[RTCW] hangt bij opstarten
  • 112 views sinds 30-01-2008
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
F:\PROGRA~1\RETURN~1\main\sp_pak2.pk3 (232 files)
F:\PROGRA~1\RETURN~1\main\sp_pak1.pk3 (1342 files)
F:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files)
F:\PROGRA~1\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'F:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Ik krijg bovenstaande foutmelding.
  • wacko
  • Laatst online: 19-07 12:12
Wat hardware en drivers info zou ook wel handig zijn.
mmkay... G400 dubbelhoofd 32Mb met V5.1.2001.0 van de G400-drivers
Als je nou eens verteld of je videokaart wel OpenGl ondersteunt op Direct3D ofzo.......(of gewoon welke videokaart je hebt)
(WARNING: missing Glide installation, assuming no 3Dfx available... Hier gaat het fout, geen 3dfx?????)
Te laat :)
Misschien moet je even de nieuwe detonators drivers downloaden:
http://www.the-ctrl-alt-del.com/
Moest ik namelijk wel doen
  • Paladin
  • Laatst online: 07-09 23:28
Paladin
Play Ball!
Hmz welke video modus gebruik je opengl direct 3d of 3dfx glide?
want overflowed deed me eerst aan ati denken maar je hebt een matrox dus dat zou het niet mogen zijn.
maare geef ff wat info over je cs settings
|Yesterday is History, Today is a gift, Tomorrow a Mystery | M3 - LRAWD - Referral-link:https://ts.la/p66085
G400DH dus...
mijn cs-settings? wat zijn dat?
clean install van xp & een nieuwe installatie van RTCW, zou toch eigenlijk gewoon goed moeten gaan?
onder win98se geprobeerd, daar loopt ie wel
zoals ik al zei probeer deze detonater driver eens:
Met clean install van XP zijn er geloof ik geen ondersteuning OpenGL
dat deel van "mijn" internet ligt plat... maar detonator drivers zijn toch alleen voor nvidia?
  • -=Indigo=-
  • Laatst online: 09-09 23:23
Yep, die detonaters werken alleen voor NVidea kaarten, dus die zou ik maar niet proberen.
Maar die foutmelding komt er dus op neer dat je geen goede openGL drivers hebt. Meestal wordt dat verholpen door de nieuwste drivers voor je videokaart te instaleren. Je moet btw ook DirectX geinstaleerd hebben, maar als het goed is gebeurd dat automatisch al.
  • komaki
  • Laatst online: 26-03 11:42
komaki
The Hot Zone
je hoeft niet perse Directx opnieuw te installen maar zeker wel de nieuwste drivers van je videokaart.
gewoon ff bij de fabrikant gaan kijken dat werkt meestal het beste. :)
Het is net een flipperkast als ik mijn hoofd schud met die 2 hersencellen!!!!!
  • FragNeck
  • Laatst online: 25-08 10:04
Met een wat oudere videokaart kun je problemen met de Q3 engine krijgen.
Doe het volgende :
- Zet de resolutie van je monitor op 800x600 / 16bits
- Start RTCW
en werken! ;)
http://eu.battle.net/d3/en/profile/Paus-2178/hero/2313958
  • bassio
  • Laatst online: 00:41
Als je vastlopers hebt in het spel is een goede optie om via b.v. nvmax de AGP te disabelen. Wellicht werkt dit voor jouw probleem ook.
Verder had een vriend van mij dit probleem ook en daar hielp niets anders dan de HD te formateren en alles er weer op te zetten. Liep daarna direct als een trein.
Je gebruikt "V5.1.2001.0" drivers? Ik zou proberen te upgraden naar de 6.71 Powerdesk
Ik gebruik deze drivers op m'n G400-Max en dat werkt perfect (800x600x32bits).
Ook een ding wat je in de gaten moet houden: Je tweede monitor uitschakelen in de powerdesk. Omdat je met OpenGL bezig bent, kun je niet je 2de monitor aan laten. Dus uitschakelen die hops.
Als je problemen hebt met het installeren van je drivers: Eerst je oude drivers de-installeren, dan pas de nieuwe installeren (na een reboot). Of anders gebruik je de Matrox PowerDesk Uninstaller
Als je problemen hebt, email me maar :)
Jord.
Ik had hetzelfde probleem, je moet gewoon een nieuwe driver downloaden, en dan moet ie het wel doen. Je moet gewoon een nieuwe detonator downloaden bij www.nvidia.com :9
  • Famoso
Famoso
Delay no more.
Op vrijdag 07 december 2001 09:55 schreef giovanni het volgende:
Gaat niet echt werken met een Matrox denk ik he :)
Half twaalf in een oud café. Twee mannen ruiken naar pis, dertien naar hachee. Dat haalt de pis dus nooit meer in.
