29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
| XFree86 Version 4.1.0 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 2 June 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.2.19 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Dec 26 18:47:35 2001
(==) Using config file: "/etc/X11/XF86Config"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) | |-->Monitor "Adi"
(**) | |-->Device "Prophet"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x8000083c, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7190 card 0000,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7191 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
(II) PCI: 00:07:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
(II) PCI: 00:09:0: chip 1011,0014 card 0000,0000 rev 21 class 02,00,00 hdr 00
(II) PCI: 00:0a:0: chip 11c1,044a card 144f,1005 rev 01 class 07,80,00 hdr 00
(II) PCI: 00:0b:0: chip 9004,5078 card 0000,0000 rev 01 class 01,00,00 hdr 00
(II) PCI: 01:00:0: chip 104a,0010 card 1681,0010 rev 07 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x88 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0xf4000000 - 0xf4ffffff (0x1000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) SGS-Thomson unknown chipset (0x0010) rev 7, Mem @ 0xe0000000/27, 0xe8000000/19, I/O @ 0xe000/8
(II) Addressable bus resource ranges are
[1] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0xf6002000 - 0xf6003fff (0x2000) MX[B]E
[1] -1 0xf6001000 - 0xf6001fff (0x1000) MX[B]E
[2] -1 0xf6000000 - 0xf7ffffff (0x2000000) MX[B]E
[3] -1 0xf0000000 - 0xf3ffffff (0x4000000) MX[B]E
[4] -1 0xe8000000 - 0xe807ffff (0x80000) MX[B](B)
[5] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[6] -1 0x00007400 - 0x000074ff (0x100) IX[B]E
[7] -1 0x00007000 - 0x000070ff (0x100) IX[B]E
[8] -1 0x00006c00 - 0x00006cff (0x100) IX[B]E
[9] -1 0x00006800 - 0x000068ff (0x100) IX[B]E
[10] -1 0x00006400 - 0x000064ff (0x100) IX[B]E
[11] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
[12] -1 0x0000e000 - 0x0000e0ff (0x100) IX[B](B)
(II) PCI Memory resource overlap reduced 0xf6000000 from 0xf7ffffff to 0xf6000fff
(II) Active PCI resource ranges after removing overlaps:
[2] -1 0xf6000000 - 0xf6000fff (0x1000) MX[B]E
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0xf6002000 - 0xf6003fff (0x2000) MX[B]E
[6] -1 0xf6001000 - 0xf6001fff (0x1000) MX[B]E
[7] -1 0xf6000000 - 0xf6000fff (0x1000) MX[B]E
[8] -1 0xf0000000 - 0xf3ffffff (0x4000000) MX[B]E
[9] -1 0xe8000000 - 0xe807ffff (0x80000) MX[B](B)
[10] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[11] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
[12] -1 0x00000000 - 0x000000ff (0x100) IX[B]
[13] -1 0x00007400 - 0x000074ff (0x100) IX[B]E
[14] -1 0x00007000 - 0x000070ff (0x100) IX[B]E
[15] -1 0x00006c00 - 0x00006cff (0x100) IX[B]E
[16] -1 0x00006800 - 0x000068ff (0x100) IX[B]E
[17] -1 0x00006400 - 0x000064ff (0x100) IX[B]E
[18] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
[19] -1 0x0000e000 - 0x0000e0ff (0x100) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "fbdev"
(II) Loading /usr/X11R6/lib/modules/drivers/fbdev_drv.o
(II) Module fbdev: vendor="The XFree86 Project"
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.2
(II) FBDev: driver for framebuffer: fbdev, afb
(II) Primary Device is: PCI 01:00:0
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 0.0.2
(II) FBDev(0): using default device
(II) Running in FRAMEBUFFER Mode
(**) FBDev(0): Depth 8, (--) framebuffer bpp 8
(==) FBDev(0): Default visual is PseudoColor
(==) FBDev(0): Using gamma correction (1.0, 1.0, 1.0)
(II) FBDev(0): Hardware: VESA VGA (vidmem: 8192k)
(II) FBDev(0): Checking Modes against framebuffer device...
(II) FBDev(0): mode "640x480" test failed
(II) FBDev(0): mode "800x600" test failed
(II) FBDev(0): mode "1024x768" test failed
(II) FBDev(0): mode "1280x1024" test failed
(II) FBDev(0): Checking Modes against monitor...
(--) FBDev(0): Virtual size is 1024x768 (pitch 1024)
(**) FBDev(0): Built-in mode "current": 78.7 MHz, 59.9 kHz, 75.7 Hz
(II) FBDev(0): Modeline "current" 78.65 1024 1056 1184 1312 768 772 776 792 -hsync -vsync -csync
(==) FBDev(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.1
(**) FBDev(0): Using "Shadow Framebuffer"
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/X11R6/lib/modules/libshadow.a
(II) Module shadow: vendor="The XFree86 Project"
Fatal server error:
AddScreen/ScreenInit failed for driver 0
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to xfree86@xfree86.org. |
