alsa driver compileren
als ik de alsa drivers probeer te compileren krijg ik de volgende foutmelding:
debian:/home/ultimate/alsa-driver-0.9.0beta9# make
make[1]: Entering directory `/home/ultimate/alsa-driver-0.9.0beta9/support'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/ultimate/alsa-driver-0.9.0beta9/support'
make[1]: Entering directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel'
make[2]: Entering directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel/oss'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel/oss'
make[2]: Entering directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel/seq'
gcc -DALSA_BUILD -D__KERNEL__ -O2 -mpreferred-stack-boundary=2 -march=i686 -DLINUX -Wall -Wstrict-prototypes -fomit-frame-pointer -pipe -I/usr/src/kernel-source-2.2.19/include -I../.. -DEXPORT_SYMTAB -c seq.c
In file included from seq_clientmgr.h:26,
from seq.c:27:
seq_ports.h:54: field `list_mutex' has incomplete type
{standard input}: Assembler messages:
{standard input}:9: Warning: ignoring changed section attributes for .modinfo
make[2]: *** [seq.o] Error 1
make[2]: Leaving directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel/seq'
make[1]: *** [all] Error 1
make[1]: Leaving directory `/home/ultimate/alsa-driver-0.9.0beta9/kernel'
make: *** [compile] Error 1
imand enig idee?
  • Tomaat
  • Laatst online: 13-05 13:50
Wordt de driver wel goed mee gecompiled, of kapt ie er halve wege mee?
geen idee ik heb het volgende gedaan:
downloaden
uipakken
cd alsa-driver-0.9.0beta9
./configure --with-kernel=/usr/src/kernel-source-2.2.19
en dan krijg ik het volgende:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
debian:/home/ultimate/alsa-driver-0.9.0beta9# ./configure --with-kernel=/usr/src/kernel-source-2.2.19
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for linux/fs.h... (cached) yes
checking for working const... (cached) yes
checking for inline... (cached) inline
checking whether time.h and sys/time.h may both be included... (cached) yes
checking whether gcc needs -traditional... (cached) no
checking for current directory... /home/ultimate/alsa-driver-0.9.0beta9
checking for directory with kernel source... /usr/src/kernel-source-2.2.19
checking for kernel version... 2.2.19
checking for kernel module symbol versions... yes
checking for PCI support in kernel... yes
checking for SGI/MIPS (HAL2) architecture... no
checking for directory to store kernel modules... /lib/modules/2.2.19/misc
checking for debug level... none
checking for processor type... i686
checking for SMP... no
checking for ISA PnP driver in kernel... no
checking for ISA PnP support... yes
checking for old kill_fasync... yes
checking for dma_addr_t... yes
checking for MUTEX macros... yes
checking for driver version... 0.9.0beta9
checking for sequencer support... yes
checking for OSS/Free emulation... yes
checking for RTC callback support in kernel... no
checking for which soundcards to compile driver for... all
creating ./config.status
creating version
creating Makefile.conf
creating snddevices
creating utils/alsa-driver.spec
creating cards.config
creating include/config.h
include/config.h is unchanged
creating include/config1.h
include/config1.h is unchanged
creating include/version.h
include/version.h is unchanged
vervolgens doe ik make en dan krijg ik de eerste foutmelding te zien.
  • LightYears
  • Laatst online: 14-03-2024
LightYears
wilt geen iPod
beta10 is uit, probeer die eens, probeer anders eens te compilen met de stable alsa (0.5)
EAC > Ogg vorbis -q6 > Cowon S9 > Westone ES3X > Oor
make[2]: Leaving directory `/usr/src/modules/alsa-driver/kernel/seq'
make[1]: Leaving directory `/usr/src/modules/alsa-driver/kernel'
dit krijg ik als ik de 0.5 versie probeer
oplossing is vrij simpel:
inplaats van make moet je make install doen dit staat in de bijgeleverde INSTALL file en anders op de website
