[.deb] <- die files uitpakken met Windows
  • 105 views sinds 30-01-2008
Ik heb wat .DEB files, van die binary Linux files, alleen heb ik geen Linux, hoe kan ik deze dan toch uitpakken?
Heb je daar een programmaatje voor, of weet ik wat?
Bedankt.
  • Metalium-220
  • Laatst online: 12-08-2022
Metalium-220
Forza Utreg!
http://www.pcnet.com/~proteus/TkZip/TkzWhat.html
heb je hier misschien wat aan?
/edit
support for most common archive/compression formats used by Unix and DOS/Windows systems
tar
zip (Info-ZIP, PKZIP), including self-extracting .exe files
gzipped tar (GNU tar/gzip)
compressed tar
gzip (GNU compression format)
compress
ar (you know, like static linking libraries; this is also the outer wrapper of the .deb files used by the Debian package manager - in a pinch you can explore or install a Debian package with TkZip and a little imagination)
arj (no comments, please, I still find some of these floating around)
rar (ibid.)
shorten (normally used for sound samples, like synth patch files)
bzip2 (usually superior compression to gzip, at the expense of being slower)
rpm (if you have to ask, you probably don't need to know)
...and more.
archive device support (floppy disk, tape) under Unix
support for spacey Windows 95 style filenames (i.e.,, filenames with embedded spaces) in archives created by WinZip
/edit
