Wat is PCI to DRAM prefetch
Ik heb de search gebruikt maar geen antwoord gevonden.
[topic=130380/1/25]
Ok nu dus de vraag wat en waarvoor is PCI to DRAM prefetch.
  • Stropdas
  • Laatst online: 05-10 14:46
Stropdas
Insert subtitle here
PCI-to-DRAM Prefetch (enabled)
In order to avoid repetitive accesses to the system memory for retrieving small pieces of data, an entire area of memory can be prefetched, based on the locality of coherent data. This means that the data are already in the buffer before they are needed and can be accessed with very low latency. This mode can enhance sound card and IEEE 1394 PCI card performance.
Lang leve Google!!!!! :)
Honda VFR800fi '99 | Volvo S60 '04
