KDE Resolutie aanpassen
Dit is mijn knelpuntje:
Ik heb een poeter (Dual Celly) met een ouwe monitor eraan vast. Ik kan in KDE komen maar dan op 640x480. Da wil ik nie... Ik heb de search al fanatiek gebruikt alleen ik kom er niet meer uit.
dit is mijn XF86Config:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
Section "ServerLayout"
Identifier     "XFree86 Configured"
Screen  0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath   "/usr/X11R6/lib/modules"
FontPath     "/usr/X11R6/lib/X11/fonts/misc/"
FontPath     "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath     "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath     "/usr/X11R6/lib/X11/fonts/CID/"
FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "Module"
Load  "dbe"
Load  "dri"
Load  "extmod"
Load  "glx"
Load  "pex5"
Load  "type1"
Load  "freetype"
Load  "record"
Load  "xie"
EndSection
Section "InputDevice"
Identifier  "Keyboard0"
Driver  "keyboard"
EndSection
Identifier  "Mouse0"
Driver  "mouse"
Option  "Protocol" "PS/2"
Option  "Device" "/dev/mouse"
EndSection
Section "Monitor"
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option     "NoAccel"            # [<bool>]
#Option     "SWcursor"          # [<bool>]
#Option     "UsePIO"              # [<bool>]
#Option     "ShowCache"          # [<bool>]
#Option     "VideoKey"          # <i>
#Option     "NoSLI"            # [<bool>]
#Option     "TexturedVideo"      # [<bool>]
#Option     "DRI"                # [<bool>]
Identifier  "Card0"
Driver  "tdfx"
VendorName  "3dfx Interactive"
BoardName   "Voodoo3"
BusID    "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device     "Card0"
Monitor    "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth     1
Modes     "800x600" "640x480"
ViewPort  0 0
EndSubSection
Depth     4
ViewPort  0 0
EndSubSection
Depth     8
ViewPort  0 0
EndSubSection
Depth     15
ViewPort  0 0
EndSubSection
Depth     16
ViewPort  0 0
EndSubSection
Depth     24
ViewPort  0 0
EndSubSection
EndSection
En ik heb CTRL-ALT-- en CTRL-ALT-+ ook al geprobeerd. Deed niks helaas.
Nu heb ik ook geen specs van de monitor omdat het een 2ehands 15" is. Onder W95 heeft ie op 800x600 gedraaid. Iemand tips?
Welke distro??
Slackware 8.0
Kernel 2.2.19
  • Sihaya
Sihaya
Pasfoto:
Wat geeft /var/log/XFree86.0.log
Probeer in XF86Config
Section "Monitor"
      Identifier    "Generic Monitor"
      HorizSync  28-33
      VertRefresh     43-72
      Option        "DPMS"
EndSection
erbij te zetten (natuurlijk wel met de juiste waarden van jouw monitor)
signature has expired
Hmmm specs van mijn monitor weet ik dus niet... 't is een 2ehandsje... |:(
Hier is m'n /var/log/XFree86.0.log
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
XFree86 Version 4.1.0 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 2 June 2001
      If the server is older than 6-12 months, or if your card is
      newer than the above date, look for a newer version before
      reporting problems.  (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.2.19 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Tue Dec 25 22:08:09 2001
(==) Using config file: "/etc/X11/XF86Config"
Markers: (--) probed, (**) from config file, (==) default setting,
       (++) from command line, (!!) notice, (II) informational,
       (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "XFree86 Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/CID/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(**) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
      XFree86 ANSI C Emulation: 0.1
      XFree86 Video Driver: 0.4
      XFree86 XInput driver : 0.2
      XFree86 Server Extension : 0.1
      XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
      compiled for 4.1.0, module version = 1.0.0
      Module class: XFree86 Font Renderer
      ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
      compiled for 4.1.0, module version = 0.1.0
      ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7190 card 0000,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7191 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
(II) PCI: 00:07:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
(II) PCI: 00:09:0: chip 1102,0002 card 1102,8027 rev 07 class 04,01,00 hdr 80
(II) PCI: 00:09:1: chip 1102,7002 card 1102,0020 rev 07 class 09,80,00 hdr 80
(II) PCI: 00:0b:0: chip 10b7,9055 card 10b7,9055 rev 30 class 02,00,00 hdr 00
(II) PCI: 00:13:0: chip 1103,0004 card 0000,0000 rev 01 class 01,80,00 hdr 80
(II) PCI: 00:13:1: chip 1103,0004 card 0000,0000 rev 01 class 01,80,00 hdr 80
(II) PCI: 01:00:0: chip 121a,0005 card 121a,0030 rev 01 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
      [0] -1  0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
      [0] -1  0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x88 (VGA_EN is set)
(II) Bus 1 I/O range:
      [0] -1  0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
      [0] -1  0xe4000000 - 0xe7ffffff (0x4000000) MX[B]
(II) Bus 1 prefetchable memory range:
      [0] -1  0xe8000000 - 0xe9ffffff (0x2000000) MX[B]
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) 3dfx Interactive Voodoo3 rev 1, Mem @ 0xe4000000/25, 0xe8000000/25, I/O @ 0x9000/8
(II) Addressable bus resource ranges are
      [1] -1  0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
      [0] -1  0xffe00000 - 0xffffffff (0x200000) MX[B](B)
      [1] -1  0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
      [2] -1  0x000f0000 - 0x000fffff (0x10000) MX[B]
      [3] -1  0x000c0000 - 0x000effff (0x30000) MX[B]
      [4] -1  0x00000000 - 0x0009ffff (0xa0000) MX[B]
      [5] -1  0x0000ffff - 0x0000ffff (0x1) IX[B]
      [6] -1  0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
      [0] -1  0xec000000 - 0xefffffff (0x4000000) MX[B]E
      [1] -1  0xe0000000 - 0xe3ffffff (0x4000000) MX[B]E
      [2] -1  0xe8000000 - 0xe9ffffff (0x2000000) MX[B](B)
      [3] -1  0xe4000000 - 0xe5ffffff (0x2000000) MX[B](B)
      [4] -1  0x0000c400 - 0x0000c4ff (0x100) IX[B]E
      [5] -1  0x0000c000 - 0x0000c0ff (0x100) IX[B]E
      [6] -1  0x0000bc00 - 0x0000bcff (0x100) IX[B]E
      [7] -1  0x0000b800 - 0x0000b8ff (0x100) IX[B]E
      [8] -1  0x0000b400 - 0x0000b4ff (0x100) IX[B]E
      [9] -1  0x0000b000 - 0x0000b0ff (0x100) IX[B]E
      [10] -1 0x0000ac00 - 0x0000acff (0x100) IX[B]E
      [11] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
      [12] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
      [13] -1 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
      [14] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
      [15] -1 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
      [5] -1  0xec000000 - 0xefffffff (0x4000000) MX[B]E
      [6] -1  0xe0000000 - 0xe3ffffff (0x4000000) MX[B]E
      [7] -1  0xe8000000 - 0xe9ffffff (0x2000000) MX[B](B)
      [8] -1  0xe4000000 - 0xe5ffffff (0x2000000) MX[B](B)
      [9] -1  0x0000ffff - 0x0000ffff (0x1) IX[B]
      [10] -1 0x00000000 - 0x000000ff (0x100) IX[B]
      [11] -1 0x0000c400 - 0x0000c4ff (0x100) IX[B]E
      [12] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B]E
      [13] -1 0x0000bc00 - 0x0000bcff (0x100) IX[B]E
      [14] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
      [15] -1 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
      [16] -1 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
      [17] -1 0x0000ac00 - 0x0000acff (0x100) IX[B]E
      [18] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
      [19] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
      [20] -1 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
      [21] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
      [22] -1 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
      Module class: XFree86 Server Extension
      ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading extension GLX
(II) LoadModule: "pex5"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading extension X3D-PEX
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
      compiled for 4.1.0, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
      compiled for 4.1.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "xie"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading extension XIE
(II) LoadModule: "tdfx"
(II) Loading /usr/X11R6/lib/modules/drivers/tdfx_drv.o
(II) Module tdfx: vendor="The XFree86 Project"
      Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
      Module class: XFree86 XInput Driver
      ABI class: XFree86 XInput driver, version 0.2
(II) TDFX: Driver for 3dfx Banshee/Voodoo3 chipsets: 3dfx Banshee,
      3dfx Voodoo3, 3dfx Voodoo5
(II) Primary Device is: PCI 01:00:0
(--) Chipset 3dfx Voodoo3 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
      [9] 0   0x000a0000 - 0x000affff (0x10000) MS[B]
      [10] 0  0x000b0000 - 0x000b7fff (0x8000) MS[B]
      [11] 0  0x000b8000 - 0x000bffff (0x8000) MS[B]
      [12] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
      [13] -1 0x00000000 - 0x000000ff (0x100) IX[B]
      [14] -1 0x0000c400 - 0x0000c4ff (0x100) IX[B]E
      [15] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B]E
      [16] -1 0x0000bc00 - 0x0000bcff (0x100) IX[B]E
      [17] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
      [18] -1 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
      [19] -1 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
      [20] -1 0x0000ac00 - 0x0000acff (0x100) IX[B]E
      [21] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
      [22] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
      [23] -1 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
      [24] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
      [25] -1 0x00009000 - 0x000090ff (0x100) IX[B](B)
      [26] 0  0x000003b0 - 0x000003bb (0xc) IS[B]
      [27] 0  0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) TDFX(0): Softbooting the board (through the int10 interface).
(II) TDFX(0): Primary V_BIOS segment is: 0xc000
(II) TDFX(0): Softbooting the board succeeded.
(**) TDFX(0): Depth 24, (--) framebuffer bpp 32
(==) TDFX(0): RGB weight 888
(==) TDFX(0): Default visual is TrueColor
(--) TDFX(0): Chipset: "3dfx Voodoo3"
(--) TDFX(0): Linear framebuffer at 0xE8000000
(--) TDFX(0): MMIO registers at addr 0xE4000000
(--) TDFX(0): PIO registers at addr 0x9000
(--) TDFX(0): VideoRAM: 16384 kByte Mapping 32768 kByte
(==) TDFX(0): Using gamma correction (1.0, 1.0, 1.0)
(WW) TDFX(0): Monitor0: Using default hsync range of 28-33kHz
(WW) TDFX(0): Monitor0: using default vrefresh range of 43-72Hz
(II) TDFX(0): Clock range:  12.00 to 300.00 MHz
(II) TDFX(0): Not using default mode "640x350" (hsync out of range)
(II) TDFX(0): Not using default mode "640x400" (hsync out of range)
(II) TDFX(0): Not using default mode "720x400" (hsync out of range)
(II) TDFX(0): Not using default mode "640x480" (hsync out of range)
(II) TDFX(0): Not using default mode "800x600" (hsync out of range)
(II) TDFX(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) TDFX(0): Not using default mode "1024x768" (hsync out of range)
(II) TDFX(0): Not using default mode "1152x864" (hsync out of range)
(II) TDFX(0): Not using default mode "1280x960" (hsync out of range)
(II) TDFX(0): Not using default mode "1280x1024" (hsync out of range)
(II) TDFX(0): Not using default mode "1600x1200" (hsync out of range)
(II) TDFX(0): Not using default mode "1792x1344" (hsync out of range)
(II) TDFX(0): Not using default mode "1856x1392" (hsync out of range)
(II) TDFX(0): Not using default mode "1920x1440" (hsync out of range)
(II) TDFX(0): Not using default mode "1400x1050" (hsync out of range)
(II) TDFX(0): Not using default mode "1400x1050" (unknown reason)
(II) TDFX(0): Not using mode "800x600" (no mode of this name)
(--) TDFX(0): Virtual size is 640x480 (pitch 640)
(**) TDFX(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) TDFX(0): Modeline "640x480"   25.20  640 656 752 800  480 490 492 525 -hsync -vsync
(==) TDFX(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
      ABI class: XFree86 ANSI C Emulation, version 0.1
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(**) TDFX(0): ShowCache Disabled
(**) TDFX(0): video key default 0x1e
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) TDFX(0): initializing int10
(II) TDFX(0): VESA BIOS detected
(II) TDFX(0): VESA VBE Version 3.0
(II) TDFX(0): VESA VBE Total Mem: 16384 kB
(II) TDFX(0): VESA VBE OEM: 3dfx Interactive, Inc.
(II) TDFX(0): VESA VBE OEM Software Rev: 1.0
(II) TDFX(0): VESA VBE OEM Vendor: Elpin Systems, Inc.
(II) TDFX(0): VESA VBE OEM Product: 3dfx Avenger
(II) TDFX(0): VESA VBE OEM Product Rev: Version 1.00
(II) Reloading /usr/X11R6/lib/modules/libddc.a
(II) TDFX(0): VESA VBE DDC supported
(II) TDFX(0): VESA VBE DDC Level none
(II) TDFX(0): VESA VBE DDC transfer in appr. 0 sec.
(II) TDFX(0): VESA VBE DDC read failed
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
      [0] 0   0xe8000000 - 0xe9ffffff (0x2000000) MX[B]
      [1] 0   0xe4000000 - 0xe5ffffff (0x2000000) MX[B]
      [2] -1  0xffe00000 - 0xffffffff (0x200000) MX[B](B)
      [3] -1  0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
      [4] -1  0x000f0000 - 0x000fffff (0x10000) MX[B]
      [5] -1  0x000c0000 - 0x000effff (0x30000) MX[B]
      [6] -1  0x00000000 - 0x0009ffff (0xa0000) MX[B]
      [7] -1  0xec000000 - 0xefffffff (0x4000000) MX[B]E
      [8] -1  0xe0000000 - 0xe3ffffff (0x4000000) MX[B]E
      [9] -1  0xe8000000 - 0xe9ffffff (0x2000000) MX[B](B)
      [10] -1 0xe4000000 - 0xe5ffffff (0x2000000) MX[B](B)
      [11] 0  0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
      [12] 0  0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
      [13] 0  0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
      [14] 0  0x00009000 - 0x000090ff (0x100) IX[B]
      [15] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
      [16] -1 0x00000000 - 0x000000ff (0x100) IX[B]
      [17] -1 0x0000c400 - 0x0000c4ff (0x100) IX[B]E
      [18] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B]E
      [19] -1 0x0000bc00 - 0x0000bcff (0x100) IX[B]E
      [20] -1 0x0000b800 - 0x0000b8ff (0x100) IX[B]E
      [21] -1 0x0000b400 - 0x0000b4ff (0x100) IX[B]E
      [22] -1 0x0000b000 - 0x0000b0ff (0x100) IX[B]E
      [23] -1 0x0000ac00 - 0x0000acff (0x100) IX[B]E
      [24] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]E
      [25] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
      [26] -1 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
      [27] -1 0x0000f000 - 0x0000f0ff (0x100) IX[B]E
      [28] -1 0x00009000 - 0x000090ff (0x100) IX[B](B)
      [29] 0  0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
      [30] 0  0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(==) TDFX(0): Write-combining range (0xe8000000,0x2000000)
(II) TDFX(0): Changing back offset from 0x00da7000 to 0x00da6000
(II) TDFX(0): Textures Memory 10.16 MB
(II) TDFX(0): Cursor Offset: [0x00000000,0x00001000)
(II) TDFX(0): Fifo Offset: [0x00001000, 0x00100000)
(II) TDFX(0): Front Buffer Offset: [0x00100000, 0x0037D800)
(II) TDFX(0): Texture Offset: [0x0037D800, 0x00DA6000)
(II) TDFX(0): BackOffset: [0x00DA6000, 0x00ED2000)
(II) TDFX(0): DepthOffset: [0x00ED3000, 0x00FFF000)
(II) TDFX(0): 1567 lines of offscreen memory available for 2D and video
(EE) TDFX(0): [dri] tdfx DRI not supported in 32 bpp mode, disabling DRI.
(II) TDFX(0): [dri] To use DRI, invoke the server using 16 bpp
      (-depth 15 or -depth 16).
(II) TDFX(0): Using XFree86 Acceleration Architecture (XAA)
      Screen to screen bit blits
      Solid filled rectangles
      8x8 mono pattern filled rectangles
      Indirect CPU to Screen color expansion
      Solid Lines
      Dashed Lines
      Offscreen Pixmaps
      Driver provided NonTEGlyphRenderer replacement
      Setting up tile and stipple cache:
            32 128x128 slots
            7 256x256 slots
(==) TDFX(0): Backing store disabled
(==) TDFX(0): Silken mouse enabled
(==) TDFX(0): Direct rendering disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(**) Option "Protocol" "PS/2"
(**) Mouse0: Protocol: "PS/2"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/mouse"
(==) Mouse0: Buttons: 3
(II) Keyboard "Keyboard0" handled by legacy driver
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
Could not init font path element /usr/X11R6/lib/X11/fonts/Speedo/, removing from list!
  • Sihaya
Sihaya
Pasfoto:
Nou zet de laatste waarde steeds iets hoger beginnende bij deze
HorizSync 28-33
VertRefresh 43-72
Dus volgende
28-40
43-75
Doe het niet te snel is toch wel wat minder voor de monitor
Oja maak van "Generic Monitor"
Monitor0
