Linux kernel 2.4.17-rc1
  • 104 views sinds 30-01-2008
Is uit. Dit is de eerste release candidate voor de 2.4.17 kernel. Veel wijzigingen deze keer.
Voor liefhebbers de CHANGELOG
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
Van:Marcelo Tosatti
Datum:Thu, 13 Dec 2001 18:44:16 -0200 (BRST)
Hi,
I've just copied 2.4.17-rc1 to ftp.kernel.org... Its mirroring yet,
probably.
Well, I want people with the "unfreeable" buffer/cache problem to confirm
with me that 2.4.17-rc1 is working ok.
The same change which should fix that problem also should make 2.4 a bit
less "swap happy".
rc1:
- Finish MODULE_LICENSE fixups for fs/nls    (Mark Hymers)
- Console race fix                  (Andrew Morton/Robert Love)
- Configure.help update              (Eric S. Raymond)
- Correctly fix Direct IO bug            (Linus Benedict Torvalds)
- Turn off aacraid debugging              (Alan Cox)
- Added missing spinlocking in do_loopback()    (Alexander Viro)
- Added missing __devexit_p() in i82092
  pcmcia driver                    (Keith Owens)
- ns83820 zerocopy bugfix                (Benjamin LaHaise)
- Fix VM problems where cache/buffers didn't get
  freed                          (me)
pre8:
- ext3 quota fix                      (Neil Brown)
- Add __devexit_p() to ISDN driver        (Kai Germaschewski)
- Declare missing function on fdomain.h    (Eyal Lebedinsky)
- Add Sony Vaio PCG-Z600NE to broken APM
  reporting blacklist                  (Kai Germaschewski)
- ns83820 driver update              (Benjamin LaHaise)
- pas16 driver cleanup                (Alan Cox)
- disable console flush on secondary CPUs on
  IA64                          (Andrew Morton)
- fix typo on parport's ChangeLog          (Tim Waugh)
- fix use count for multiple queued requests on
  closed fd                      (Douglas Gilbert)
- Check return value of get_user() on
  set_vesa_blanking                  (Jeff Garzik)
- Remove asm/segment.h include from nbd    (Jeff Garzik)
- Guard sysrq.h against multiple inclusion  (Jeff Garzik)
- Minor PCI skeleton changes              (Jeff Garzik)
- Add via rhine MMIO to Configure.help      (Jeff Garzik)
- Jeff Garzik is not the via82cxxx driver
  maintainer anymore: "No time, no hardware".   (Jeff Garzik)
- Remove old tulip documentation            (Jeff Garzik)
- Avoid direct IO's "misunderstanding" of which
  block device it should use              (Masanori Goto)
- Remove mcheck_init() call from processor
  dependant code and put it in unified codepath (Dave Jones)
- Netfilter bugfixes                    (Harald Welte)
pre7:
- More USB updates                  (Greg KH)
- Add missing checks on shmat()          (Christoph Rohland)
- ymfpci update                    (Pete Zaitcev)
- Add aacraid driver                    (Alan Cox)
- Actually apply some of the Alan's changes
  which were on pre6 changelog.          (silly me)
- Clean up t128 SCSI driver            (Alan Cox)
- Clean up dtc SCSI driver              (Alan Cox)
- Undo lcall patch from -pre6            (me)
- More ISDN updates                  (Kai Germaschewski)
pre6:
- ISDN fixes                        (Kai Germaschewski)
- Eicon driver updates                (Kai Germaschewski)
- Fix multithread coredump deadlock      (Manfred Spraul)
- Support /dev/kmem access to vmalloc space     (Marc Boucher)
- ext3 fixes/enhancements                (Andrew Morton)
- Add IT8172G driver to Config.in/Makefile  (Giacomo Catenazzi)
- Create __devexit_p() function and use that on
  drivers which need it to make it possible to
  use newer binutils                    (Keith Owens)
- Make PCMCIA compile without PCI support    (Paul Mackerras)
- Use copy_user_highpage instead copy_highpage
  on COW path.                      (David S. Miller)
- Cacheline align some more performance
  critical spinlocks                    (Anton Blanchard)
- sonypi driver update                (Michael C.B. Ashley/Bob Donnelly)
- direct render for some SiS cards        (Torsten Duwe/Alan Cox)
- full handling of the NFSv3 'jukebox' feature  (Trond Myklebust)
- NFS performance improvements          (Trond Myklebust)
- More parport fixes                    (Tim Waugh)
- Fix lots of core NCR5380 bugs          (Alan Cox)
- NCR5380/PAS driver update            (Alan Cox)
- Add aacraid to the SCSI list          (Alan Cox)
- fdomain driver fixes                (Alan Cox)
pre5:
- 8139too fixes                    (Andreas Dilger)
- sym53c8xx_2 update                    (Gerard Roudier)
- loopback deadlock bugfix              (Jan Kara)
- Yet another devfs update              (Richard Gooch)
- Enable K7 SSE                    (John Clemens)
- Make grab_cache_page return NULL instead
  ERR_PTR: callers expect NULL on failure    (Christoph Hellwig)
- Make ide-{disk-floppy} compile without
  PROCFS support                      (Robert Love)
- Another ymfpci update              (Pete Zaitcev)
- indent NCR5380.{c,h}, g_NCR5380.{c,h}, plus
  NCR5380 fix                        (Alan Cox)
- SPARC32/64 update                  (David S. Miller)
- Fix atyfb warnings                    (David S. Miller)
- Make bootmem init code correctly align
  bootmem data                      (David S. Miller)
- Networking updates                    (David S. Miller)
- Fix scanning luns > 7 on SCSI-3 devices    (Michael Clark)
- Add sparse lun hint for Chaparral G8324
      Fibre-SCSI controller          (Michael Clark)
- Really apply sg changes                (me)
- Parport updates                    (Tim Waugh)
- ReiserFS updates                  (Vladimir V. Saveliev)
- Make AGP code scan all kinds of devices:
  they are not always video ones            (Alan Cox)
- EXPORT_NO_SYMBOLS in floppy.c          (Alan Cox)
- Pentium IV Hyperthreading support      (Alan Cox)
pre4:
- Added missing tcp_diag.c and tcp_diag.h    (me)
pre3:
- Enable ppro errata workaround          (Dave Jones)
- Update tmpfs documentation              (Christoph Rohland)
- Fritz!PCIv2 ISDN card support          (Kai Germaschewski)
- Really apply ymfpci changes            (Pete Zaitcev)
- USB update                        (Greg KH)
- Adds detection of more eepro100 cards    (Troy A. Griffitts)
- Make ftruncate64() compliant with SuS    (Andrew Morton)
- ATI64 fb driver update                (Geert Uytterhoeven)
- Coda fixes                        (Jan Harkes)
- devfs update                      (Richard Gooch)
- Fix ad1848 breakage in -pre2          (Alan Cox)
- Network updates                    (David S. Miller)
- Add cramfs locking                    (Christoph Hellwig)
- Move locking of page_table_lock on expand_stack
  before accessing any vma field            (Manfred Spraul)
- Make time monotonous with gettimeofday      (Andi Kleen)
- Add MODULE_LICENSE(GPL) to ide-tape.c    (Mikael Pettersson)
- Minor cs46xx ioctl fix                (Thomas Woller)
pre2:
- Remove userland header from bonding driver    (David S. Miller)
- Create a SLAB for page tables on i386    (Christoph Hellwig)
- Unregister devices at shaper unload time  (David S. Miller)
- Remove several unused variables from various
  places in the kernel                (David S. Miller)
- Fix slab code to not blindly trust cc_data():
  it may be not valid on some platforms    (David S. Miller)
- Fix RTC driver bug                    (David S. Miller)
- SPARC 32/64 update                    (David S. Miller)
- W9966 V4L driver update                (Jakob Jemi)
- ad1848 driver fixes                  (Alan Cox/Daniel T. Cobra)
- PCMCIA update                    (David Hinds)
- Fix PCMCIA problem with multiple PCI busses   (Paul Mackerras)
- Correctly free per-process signal struct  (Dave McCracken)
- IA64 PAL/signal headers cleanup          (Nathan Myers)
- ymfpci driver cleanup              (Pete Zaitcev)
- Change NLS "licenses" to be "GPL/BSD" instead
  only BSD.                      (Robert Love)
- Fix serial module use count            (Russell King)
- Update sg to 3.1.22                  (Douglas Gilbert)
- ieee1394 update                    (Ben Collins)
- ReiserFS fixes                      (Nikita Danilov)
- Update ACPI documentantion              (Patrick Mochel)
- Smarter atime update                (Andrew Morton)
- Correctly mark ext2 sb as dirty and sync it   (Andrew Morton)
- IrDA update                        (Jean Tourrilhes)
- Count locked buffers at
  balance_dirty_state(): Helps interactivity under
  heavy IO workloads                    (Andrew Morton)
- ide-scsi locking fix                (Christoph Hellwig)
pre1:
- Change USB maintainer              (Greg Kroah-Hartman)
- Speeling fix for rd.c              (From Ralf Baechle's tree)
- Updated URL for bigphysmem patch in v4l docs  (Adrian Bunk)
- Add buggy 440GX to broken pirq blacklist  (Arjan Van de Ven)
- Add new entry to Sound blaster ISAPNP list    (Arjan Van de Ven)
- Remove crap character from Configure.help     (Niels Kristian Bech Jensen)
- Backout erroneous change to lookup_exec_domain (Christoph Hellwig)
- Update osst sound driver to 1.65        (Willem Riede)
- Fix i810 sound driver problems            (Andris Pavenis)
- Add AF_LLC define in network headers      (Arnaldo Carvalho de Melo)
- block_size cleanup on some SCSI drivers    (Erik Andersen)
- Added missing MODULE_LICENSE("GPL") in some   (Andreas Krennmair)
  modules
- Add ->show_options() to super_ops and
  implement NFS method                (Alexander Viro)
- Updated i8k driver                    (Massimo Dal Zoto)
  • Apache
  • Laatst online: 02-09 12:24
Apache
amateur software devver
mooie lijst, misschien gaat het eindelijk terug de goede kant op met de 2.4.x reeks.
Maar jammer genoeg geen support voor de audigy kaarten waar ik persoonlijk toch op zit te wachten :(
If it ain't broken it doesn't have enough features
De policy is gewijzigd. Er is na 2.4.17-pre8 geen nieuwe functionaliteit toegevoegd, slechts bugfixes. Dat heeft geleid tot rc1. En als deze goed is gaat ie (ongewijzigd) door als de stable 2.4.17. Geen rare dingen nog gezien, maar ben net weer 10 minuutjes online :z
