CS 1.3 dedicated starten
  • Multispeed
  • Laatst online: 26-06 22:46
Multispeed
HEY! Dat ben ik!
[topic=230706/1/25]
hier stond een link in naar de CS server page om srever files etc te downen
maar das voor 1.1 of kan ik die tools ook voor 1.3 gebruiken
ik praat hier over
The TSC team has now come out with a new version that catches them all. :D Here's the changelog.
- Systen Shock Algorithm -- New Anti-Cheat System (OGC, H1H, etc)
- Fixed blood issue
- Hopefully fixed team selection bug
- Removed starting screen clear commands
- Added command "lasertoggle" which may be bound to toggle your lasersight
- Added cvar "tsc_shoveit" which toggles the verbosity of tsc
- Blood decals have more variety
- Many szGetspace overflow errors have been eliminated
- Server restarting on windows server implemented with *phoenix* by amatus
- Cheater disconnect message hold time increased
- Added special effects to disconnected cheaters (lightning, explosion, earthquake)
- Setting tsc_nervegas 2 will make sg's into tear gas
- NVG's are enhanced (tsc_nvg toggles)
- Logging greatly improved, includes time, won, reason, etc
- Grenades can be kicked about (tsc_gkick toggles)
- Ghost players may be seen by other ghosts (tsc_ghost toggles)
- Lightning and explosions have a wonderful small groundshaking effect
- SG's can be turned into teargas now (tsc_nervegas 2)
- Gun and Blood splashes now work for all guns, original physics also improved-- they have also been unlagged.
- Rainmaker system allows individual map-based weather conditions
- All the programs settings are unified in one file, tsc.ini.
- Laser sites are less visible to other players.
- Blah Blah Blah, lots of things have been added or improved that I forgot about,
but that you will run into and find when you get there.
- Miscelanious tweaks and bugfixes.
You can download the file here, or a mirror here.
En toevallig vind ik dus van niet! :-)
  • Multispeed
Multispeed
HEY! Dat ben ik!
ik wilk dus een cs server starten zonder in het spel te hoefen en dedicated aan te vinken etc.
gewoon net als servarena voor quake3
of met een batch file voor quake2
is dat mogelijk ??
  • Vos
  • Laatst online: 19:59
Vos
AFCA
hlds.exe
#36
  • KeRsTmAnNeKe
  • Laatst online: 30-10 17:22
Heb je iig niet TSC nodig, dat zijn extras en werkt ook anti cheat :)
draai je een windows server dan heb je deze nodig:
http://personalserver.fileplanet.com/redir.asp?from=PHLRUX&to=http%3A//www.fileplanet.com/index.asp%3Ffile%3D59236
draai je linux dit:
http://personalserver.fileplanet.com/redir.asp?from=PHLRUX&to=http%3A//www.fileplanet.com/index.asp%3Ffile%3D58368
en dan nog CS1.3:
win: http://www.counter-strike.net/mod_full.html
linux: http://www.counter-strike.net/linux_full.html
ALs je die installeerd ben je al een heel eind verder...
server settings staan in server.cfg en wil je extra dingen dan kan je nog adminmod installeren www.adminmod.org
