[SuSE72] Dhcpclient veroorzaakt flinke logs
  • EWS99
  • Laatst online: 07:20
stukje uit mijn /var/log/messages:
Dec 20 18:25:03 router last message repeated 3 times
Dec 20 18:25:05 router dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Dec 20 18:25:05 router dhclient: DHCPOFFER from 62.163.x.x
Dec 20 18:25:09 router dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Dec 20 18:25:10 router dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Dec 20 18:25:12 router dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Dec 20 18:25:12 router dhclient: DHCPOFFER from 62.163.x.x
Dec 20 18:25:15 router dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Dec 20 18:25:19 router last message repeated 2 times
Dec 20 18:25:21 router dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Dec 20 18:25:21 router dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Dec 20 18:25:21 router dhclient: DHCPOFFER from 62.163.x.x
Het gaat hierbij om SuSE 7.2 op Chello kabelinternet, met de dhcplient dhclient.
/etc/dhclient.conf:
supersede domain-name "ews99 arnhem.chello.nl";
prepend domain-name-servers 192.168.0.1;
send dhcp-lease-time 3600;
request subnet-mask, broadcast-address, time-offset, routers, domain-name, domain-name-servers, host-name;
require subnet-mask, domain-name-servers;
timeout 60;
retry 60;
reboot 10;
select-timeout 5;
initial-interval 2;
script "/sbin/dhclient-script";
Iemand enig idee wat hier aan de hand is? Iets in de config dat niet goed staat?
Hier had uw advertentie kunnen staan!
  • Mujo
  • Laatst online: 23-08-2021
Mujo
Nee hè?
Is dit misschien iets dat je kan helpen? :?
http://mail-index.netbsd.org/tech-net/1999/12/06/0000.html
Deze rept ook over een dhcpoffer melding:
http://www.foldr.org/~michaelw/wireless.html
Nog wat url's die misschien handy kunnen zijn:
http://lists.suse.com/archive/suse-security/2000-Aug/0417.html
http://www.monkey.org/openbsd/archive/misc/0012/msg00698.html
Again: kweet niet OF je er wat aan hebt... Mijn eerste guess
is dat er een rule verkeerd staat in je firewalling/routing script... :?
Gelieve niet te roken in mijn kantoorkamer!
Ik ben meer verslaafd aan sex, dan jij aan roken, maar je ziet mij toch ook niet neuken op kantoor?
  • EWS99
hmm, dit is mijn routing script
root@router:/etc/init.d > cat rciptable
#! /bin/sh
modprobe iptable_nat
iptables -F FORWARD
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
echo 1 > /proc/sys/net/ipv4/ip_forward
  • EWS99
dit mis ik dus in mijn logs:
host dhclient: bound to x.x.x.x -- renewal in 3600 seconds.
D'r is dus toch iets niet helemaal lekker
Op donderdag 20 december 2001 20:12 schreef hardrocker het volgende:
Ik heb wel een vermoeden.. Als je een andere netwerk kaart gebruikt dan die waar je het laatst mee op chello hebt aangelogged dan komt het door de dhcp lease..
  • EWS99
nope, ik heb nooit een andere netwerkkaart gebruikt. Ik ben bekent met dat probleem, en dus zorg er goed voor dat ik steeds de juiste NIC blijf gebruiken.
Maar ik krijg wel gewoon een IP van de dhcpserver, en alles loopt.
  • EWS99
nobody knows :(
  • eek
  • Laatst online: 06-04-2020
eek
@MagickNET
humor
ik heb alleen
reboot 10
in /etc/dhclient.conf staan
en het werkt netjes
Skill is when luck becomes a habit.
  • EWS99
Op vrijdag 21 december 2001 20:56 schreef _eek_ het volgende:
humor
ik heb alleen
reboot 10
en het werkt netjes
Serieus? Dan gaat ik dat ook eens proberen :P
  • EWS99
kick :P
