ik heb ondestaand systeem inelkaargezet maar openGLdoethetniet op mjin matrox
BBij windows screensavers krijg ik ene zwart scherm (3d flowerbox) of springt ie terug naar desktop (3d pipes)
bij return to castle wolfenstein mp demo 1.1 krijg ik deze fout bij het opstarten:
ECS K7S5A LAN rev 3 sis 735
AMD Athlon XP 1700+ (1,47GHz)
VIKING 256MB DDR-RAM/266, PC2100
Millennium G550 Enhanced
Lite on LTR-16101B 40/16/10 IDE Retail
IBM IC 35L060 60GB 8 ms 7.200 2mbCache
Creative Labs SB Audigy Player
Floppy 3,5" 1,44MB
AOpen Miditower ATX, 300Watt (Hx45a)
Coolermaster EP5-6I11
Microsoft Intelli Optical 1.1
Microsoft Internet Keyboard
Iiyama MF901U Vision Master 452 19"
iemand die mij kan helpen of uitleggen waar het aan ligt? (matrox technical support werkt niet in het weekend)Wolf 1.1 win-x86 Dec 17 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Return to Castle Wolfenstein Multiplayer DEMO/main
0 files in pk3 files
Running in restricted demo mode.
C:\Program Files\Return to Castle Wolfenstein Multiplayer DEMO\demomain\pak0.pk3 (1846 files)
C:\Program Files\Return to Castle Wolfenstein Multiplayer DEMO/demomain
1846 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig_mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
Loaded 714 translation strings from scripts/translation.cfg
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...31 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: failed
...failed hard
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...releasing DC: failed
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Q_strncpyz: NULL src
Floppy 3,5" 1,44MB
Human Bobby
