ooit komt er een einde aan het eind
Q1: How does a Workstation board differ from a game board?
A1:
When you compare the FIRE GL 8700 workstation product to a high-end 3D game card the requirements and differences are substantial. For example, Workstation boards are used to create the models/environments you see in your games while game cards are designed to play the game.
While game requirements are focused on high frame rates Play-It, the workstation product needs to address the problems of working with very advanced & complex applications that simultaneously run in wire-frame and shaded mode with numerous windows and menus being opened or closed Create-It. Listed below are the some of the major differences:
Optimized For Superior OpenGL Performance
ISV Certification for greater Application Stability & Reliability
Application Customization for End User--ease of use
OpenGL Extensions
Dedicated team of workstation support & development engineers
Q5: Are the FIRE GL 8800 and FIRE GL 8700 only designed to take advantage of Open GL®?
A5:
No, both the FIRE GL 8800 and FIRE GL 8700 provide full support for DirectX® 8.1. Other graphic manufactures may only offer one solution that provides OpenGL®, but no DirectX® support for workstation customers. ATI's solution is to provide our customers with one product that fully supports and accelerates both OpenGL® and DirectX® 8.1 applications.
A1:
OpenGL Extensions
A5:
Volgens is dit een renderkaartje, alleen interessant als je aan 3d modellen ofzo doet.. met maya, 3d max etc.
Anders is het weggegooid geld.
Als je die 8700 duidelijk goedkoper kan krijgen dan de 8500, dan zeker voor de 8700 gaan; zijn toch dezelfde kaarten (like GeForce = Quadro), althans dat meen ik bijna zeker te weten.
