3 minuten geleden is Opera voor Linux 6.0 TP2 gereleased
Veranderingen sinds 6.0 TP1:
Ik ben hem nu aan het downloaden- Install.sh now supports interactive mode as default.
It will test your write access level and suggest proper prefixes.
- Debian dependencies should work for all Linux 2.2 debians (Potato R1-R4,
Woody, Sid)
- No startup dialog box (since some of you did not like it)
- New layout on the address bar
- Ctrl+Alt+Scrollwheel is mapped to PageUp/PageDown
- Some cosmetic fixes on the address bar when loading a file
- Shift-Ctrl-Tab should now open the window selector popup window
- DnD drop is now rejected if a folder is dropped on itself in
the hotlist
- File transfer works properly.
- Save With Images As fixed (blocked opera and filled the disk in TP1)
- Problem with large images not shown (cache management) fixed
- Better generic font family detection. Fixes crash on some systems
(especially AA fonts), and might look better too.
- Fix for overlapping lines when selecting text. This was a problem
especially when using truetype fonts
- Fixed iframe positioning when going back/forward in history to a
page containing iframes
- Fixed network communication problem that prevented some sites from
loading, especially sites using certificates and FTP sites.
- Major speedup in network communication
Linkje is misschien wel handig: http://www.opera.com/download/get.cgi?custom=yes&opsys=4&language=5
À vaincre sans péril, on triomphe sans gloire - Pierre Corneille
