Post hier je Speed, Temp, FSB, etc...
  • 36 views sinds 30-01-2008
  • dnz
  • Laatst online: 09-09 17:52
Om deze weer ff nieuw leven in te blazen: !!! Post hier je PII, PIII Speed, Temp, FSB,enz
Ik vroeg 't mezelf een beetje af omdat ik verder vrij weinig bevindingen (P4 in mijn geval. AMD uiteraard welkom ;)) kan vinden...
Nu dan een kick off:
Motherboard: Abit TH7ii-raid
Processor: Intel(R) Pentium(R) 4 CPU 1.70GHz
Platform: Socket479 (PGA479 Socket)
Internal Clock: 2056.93 MHz
System Bus: 483.98 MHz QDR
System Clock: 121.00 MHz
Multiplier: 17.0
L2 Cache: 256K Byte
L2 Speed: 2056.93 MHz (Full)
Host Bridge: Intel i850
Memory Clock: 484.00 MHz
Vcore: 1.65 V
OS Version : Windows XP Version 5.01.2600
temp at load: sys;32.0 cpu;42.0
temp idle: sys;30.0 cpu;34.5
  • snars
*zucht*
Selderij 900@1134 (126x9) @ 1.90v
I reject your reality, and substitute my own.
  • Rick2001
  • Laatst online: 09-08 01:10
Rick2001
9950X delidded en direct die
Motherboard: EPOX EP-8KHA+
Processor: AMD Athlon XP 1800+ 1533 @ 1774MHz
Internal clock: 1774MHz
Cooler: SWIFTECH MC462-A rev.1 + Arctic Silver II + Coppershim
Fan on cooler: DELTA FFB0812SHE 68CFM
Case: Antec sx1030bec
Case fans: 4 x DELTA ASB0812HH 38CFM
System bus: 169MHz DDR
System clock: 169MHz DDR
Multiplier: 10.5
L2 Cache: 256K byte
L2 Speed: 1774MHz (Full)
Host Bridge: VIA KT266A
Memory clock: 169MHz DDR
Vcore: 2.02 V
OS Version: Windows XP Professional Version 5.01.2600
Temp at load: sys; 23 cpu;38
Temp at idle: sys; 22 cpu;24
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
zie Extra info onderaan :7
:Z
  • Barreljan
  • Laatst online: 04-09 16:52
Barreljan
...Zoom-Zoom...
nou hiero dan
Motherboard: Aopen MX6B-EZ Pro
Processor: Intel(R) Pentium(R) 3 CPU 550MHz
Platform: Slot1
Internal Clock: 549,9 MHz
System Bus: 110 MHz
System Clock: 110.00 MHz
Multiplier: 5.0
L2 Cache: 512K Byte
L2 Speed: 549 MHz (Full)
Host Bridge: Intel 440bx/zx
Memory Clock: 143.00 MHz + 110Mhz
Vcore: 1.99 V
OS Version : Windows 98
temp at load: cpu; 29/30
temp idle: cpu; 21.0
(beetje jouw schema bijgewerkt naar mijn systeem :))
Time Attacker met de Mazda 323F 2.5 V6 J-spec | PV output
  • BrZ
  • Laatst online: 09-09 08:15
BrZ
Motherboard: Tyan Tiger MP (S2460)
Processor: 2x AMD Athlon (Thunderbird) 1333 @ 1420MHz
Coolers: 2x Alpha PAL6035MFC + Arctic Silver II
Fan on coolers: 2x Delta AFB0612EH ("60HP")
Case: Chieftec DA-01-DB
Case fans: 5 x Sunon 80mm + 1x Sunon 92mm
System bus: 142MHz DDR
Multiplier: 10
Host Bridge: AMD 760MP (northbridge is dus de AMD762)
Memory clock: 142MHz DDR
Vcore: 1.75 V
Temp at load: cpu's: 43 en 46 graden
Temp at idle: nog nooit getest :P
Maarruh... beetje loos opsomtopic :P
  • Thyzz
  • Laatst online: 07-09 14:45
Thyzz
-=leeg=-
Processor: AMD Athlon XP 1600+ 1400 @ 1470MHz
Internal clock: 1470MHz
Case: Aopen HQ45 pro (300watt)
System bus: 140MHz DDR
System clock: 140MHz DDR
Multiplier: 10.5
L2 Cache: 256K byte
L2 Speed: 1470MHz (Full)
Memory clock: 140MHz DDR
Vcore: 1.85 V
Temp at load: sys; 25 cpu;48
Temp at idle: sys; 22 cpu;40
5325wp
Opsomtopic :Z :Z :Z
  • floduR
Als jet niet leuk vind zo'n topic, zeg dan niets...
zie spec...
1400 --> 48 °C stressed Vcore 1.75v
1522 --> 58 °C stressed Vcore 1.85v
1533 --> (onstabiel) 62 °C Vcore 1.85v
redelijk... :)
ik wil niet vervelend zijn ofzo maar wat is hier t nut van?
tis idd een opsom-topic
:Z :Z :Z :Z :Z
  • The_Greater
  • Laatst online: 12-09 22:13
Motherboard: Asus A7V
Processor: AMD 1200 @ 1365
Platform:
System Clock: 105.00 MHz
Multiplier: 13.0
L2 Cache: 256K Byte
Memory Clock: 140.00 MHz
Vcore: 1.85 V
temp at load: sys;33.0 cpu;44.0
temp idle: sys;29.0 cpu;38
Working in the IT : "When you do things right, people won't be sure you've done anything at all"
Motherboard: Abit KT7A
Processor: AMD Athlon Thunderbird 1000Mhz 200FSB
Platform: Socket462 (socket A)
Internal Clock: 1456.42 Mhz
System Bus: 277.41 MHz DDR
System Clock: 138.71 MHz
Multiplier: 10.5
L2 Cache: 256K Byte
L2 Speed: 1456.42 Mhz (Full)
Host Bridge: VIA Apollo KT133A
Memory Clock: 138.71 MHz
Vcore: 1.88 V
OS Version : Windows 2000 SP 2
temp at load: sys 28.0 cpu 47.0
temp idle: sys 25.0 cpu 29.0
Motherboard: Epox KP6-BS
Processor #1: Intel(R) Pentium(R) 3 CPU 515MHz
Processor #2: Intel(R) Pentium(R) 3 CPU 515MHz
Platform : Slot 1 (SC242 Connector)
Internal Clock: 515.55 MHz
System Bus: 103.11 MHz QDR
System Clock: 103.11MHz
Multiplier: 5.0
L2 Cache: 512K Byte (2x)
L2 Speed: 257.77 MHz (Half)
Host Bridge: 8086:7190.03 [Intel 440BX/ZX/DX]
Memory Size : 448M Byte
Memory Clock: 103.11 MHz
Vcore: 2.00 V
OS Version : Windows 2000 Version 5.00.2195
temp at load: sys;23.0 cpu;31.0
temp idle: sys;22.0 cpu;22.5
typo's :D
  • Stropdas
  • Laatst online: 04-09 16:22
Stropdas
Insert subtitle here
Mobo: ECS K7S5A
CPU: Duron800@800
FSB: 100MHz
MP: 8
Vcore: 2,15
Stressed: 47graden
Honda VFR800fi '99 | Volvo S60 '04
  • BrZ
BrZ
Op dinsdag 25 december 2001 21:49 schreef Stropdas het volgende:
CPU: Duron800@800
Vcore: 2,15
Heu? ikke niet snappen :?
  • Stropdas
Stropdas
Op dinsdag 25 december 2001 21:54 schreef BrZ het volgende:
En ikke laten inbranden :) Is nieuwe CPU 8-)
alweer een van de kijk mijn PC is sneller dan die van jouw.
:Z :Z :Z
post een andere topic ffs.
ik zal het beginnen.
mijn pik is groter dan die van jouw
post hier je lengte :)
zacht:-
hard:-
is net zo dumb als deze topic net hetzelfde als de andere 1.000.000 van hetzelfde :)
:7
  • Stropdas
Stropdas
Op dinsdag 25 december 2001 21:58 schreef Ev!L-c het volgende:
:Z :Z :Z
zacht:-
hard:-
:7
Dat was in de huiskamer laatst, gebruik eerst de search voordat je een topic aan maakt terwijl die er al is ;)
Motherboard: MSI MS-6199 VIA Apollo Pro 133
Processor: Intel(R) Celeron(R) 600 @ 705
Platform: Socket370 (PGA370 Socket)
Internal Clock: 705 MHz
System Bus: 78.00 MHz
System Clock: 78.00 MHz
Multiplier: 9.0
L2 Cache: 128K Byte
L2 Speed: 705 MHz (Full)
Host Bridge: VIA Apollo Pro 133
Memory Clock: 78.00 MHz
Vcore: 1.60 V
  • Dirk J
  • Laatst online: 22-07 22:22
Okee, daar gaan we dan...
Motherboard: ECS K7S5A
Processor: AMD Athlon (Model 4)
Platform: Socket A (Socket 462)
Internal Clock: 1099.89 MHz
System Bus: 293.30 MHz DDR
System Clock: 146.65 MHz
Multiplier: 7.5
L2 Cache: 256K Byte
L2 Speed: 1099.89 MHz
Host Bridge: SiS 735
Memory Clock: 293.30 MHz
Vcore: 1.81 V
Temp at load: Sys;27.0 Cpu;47.0
Temp idle: :? Wat is dat ( }:O )
ik voorspel dat dit opsom-topic binnenkort dicht gaat...
  • dnz
/* hallo we zitten hier bij GOT.
ik meen dat dit staat voor gathering of tweakers.
je ben een tweaker of niet.
de bedoeling voor een tweaker is om 't maximale uit z'n systeem te halen.
ik zocht enkel vergelijking materiaal met name voor de p4 (os-temp-enz), en niet om iemand verbaal de grond in te stampen. heb hier je bij je voordeel van zo'n lijst post dan je gegevens, en als je verder niets te relevants te melden hebt dan niet.*/
  • Speedy-J
  • Laatst online: 27-08 07:36
Speedy-J
AMD Enthusiast
Dit is er ook eentje van de vele,dus gaat ook dicht zodra er een Ops langskomt :)
Ryzen 7 5800@4.7GHz|Asus prime X570 pro|16GB G-Skill trident z rgb|Gigabyte rtx 2070 super|Custom WC van EK|chietech dragon|Corsair 750w rm x
  • Daan
  • Laatst online: 23:59
Idd, hij gaat dicht, dit is een opsomtopic.
Voor de rest ook nog in het verkeerde forum enzo :)
