Promise Lite controller modden naar Full versie
  • 176 views sinds 30-01-2008
Ik heb op o.a. de fora van amdmb.com gelezen dat de promise raid controller (lite bios) te flashen is naar de full versie. Zodat je o.a. de block size kan instellen enzo. Hierdoor zou je performance aanzienlijk omhoog gaan.
Wie kan mij hier het fijne van vertellen?
  • _JGC_
  • Laatst online: 00:06
Welk mobo heb je?
MSI K7T266 Pro2 RU
Ik heb hier ook wat gevonden, alleen mijn Duits is niet al te best
http://www.msi-computer.de/wbboard/thread.php?threadid=27&boardid=4&styleid=&page=1#7
  • roelio
roelio
fruitig, en fris.
check altavista translator voor pagina's of texten vertalen naar engels :)
Wie heeft het al geprobeerd om zijn lite bios te modden of wie wil het even proberen.
Hier de readme van die kerel die de bios gemod heeft.
First IŽve to say, that this bios is only for the MSI-K7T266Pro2, whatever
with or without raidsupport. I donŽt recommend to flash it on a MSI-K7T266Pro.
If the bios isnŽt flashed via the enclosed file "FLASH.BAT", you have to
disable bootblock programming with the commandline switch /-B at the amiflash
utility.
If you flash this bios with a functional raidarray on your promise onboard
controller, you first have to apply the drivers in the archive via the
device manager, regardless of the warnings from windows. After that reboot
your system, flash the bios and restart the system.
If someone expirience problems unter WindowsXP with "EVIAN.SYS", just delete
this file from your system. This information came from promise support. I
recommend to keep a backup of this file.
At a fresh os install this doesnŽt matter. Just copy the drivers to a floppydisk
and push <F6> during os installation and provide the drivers on the disk.
You will be able to build more than one array with this fullraid bios. You can
use the raidfunction spanning and you can define the clustersize by yourself.
ATTENTION!
If you change the current clustersize on an existing raid array, you wonŽt be
able to get access at your data.
ATTENTION!
After you flashed the BIOS set CMOS defaults via the jumper on the motherboard
described in your manual.
If after the flashing a loss of data occured or anything would be damaged donŽt
make me responsible for it.
Die Evian.sys is een file die voor probelem kan zorgen onder XP, maar mensen in AMDMB hebben er geen last van. Je moet dus eerst even de modden 3.3 bios versie flashen en vervolgens de fasttrack 100 drivers gebruiken.
Ik krijg mijn MSI pas maandag binnen ander had ik het al geprobeerd.
MSI K7T266 Pro2 RU bios 3.3 full raid bios
Promise Fasttrack 100 drivers.
Heb je al een functioneerde raid array, pas dan via apparaatbeheer de drivers aan (Promise Fasttrack 100 driver), en flash vervolgens de bios. Wie durft?
Als het goed is moet je nu de block size e.d. kunnen veranderen en nog wat andere opties die de lite bios niet heeft. Persoon op AMDMB is van 26000 naar 38000 gegaan met Sandra2001 hd benchmark en er zaten ook lui bij met een HDTach piek van 55000!
Dit is dus voor de MSI K7T266 Pro RU
Zijn we nou tweakers of niet :?
Gaat lekker hier.
Poep
  • The Dolf
Ik boot van mijn raid dus ik ga het niet proberen.
Gezocht!
Samsung 1TB HD103SI printplaat
Router
If everything seems to be going well, you have obviously overlooked something
Op zondag 09 december 2001 22:20 schreef thedolf het volgende:
Wat moet je dan op een tweakers forum. :?
Komt dat effe goed uit....Ik ga dat bordje eind deze week in mn computer zetten. :9
Op zaterdag 08 december 2001 15:43 schreef Mannekino het volgende:
Block Size? Wat is dat precies en op welke waarde kun je die het beste instellen als je twee SG Barracuda's IV a 40 GB aan je RAID (R-0) hebt hangen?? Thnx voor de uitleg!!
Op maandag 10 december 2001 15:34 schreef App het volgende:
Wat block size betekent is me nu wel duidelijk ('search'gebruikt ;) ) maar welke waarde je het beste in kunt stellen nog niet. Thnx!
Hoho, die heb ik du sniet zelf geprobeerd, dit is wat ik uit allerlei fora bijelkaar gevoegd heb.
Ik wil juist weten of het klopt wat ik zeg!!!!!
  • Hermanvh
  • Laatst online: 17-03 10:14
Hermanvh
webOS fan, hacker, developer
Hmmz Barracude IV in RAID0, ik zou het niet doen. Gebruik de Search maar eens en je zult zien waarom :(
webOS all the way!
Op maandag 10 december 2001 20:03 schreef Hermanvh het volgende:
Ja, ik weet het... :'( . Ik heb die ervaringen al gelezen, maar ik ga het toch proberen.
  • ROMiJo
  • Laatst online: 05-04 18:12
Achter deze link zit alle benodigde info om het BIOS (en de driver !! te hacken.
Ik heb zelf een MSI K7T Turbo LE en geen problemen.
http://home.online.no/~devisor/
Weet iemand toevallig of er fullraid drivers zijn voor de promise fasttrak133 raid.
Ik heb de drivers die bij MSI KT3 ultra2-R zitten. Heb hackbios gevonden op site en nu wil ik de drivers erbij hebben kan niets op promise site vinden mbt fasttrak133
  • KBDE
  • Laatst online: 18-08 21:50
Ok dan,
Je gebruikt dus eigenlijk de drivers van een fasttrack 2000TX voor promise ultra133!
  • KBDE
jip want een fasttrak133 raid = 2000TX ;)
  • Steve
  • Laatst online: 02-09 23:18
Steve
Krokodil \o/
Kickje :)
Sta op het punt dit te doen op m'n P4T533. Eén probleem: op dit moment zijn er al twee schijven in een RAID-0 array. Wordt de array vernietigd als ik een gehackt BIOS flash, of als ik (bv.) de block size verander?
Ik wil het ook graag doen met mijn P4T533! Is het nog gelukt?!
  • Bor
  • Laatst online: 23:37
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Dit is al erg oud nieuws. Voor veel moederborden zijn hier hacks voor (die raar genoeg allemaal uit DE komen). Ik heb uit een betrouwbare bron vernomen dat de performance increase erg tegen valt en dat er veel "gepatser" in de betreffende thread staat (performance increase die men in de praktijk niet haalt). Ik heb ook al gehoord van mensen die hun promise onklaar hebben gemaakt hiermee.
Opgepast dus!
[ Voor 16% gewijzigd door Bor op 11-01-2004 11:12 ]
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
Ja, maar mij gaat het niet om de performance increase, maar ik wil een 2e array kunnen aanmaken. Iets dat nou niet gaat met de "Lite" versie.
Nu heb ik:
2* Maxtor 40 gb in Array1 - raid 0
1* IBM 40 gb
1* IBM 40 gb
Nou wil ik dus die 2 IBM's ook kunnen samenvoegen in 1 array, maar dat werkt dus niet omdat het maar een lite versie is....
  • Bor
Bor
Volgens mij gaat dat ook niet werken als je hem mod.
  • Steve
Steve
Krokodil \o/
Even melden dat het destijds probleemsloos ging op m'n P4T533 - ik kon een stuk meer arrays aanmaken en andere drives aansluiten Intussen heb ik wel al een ander mobo met een lekkere TX2000 erbij :)
Jah het is hier ook goed gelukt!!!
Alleen valt de performance vies tegen als je de USB 2.0 controller en PCI slot 2 in gebruik hebt (door de gesharede IRQ's) !!!
Nu ik die devices heb uitgeschakeld loopt mijn 4 disk array als een trein :) _/-\o_
