verschil tussen socket 423 en 478 ?
  • 76 views sinds 30-01-2008
  • XtremeDesign
  • Laatst online: 21-08 11:59
wat is het verschil tussen socket 423 en 478?
of wat is beter?
  • BalusC
BalusC
Carpe diem
Na jouw profiel en topichistorie te hebben gezien, heb ik helaas de neiging om te zeggen: search!!! |:(
  • kutkip
  • Laatst online: 25-03 23:04
S 478 kn je beter nemen omdat die dacht ik compatible was met de northwood p4 en die andere niet. Verder is er geen verschil alleen de S 478 is meestal ietsje duurder.
  • Brakkie
Brakkie
blaat
Answer:
Socket 478 Pentium 4 CPU is utilize the same .18 -micron technology and same processor core (Willamette) as current Socket 423 Pentium 4 CPUs. This means it has the exact same features as its predecessor, the Socket 423 Pentium 4 CPU, but with different packaging. Socket 478 Pentium 4 CPU use FC-PGA2 packaging and an IHS (Integrated Heat Spreader) on the top of the chip. It is also designed to be installed onto a smaller-sized surface-mount, 478-pin, ZIP socket, referred to as a mPGA478 socket.
Socket 423 Pentium 4 will only use the Willamette core, while Socket 478 Pentium 4 uses the Willamette core as well as the future Northwood core. Pentium 4 CPU with Willamette core utilizes .18-micron process technology and has 256KB L2 cache, while Pentium 4 CPU with Northwood core utilizes .13-micron process technology and has 512KB L2 cache. All Pentium 4 processors support 400MHz NetBurst microprocessor architecture and add 144 SSE2 new instructions for enhanced computing.
En dat heb ik zo gevonden.....
http://www.google.com/search?q=difference+between+s478+and+s423&hl=nl&btnG=Google+zoeken&lr=
Systeem | Strava
  • Exirion
  • Laatst online: 16:25
Exirion
Gadgetfetisjist
[search=423 478]
Sjee.....
