Moet even voor 'n vriendin XFree remote installen. Dat heb ik al 100 keer gedaan en gecompiled.. alleen dit moet even met apt.
Nu wil ik xprt met alle liefde zelf compileren, maar dan klopt het helemaal niet meer.
Wat doe je nou met zoiets?
29
30
31
32
33
| lautje:/home/lautje# apt-get upgrade Reading Package Lists... Done Building Dependency Tree... Done You might want to run `apt-get -f install' to correct these. Sorry, but the following packages have unmet dependencies: x-window-system: Depends: xprt but it is not installed E: Unmet dependencies. Try using -f. lautje:/home/lautje# apt-get -f install Reading Package Lists... Done Building Dependency Tree... Done Correcting dependencies... Done The following extra packages will be installed: xprt The following NEW packages will be installed: xprt 0 packages upgraded, 1 newly installed, 0 to remove and 142 not upgraded. 12 packages not fully installed or removed. Need to get 0B/1114kB of archives. After unpacking 2716kB will be used. Do you want to continue? [Y/n] (Reading database ... 18592 files and directories currently installed.) Unpacking xprt (from .../xprt_4.1.0-11_i386.deb) ... dpkg-deb (subprocess): error reading member data from /var/cache/apt/archives/xp rt_4.1.0-11_i386.deb: Input/output error gzip: stdin: unexpected end of file dpkg-deb: subprocess gzip -dc returned error exit status 1 dpkg: error processing /var/cache/apt/archives/xprt_4.1.0-11_i386.deb (--unpack) : subprocess dpkg-deb --fsys-tarfile (EOF) returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/xprt_4.1.0-11_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1) lautje:/home/lautje# |
