Hallo allemaal , ik effe een beetje tft schermpjes aan het zoeken en nu kwam ik een erg mooi schermpje tegen
Namelijk deze :
Specs
Prophetview 720
Download QuickSpecs Prophetview 720 (PDF / 411Kb)
LCD Module With Last TFT-3G Technologies Size (Viewable Diagonal)
15 (38.1 cm) 305 x 230 mm (Larger than A4 page) Similar to 17 Tube monitor.
Display Type Active Matrix Color TFT LCD screen
Recommended Resolution 1024 x 768 (Perfect for windows applications)
Pixel Pitch (H x V) 0.29 x 0.29 mm
Display Color True colors
Brightness (Typical) 230 Cd/m² (Very high Brightness)
Contrast ratio (Typical) 300 : 1 (Very high Contrast)
Response time (Tr/Tf) < 30 ms (Last generation high speed)
Viewing Angle( H/V) +130 Degrees (Ideal for Group Presentation)
Cabinet with High comfort Color Blue Metal (Fashionable Design)
Control Management Digital Titanium buttons
On screen Display adjustment (Automatic options)
Auto
Adjustment
Screen Image
720 x 400 (DOS) 70Hz
640 x 480 60Hz, 72Hz, 75Hz, 85Hz
800 x 600 60Hz, 72Hz, 75Hz, 85Hz
1024 x 768 60Hz, 70Hz, 75Hz, 85Hz
Input Signal High level of compatibility Compatible with any VGA graphics board
Signal Level RGB Analog 0.7 Vpp / 75 ohm
Synchronization H/V Separate (TTL)
VGA Cable Un-detachable mini Sub-D 1.8m cable PC99 color
PC Compatible with VGA PC Cards.
MAC Mac Compatible (Need plug adaptor not included)
Frequency Horizontal Scan 30-75 KHz
Vertical Scan 50-75 Hz
Communication Plug & Play DDC1/2B (Windows 95/98/NT/2000)
Stand Design Boomerang (Fashion look)
Color Titanium (Fashion color)
Stand Backward Tilt 20 Degrees (large tilt ideal for stand up use)
Stand Forward Tilt -5 Degrees
Power Power Input AC 90-264 V, 50/60Hz auto-adjusting Worldwide
Power adapter DC +12V, 2.0A
Power Consumption 24 Watts (Very Low power consumption)
Power Management Standby mode : Less than 4 W
Many Safeties & Regulations Safety : IEC950, UL1950, CSA, TUV-GS
CE-LVD (Low Voltage Directive)
EMC : FCC Class B, CE
Strong Environmental Conditions Operating Temperature 0 to 40 degree C
Operating Humidity 30 to 85 percent (non-condensing)
Storage Temperature -20 to 60 degree C
Storage Humidity 10 to 90 percent
Dimension Set (WxHxD) (panel) 378 x 285 x 20 mm
Weight Net 3.5 Kg (Set), 4.5 Kg (Box)
Heeft iemand ervaring met dit scherm??? heb verder nog nooit iets over Hercules beeldschermen gehoord op dit forum en ik denk dus dat dit een van hun eerste stappies op dit gebied is....
Namelijk deze :
Specs
Prophetview 720
Auto
Adjustment
Screen Image
