VNC in STEALTH
  • 60 views sinds 30-01-2008
Is het mogelijk om vnc onder w98 in stealth mode te late draaien? Dus dat men het pictogrammetje niet rechts onderin de systray ziet staan?
Zo ja, Hoe?
<edit>
Search al gebruikt.
</edit>
Nee, dit is OPZETTELIJK zo gedaan door de programmeurs.
Aangezien het programma open source is, sloop zelf maar het gedeelte eruit voor het "display icon on systray"
Veel plezier.
  • Koffie
  • Laatst online: 21-08 15:02
Koffie
Koffiebierbrouwer
Braaimeneer
Search gebruikt :? ik vond hem direct.
anyway:
Uit de VNC FAQ:
Q46 Can I get rid of the taskbar icon created by WinVNC?
No. Not without changing and recompiling the source code. We feel that there would be few legitimate uses of VNC where you would need to conceal its operation. However, there might be occasions where you would not want the user of the server machine to be able to adjust the WinVNC settings, password, etc, so versions later than 3.3.2R3 include a 'restricted' mode where the icon is still visible, but the menu options normally available from it will be disabled. See WinVNC - Advanced Settings in WinVNC docs for the details.
In some situations, particularly on Win95, you may find that the icon is not displayed. This is not a feature, it's a bug which we plan to iron out! See the question above on 'I ran WinVNC don't see an icon in my Taskbar!'.
[search=vnc hidden]
Braaikamer - Smoke&BBQ
