In je pproxy.ini staan ook paden die gebruikt worden (uitgelezen) door ppstats voor de consolelogfiles enzo.
Denk daaraan :)
ToeTerdeToeTToeT! | May the ToeT be with you | There is no ToeT | specs
Still the gentleman ;)
[Clan of ToeT]
  • MeneerKrab
nog 1 ding Narf. Die counter verneukt eigenlijk een beetje de layout.
't is ook verstandig op striplog te gaan gebruiken, dat maakt je logfiles kleiner, waardoor je statsrun minder lang is, en daarbij kan je ranzige hosts (zoals die bij jou op je proxy) samenvoegen onder één naam.
  • Narf109
Is al gefixt ;)
Heb ik gedaan alleen nu zit ik met het probleem dat bv alle clients die inbellen via Planet onder dezelfde naam vallen :(
Kan ik niet iets doen met het e-mailadres ?, dus iets van:
Dpc_narf@hotmail.com=client_1
dPc_narf@hotmail.com=client_2
dpC_narf@hotmail.com=client_3
dpc_Narf@hotmail.com=client_4
etc.
Ik heb hier ooit wel eens iets over gelzen hier op GoT maar kan het niet terug vinden...
  • Narf109
Ik heb het al gevonden denk ik...
de regels "$entry =~ tr/A-Z/a-z/;" weghalen (of #'en) zodat er geen lowercase geforceerd wordt.
En de DayTopHost=0 om op e-mail te sorteren ipv hostname
Ik geloof dat dit het is, nu moet ik dus alle clients ff voorzien van een aangepast ID
Klopt dit een beetje ?
