Voor alle RTCW aarsen die niet online konden spele
  • 100 views sinds 30-01-2008
  • eGo2K
  • Laatst online: 01-05 20:12
eGo2K
De vraag .. (zie sig)
Ik quote:
The Q3A master/auth server fell over on Saturday, I went into the office and re-started. When I got up this morning (Sunday), it was down again. It seems an uptime of 200 days straight is a little much on the computer.
I took the opportunity to upgrade the Q3A master/auth code to the same codebase as RTCW this brings up all the anti-piracy measures that have been employed in the RTCW codebase.
So apologies for the downtime, we were on it as soon as possible. The authorize server resorts to "auth all" when it's down, but the internal browser will not work when the master server is down. Any problems beyond that were, of course, your own. :-)
If you get an "invalid_cdkey" message back from a server, that REALLY means that the authorize server has recieved your cdkey, decoded it, and found it to be BAD. Re-entering your cdkey should fix this problem. It does not ever give this message with good cdkeys.
If you get the message "client unknown to auth", this means that the authorize server has yet to hear from you (the player). Make sure you can ping authorize.quake3arena.com (type "ping authorize.quake3arena.com" from a command or ms-dos prompt). If you do not see "192.246.40.56" in the responses, then this is why you're not getting to play.
If you're playing behind a firewall or NAT router, ensure that the ports to the server, and the authorize server are open through your firewall or for your NAT IP address. Refer to your firewall or router manual, there should be a section for games in it. The authorize server runs on port 27952, most servers run on port 27960.
There's a lot of people using the same few cdkeys on Quake 3 right now. These keys will be added to the ban list. If you see "banned cdkey" when you try and connect to a server this is because your cdkey is in general distribution, and while it will not work that way (you will get a cdkey in use error), we do now keep lists of banned keys for both RTCW and Q3A.
Veel plezier!! :D
* eGo2K moet het spel nog kopen!! :( ((geen tijd gehad!!))
... die alle andere vragen overbodig maakt: BIERTJUH?!
hmm die underline bij je naam staat hiervoor?
is idd vrij vervelend
  • eGo2K
eGo2K
lol.. nouja... ik vind het helemaal niet grappig!! :D
k*t 2e Fase ....
:r 2e Fase
  • Mister_X
  • Laatst online: 16-09 11:38
Ik wil er wat bij toevoegen:
ik HAD dit probleem ook! alleen ik gebruikte SYGATE HOME nogwat. toen was ik het bui en heb me server geformateerd en WINNT 4.0 server opgekwakt, en daarbij een domein gemaakt, daarna winroute pro erop, NAT aangezet en HOPPA toen deed ie het!
alleen wel hogere pings nu :(
  • Mister_X
ah, ga naar www.speedguide.net
download die patches en die register shit, voor server als client pc of hoe je ook je lan heb,
en hoppa van een ping van 200 naar gewone 40's 70's :)en dat met Winroute PRO in een domein + NAT
