Mplayer GUI???
  • Mx. Alba
  • Laatst online: 23:08
Mx. Alba
hen/hun/die/diens
Ik heb net Mplayer genstalleerd:
deb http://marillat.free.fr/ unstable main
daarvandaan dus...
Maar het lijkt geen GUI te hebben? Alleen maar command line voor zover ik kan zien. Hoe krijg ik er een GUI bij?
  • odysseus
  • Laatst online: 04-09 07:47
odysseus
Debian GNU/Linux Sid
mplayer -gui [bestand]
Staat overigens ook in de manpage:
-gui start MPlayer with the GUI mode. You have to compile it in, for details see
the documentation.
En ja, die debs van de marillat-server hebben de GUI erin gecompileerd, weet ik uit ervaring ;)
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • Mx. Alba
Mx. Alba
hen/hun/die/diens
MPlayer 0.11pre-cvs (C) 2000-2001 Arpad Gereoffy <arpi@esp-team.scene.hu>
invalid option: -gui
  • odysseus
odysseus
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
odysseus@odysseus:~$ mplayer -gui
MPlayer CVS-011206-16:49 gcc-2.95.4 (C) 2000-2001 Arpad Gereoffy (see /usr/share/doc/mplayer-*/)
CPU vendor name: AuthenticAMD  max cpuid level: 1
CPU: Advanced Micro Devices Athlon K75 Pluto,Orion
extended cpuid-level: 6
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0
vo: X11 running at 1152x864 with depth 16 and 16 bits/pixel (":0.0" => local display)
Reading /home/odysseus/.mplayer/codecs.conf: 15 audio & 34 video codecs
font: can't open file: /home/odysseus/.mplayer/font/font.desc
Font /usr/share/mplayer/font/font.desc loaded successfully! (495 chars)
SKIN dir 1: '/home/odysseus/.mplayer/Skin'
SKIN dir 2: '/usr/share/mplayer/Skin'
[ws] Display name: :0.0 => local display.
[ws] Screen depth: 16
[ws]  size: 1152x864
[ws]  red mask: 0xf800
[ws]  green mask: 0x7e0
[ws]  blue mask: 0x1f
[ws] XShm version is 1.1
[ws] XShape version is 1.0
[ws] Initialized converter: rgb32 to rgb16
[ws] atomname: _VIDEO_REMOTE
[ws] window is created. ( ViDEO ).
[ws] atomname: _MPLAYER_REMOTE
[ws] window is created. ( MPlayer ).
[ws] atomname: _MPLAYER_MENU_REMOTE
[ws] window is created. ( MPlayer menu ).
[menu.h] menu: 0x2c00013
[main] Depth on screen: 16
[main] parent: 0x2c0000b
[main] sub: 0x2c00004
Setting up lirc support...
mplayer_lirc: could not connect to socket
mplayer_lirc: No such file or directory
Failed opening lirc support!
You won't be able to use your remote control
Linux RTC init: open: No such device
Using usleep() timing
odysseus@odysseus:~$ apt-cache show mplayer-686 | grep Version
Version: 0.50-cvs20011206-1
Werkt hier als een zonnetje...
  • Wekkel
  • Laatst online: 28-08 15:44
Wekkel
De downloadkoning
Je moet de GUI meecompilen (zie docs). Verder ./mplayer -gui gebruiken of in je config file zetten. Dan nog een skin halen bij www.mplayerhq.nogwat en in de goede dir zetten (zie docs). Dan nog Skin=default en rammen maar.
Nogal bewerkelijk, maar mij is het uiteindelijk ook gelukt als leek.
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Op zondag 09 december 2001 22:23 schreef Reyn_Eaglestorm het volgende:
Odysseus heeft versie 0.50 uit die cvs-deb getrokken, en jij gebruikt (nog) versie 0.11.. Heb jij toevallig een keertje een MPlayer versie met de hand gecompileerd, i.p.v. met een deb ?
God, root, what is difference? | Talga Vassternich | IBM zuigt
De maker van mplayer raadt overigens TEN ZEERSTE af (om niet te zeggen dat hij het 'verbiedt') om binaries ervan op het net te zetten. Mplayer optimaliseert zichzelf zo veel mogelijk voor jouw systeem tijdens het compileren..
Je krijgt dus altijd VEEL betere resultaten met je eigen bouwsel...
  • odysseus
odysseus
Hmm, ik heb er inderdaad ooit wel eens een zelf gecompileerd, maar dat is niet degene die ik op het moment gebruik bij mijn weten (kan me vergissen natuurlijk). Bovendien geeft dselect bij mij als versie van mplayer 0.50-cvs***, dus ik vermoed toch dat ik ondertussen die van debian gebruik. Uit mijn sources.list:
Maar de kans is aanwezig dat ik eens ga spelen met deb-src's om zo mijn eigen mplayer te bouwen, dan heb ik geen problemen met dpkg maar kan ik wel zelf optimaliseren.
Yah, ./configure --enable-gui
dan een skin downloaden en die in .Mplayer/Skin/default/ zetten ofzo...ff documentation lezen...staat het allemaal in ;)
uiteindelijk opstarten met mplayer -gui ofzo...suc6
  • Wekkel
Wekkel
De downloadkoning
en in mijn geval uiteraard --disable-gcc-checking ;)
  • blouweKip
  • Laatst online: 10-08 18:05
Mplayer (de cvs versie van een paar mnd geleden) heeft nog 1 vervelende bug, hij werkt niet goed samen met sawfish (1.0.1), iemand een idee waar dat aan kan liggen (ik krijg dus geen sawfish window om mn beeld heen)
"For my friends, anything; for my enemies, the law."
