het topic zegt genoeg, deze vrij stille koeler heb ik gezien op de internet site van global win en bij oc-shop maar koelt die wel goed genoeg???? heeft iemand ervaring met deze koeler?
Oc-Shop:
Global Win WBK68
Global Wins silent version of the WBK38. Extreme low noise with a good performance. It is possible to mount a 80mm fan on this heatsink, without any tools. This way you can upgrade you heatsink if you want extreme performance. We have made sure you get some discount on the fans!!.
Global Win Site:
WBK68
Specifications
Fan
Operation Voltage
DC 10.8V ~ 13.2V
Rated Voltage
DC 12V
Rated Current
DC 0.24A MAX.
Input Power
2.88WATT MAX.
Bearing System
One Ball One Sleeve Bearing
Fan Speed
5000 RPM+/- 15%
Air Delivery
23.7 CFM +/- 15 %
Noise Level
36.5 dB(A)
MTBF(life)
30000 hours
Thermal Resistance
0.628¢J/W
Fan Safety
UL Approved:CLASS A
Fan with RPM signal output
Yes
HEAT SINK
Dimension
75mm x 63.5mm x 39.4mm
Material
Anodized Aluminum Alloy 6063
CLIP
Material
Steel SK7 ( Quality Metal Clip )
Thermal Interface
High thermal conductive interface
Material
GW101
Thermal Conductivity
0.0015K factor, cal/cm2/¢J/sec/cm
Connector
Molex 2510 / 2695 3 pin
Total Weight
240g
Packaging 36pcs/box
ik wil namelijk af van mijn KLOTE thermaltake die maakt super veel lawaai!!! wie heeft deze koeler op zn athlon of kent hem, of een review ofzo hoe goed die koelt??? thnx
Oc-Shop:
Global Win WBK68
Global Win Site:
WBK68
Specifications
Fan
Operation Voltage
DC 10.8V ~ 13.2V
Rated Voltage
DC 12V
Rated Current
DC 0.24A MAX.
Input Power
2.88WATT MAX.
Bearing System
Fan Speed
5000 RPM+/- 15%
Air Delivery
23.7 CFM +/- 15 %
Noise Level
36.5 dB(A)
MTBF(life)
30000 hours
Thermal Resistance
0.628¢J/W
Fan Safety
UL Approved:CLASS A
Yes
HEAT SINK
Dimension
Material
CLIP
Material
Thermal Interface
Material
GW101
Connector
Total Weight
240g
Packaging 36pcs/box
