als ik mijn dirsize.bat intik, wil ik de directory size in Mb's echoen van c:\backup
hoe doe ik dit in batch
[ Voor 91% gewijzigd door Engineer op 14-10-2018 09:36 ]
Op donderdag 20 december 2001 13:12 schreef lisson01 het volgende:
tuurlijk wel
Music is the pleasure the human mind experiences from counting without being aware that it is counting
~ Gottfried Leibniz
29
30
31
32
33
34
35
| DIRUSE displays a list of disk usage for a directory tree(s).
Version 1.20
DIRUSE [/S | /V] [/M | /K | /B] [/C] [/,] [/Q:# [/L] [/A] [/D]
[/O]] [/*] DIRS
/S Specifies whether subdirectories are included in the output.
/V Output progress reports while scanning subdirectories.
Ignored if /S is specified.
/M Displays disk usage in megabytes.
/K Displays disk usage in kilobytes.
/B Displays disk usage in bytes (default).
/C Use Compressed size instead of apparent size.
/, Use thousand separator when displaying sizes.
/L Output overflows to logfile .\DIRUSE.LOG.
/* Uses the top-level directories residing in the specified DIRS
/Q:# Mark directories that exceed the specified size (#) with a "!".
(If /M or /K is not specified, then bytes is assumed.)
/A Specifies that an alert is generated if specified sizes are
exceeded.
(The Alerter service must be running.)
/D Displays only directories that exceed specified sizes.
/O Specifies that subdirectories are not checked for specified size
overflow.
DIRS Specifies a list of the paths to check.
Note: Parameters can be typed in any order. And the '-' symbol
can be
used in place of the '/' symbol.
Also, if /Q is specified, then return code is ONE
if any directories are found that
exceed the specified sizes. Otherwise the return code is ZERO.
Example: diruse /s /m /q:1.5 /l /* c:\users |
