Met PHP 4.10 en nieuwer zullen Register_globals en errorreporting uitstaan. Dit is een ramp als je oude projecten ervan uitgaan dat deze twee zaken aanstaan (vooral Register_globals). (Natuurlijk heeft de nieuwe setting zijn voordelen, maar ga maar eens 20 production sites omzetten...
Welke manieren zijn er om Runtime toch register_globals aan te zetten en ook error_reporting aan te zetten?; - register_globals = Off [Security, Performance]
; Global variables are no longer registered for input data (POST, GET, cookies,
; environment and other server variables). Instead of using $foo, you must use
; you can use $_REQUEST["foo"] (includes any variable that arrives through the
; request, namely, POST, GET and cookie variables), or use one of the specific
; $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
; on where the input originates. Also, you can look at the
; import_request_variables() function.
; Note that register_globals is going to be depracated (i.e., turned off by
; default) in the next version of PHP, because it often leads to security bugs.
; Read http://php.net/manual/en/security.registerglobals.php for further
; information.
; - display_errors = Off [Security]
; With this directive set to off, errors that occur during the execution of
; scripts will no longer be displayed as a part of the script output, and thus,
; will no longer be exposed to remote users. With some errors, the error message
; content may expose information about your script, web server, or database
; server that may be exploitable for hacking. Production sites should have this
; directive set to off.
