Hai, ik heb een probleem met OpenGL met alle spellen die van dezelfde console gebruik maken als het spel ST Elite Force. De output is als volgt:
Uiteraard heb ik gezocht in de search..ST:V EF v0.28 win-x86 Aug 17 2000
----- FS_Startup -----
Current search path:
E:\Star Trek Voyager Elite Force\baseef\pak0.pk3 (19069 files)
E:\Star Trek Voyager Elite Force/baseef
execing default.cfg
execing efconfig.cfg
couldn't exec autoexec.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
------- Force Feedback Initialization -------
...inhibited, not initializing
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: E:\Star Trek Voyager Elite Force
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
I don't have a solution; but I do admire the problem.
