Ik was op de website van Solarism en zag de specs van online staan:
Panel Type a-Si TFT Active Matrix LCD (16.7 Million colors)
Size 17.0 Viewable (diagonal)
Pixel Pitch .264mm (H) x .264mm (V)
Brightness 700cd/m2
Contrast 400:1 (typical)
Response Time tr:20 ms tf:20 ms
Dimming Range 200:1
View Angle 170o (H) 170o (V)
Frequency Horizontal Rate 64 KHz
Vertical Rate 60 Hz
Maximum Pixel Rate 54 MHz
Resolution Maximum 1280 x 1024 (SXGA)
Controls LCD Panel Controls Contrast, Brightness, Auto Adjust,
Clock, Phase, H-Position, V-Position
Input selections: AV1 / S-Video (AV),
Volume control
Signal Input Analog RGB 0.7p-p 15-pin D-sub
Digital DVI-D 24-pin
Video-in S-Videox1 & RCA Terminal (x1)
Audio-in Earphone jack, RCA Terminal (x1)
Audio Speaker (2w x 2)
Power ON <63W
Dimension Set 450mm (W) x 430mm(H) x 200mm (D)
Weight Net 18 lbs
Tilt/Swivel -10o to 30o
Operating Temperature: 0o C ~ 50o C
Humidity:
Storage Temperature: -20o C ~ 80o C
Humidity: 5% ~ 95%
Certification FCC, CE-B, VCC-I, UL, TUV/GS
Options Bezel Colors Silver/ Black / Beige
Wall mount kit, Mechanical arm extension,
Touch screen
ik weet dat die 15" van Solarism zeer goed was maar is deze dat ook ivm de SGI 1600SW??
wat vinden jullie hiervan? zeker ivm games
ook belangrijk, waar is die te koop in Nederland?
Brightness 700cd/m2
Dimming Range 200:1
Vertical Rate 60 Hz
Volume control
Power ON <63W
Weight Net 18 lbs
Humidity:
Humidity: 5% ~ 95%
Touch screen
