• l.d._
  • Laatst online: 03-08 23:47
Tja heb hier in huis nu zo'n 6 verschillende AB's en die pokke dingen hebben allemaal een andere indeling en ijn altijd zoek ;(
dus * l.d._ ging op zoek.
en wat vind ik
Afbeeldingslocatie: http://www.remotecentral.com/mx500/photo1.jpg
dat is nog eens een AB :P :9~ :9
Home Theater Master MX-500 Features:
Controls 10 devices: Default device names include AUDIO, CD, DVD, TAPE, AUX, TV, VCR1, VCR2, SAT and CABLE, although the remote is capable of controlling any number of these.
All hard buttons: The MX-500 includes a total of 50 hard buttons, 43 of which are user programmable in each device. One hard button is for enabling the backlight, three hard buttons are dedicated to system-wide macros, while a further three are for remote operation.
Menu joystick: A fully customizable 5-way "gamepad"-style joystick is provided on the MX-500.
LCD screen: A large 2.3" diagonal LCD screen with dot-matrix labels provides 5-character names for 10 surrounding buttons. Two LCD pages are available for each device, providing a total of 20 LCD hard buttons. The LCD never shuts off - it's always active. LCD contrast levels are adjustable on the fly.
Complete backlighting: The MX-500 features an aqua-colored electroluminescent backlight that covers all hard buttons and the entire LCD screen. Backlight timeout can be configured from 0 (only on when button is pressed) to 99 seconds of inactivity, or disabled completely.
Full learning: The MX-500 can store up to 53 commands for each of its 10 devices - that's 530 learned functions! The applicable frequency range of learnable infrared signals is 10 to 100kHz.
Preprogrammed database: The MX-500 includes a huge database of preprogrammed codes for a wide variety of devices. Devices can be directly entered via 3-digit number or searched. Currently active code numbers can be easily displayed.
Editable LCD labels: Each of the 10 devices can feature a customizable 5-character name. In addition, 20 LCD-adjacent buttons for each device can also have 5-character names.
5 system macros: The MX-500 features three dedicated 20-step system macros which are available no matter what device is active; a further two system macros can be placed on the [SYSTEM OFF] and [POWER] buttons if desired.
10 device macros: Each device can have a 20-step macro assigned to it which is transmitted when the button is held for 2-seconds. Alternatively (and in combination) a single learned signal can also be attached.
50 favorite channel macros: Accessed from a dedicated [FAV] button, five LCD screens worth of buttons can each hold 10-step macros which reference a device's keypad.
Punchthroughs: Volume, channel or transport commands can be individually "punched through" on a specific device basis.
Menu driven interface: Unlike most hard buttoned remotes, all configuration changes are intuitively made through the LCD screen.
Reset configuration changes: The MX-500 allows you to delete learned signals or macros on a single, device or entire remote basis. In addition, the remote is easily reset to factory default.
Clone remotes: One MX-500 can be wirelessly cloned to another in about 40 seconds.
Strong IR transmission: Two powerful IR emitters enable the MX-500 to outshine the IR range and spread of almost all original remote controls.
Memory lock: The MX-500 won't lose your configuration when it is left without power for an extended amount of time.
Low battery warning: When battery levels are low, the MX-500 will display a "LOW BATTERY" message each time the [POWER] button is pressed or the Setup Menu is accessed.
weer wat voor op het verlang lijstje >:)
als je niks te doen hebt doe het dan niet hier
  • Sick Nick
Sick Nick
Drop the top!
Het ding van onze TV heeft meer knopjes en is ook bruikbaar voor andere apparatuur, dus laat maar hangen ;)
  • Hyperbird
En wat mag dat kosten?
Wel een geinig ding :) alleen niet zo mooi.
Ik heb sinds kort deze
Afbeeldingslocatie: http://www.remotecentral.com/uc525/photo01a.jpg
bevalt erg goed en maar $90,-
Die kan je toch zelf voorprogrammeren?
  • seq_uence
  • Laatst online: 30-10 08:08
Die laatste is veel mooier !
Donec eris felix, multos numerabis amicos
  • l.d._
Op zondag 16 december 2001 01:44 schreef ron.bouwens het volgende:
ziet er ook leuk uit.
ik doe alleen een heleboel op de tast (geen zin om naar de AB te kijken) en dan zijn harde knoppen net wat makkelijker te vinden.
Hier een lading AB's om te vergelijken
  • Flox
  • Laatst online: 14-04 20:57
volgens mij moet het ook mogelijk zoiets te creeren met een pda (is wel iets duurder natuurlijk) maar in mijn geval een ipaq. pocketremote installeren en de verschillende afstandsbedieningen die je hebt voor tv, versterker, cd, lampen etc. kun je dan in je pda programmeren en voila...
Earth is nice, heaven is better...
Ik heb al 3 jaar deze.
http://www.sony-europe.com/view.x?prod=18956&loc=eu
Werkt heel fijn (is een beetje groot ok).
Zit een leerfunctie op en 3 heel erg makkelijke programmeerbare knopjes waardoor je een serie handelingen in 1 keer kunt uitvoeren. Is wel makkelijk met zappen :)
  • Dethroned
  • Laatst online: 10-10 16:09
Dethroned
Liev
Beter neem je eentje met Touchscreen omdat dus net ff wat luxer is. Je gaat natuurlijk niet die eerste pauper RC, als je een nieuwe koopt, koop dan een goede.
Die Sony is wel relaxed. Hij kan al mijn Sony app aan (duh) maar ook mijn Denon versterker en cd-spieler en mijn technics afgedankte rotzooi en nog veel meer.
I got a problem-solver and its name is revolver
  • Solosmots
  • Laatst online: 31-10 09:08
Dis pas een zapper, die veegt al die wannabe-dingen van tafel:
Afbeeldingslocatie: http://www.remotecentral.com/ces2001/prontopro/photo5a.jpg
Voor weinig....dat niet, maar goed..
  • Hyperbird
Op zondag 16 december 2001 17:33 schreef Solosmots het volgende:
Das dus echt voor mensen die alles hebben en totaal niet meer weten wat ze moeten kopen, echt onzinnig in mijn ogen, vooral voor die 1000 gulden.
Maakt em natuurlijk niet minder cool :7
  • sigma01
  • Laatst online: 09-04 11:55
hmmm Die pronto lijkt veel op een pocket pc. Geen ideetje voor die lui van Philips om een pocket pc met ingebouwde afstandsbediening te maken? Ze kunnen alle onderdelen al zelf maken (ja ik weet van de nino af).
P3 667 Mhz, 384MB ram, 20GB maxtor+60GB IBM (60GXP), Matrox G400 dh, asus mobo, Philips 109b10 + Philips 17B
Ik heb deze :
Afbeeldingslocatie: http://www.remotecentral.com/ucommand/photo1a.jpg
Ik gebruik hem eigenlijk nooit. Hij werkt wel perfect maar ik ben nooit thuis >:)
[edit]
info over deze AB is te vinden op http://www.remotecentral.com/ucommand/index.html
  • Solosmots
Op zondag 16 december 2001 18:27 schreef Hyperbird het volgende:
1000 piek???? >:)
Was het maar zo, hij is $999, ja $ ja.... :'(
  • Solosmots
OOOPZ, dubbelpost
  • Bierkameel
Bierkameel
I use Debian btw
Afbeeldingslocatie: http://www.remotecentral.com/weemote/photo1a.jpg
Lijkt je dit nix :?
Alle proemn in n drek
  • Fakir
  • Laatst online: 05:03
Ik heb een Philips Pronto en die bevalt perfect. NB als je daarvoor gaat dan kan ik je verklappen dat de 1mb versie meer dan zat is, krijg je niet vol.
  • Acolyte57
  • Laatst online: 21-01 23:41
Acolyte57
Omnia Mutantur, Nihil Interit
Ook mogelijke overweging: Koop een oeroude Palm III of dergelijk stuk oud PDA schroot voor weinig, koop daar een sterkere IR module bij en installeer een remote-control programma. Voila! Programmeerbare RC.
Daarnaast kun je:
- TV Gids synchen zodat je altijd een up to date TV gids hebt
- Favo programmas in de agenda zetten met alarm zodat je nooit meer iets vergeet
- u... Een TV dagboek bijhouden...
okee ik raakte even uit inspiratie maar je snapt wat ik bedoel :)
~/~ 101 little bugs in the file / 101 little bugs / take one out and recompile / 102 little bugs in the file ~/~
  • Solosmots
Op zondag 16 december 2001 23:58 schreef Fakir het volgende:
Enig idee waar je de 'oude' Pronto kan krijgen voor weinig ;) ?
