I've just put together a new system, and the first it started up perfectly. The only problem was that I had to adjust the cpu from 100 to 133 MHz, which I did. I also changed the SDRAM freq. from SPD to HCLK, as pc2100 supports 133 MHZ. When I restarted the system jammed with a black screen en the leds R-G-R-R. Indecating a memory problem. I cleared CMOS with the JBAT1 jumper a few times and i tried al the DDR banks on my MB. I also made sure that the DIMM was enterd correctly and solid. Unfortunately still the same problem arises.
Who has the awnser??
_______________
K7T266 pro2 RU
AMD XP 1600+
Spire 5E34B3 socketA cooler.
512 DDR pc2100
Asus Gforce3 8200Ti200 64Mb Deluxe
Maxtor IDE 40Gb HD 7200 rpm
Lite-on DVD 16x48
Samsung CDR 8x4x32
Aopen HX48A 300w miditower
Deze post is in het engels geschreven omdat hij op meerdere forums tegelijk wordt geplaatst.
_______________
K7T266 pro2 RU
AMD XP 1600+
512 DDR pc2100
Lite-on DVD 16x48
Samsung CDR 8x4x32
