29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
Validator message export for "[Untitled]":
Generated by CSE HTML Validator Professional v5.00 (http://www.htmlvalidator.com/)
1. Warning: Possibly misspelled words (35, 9 unique): vraag (1x), BOOG (2x), ONDER (2x), RECHTS (2x), BOVEN (3x), ONDERWERP (3x), TUSSEN (3x), EINDE (9x), PLAATJE (10x). Complete list.
2. Message: [72] [73] To disable the section 508 accessibility messages, disable flag 72. To disable this message, disable flag 73.
3. Error in line 4 at character 6: [16] HTML 4.01 requires the "type" attribute to specify the scripting language for the "script" element. For example, use type="text/javascript" for JavaScript. Note that some browsers may work without this attribute but it is highly recommended that it be used.
4. Message in line 11 at character 9: [1] The "leftmargin" and "topmargin" attributes for "BODY" are not HTML 4.01 attributes and are currently only supported by Internet Explorer 3.0+. For instance, Netscape 4.5 does not support these attributes.
5. Message in line 11 at character 12: [2] The "marginheight" and "marginwidth" attributes for "BODY" are not HTML 4.01 attributes and are currently only supported by Netscape 4.0+. For instance, Netscape 3.0 and Internet Explorer 4.0 do not support these attributes.
6. Message in line 14 at character 6: [9] The "CENTER" element is deprecated in HTML 4.01 in favor of using style sheets or "align=center", which works with many elements. The "CENTER" element may become obsolete in the future.
7. Warning in line 15 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
8. Message in line 15 at character 5: [69] If this is a data table then row and column headers must be used. See section 1194.22 (g).
9. Message in line 15 at character 5: [46] Consider using a "summary" attribute with this "TABLE" tag to provide a summary of the table's purpose and structure for user agents rendering to non-visual media such as speech and Braille. However, this element is not widely supported.
10. Message in line 15 at character 5: [71] If this is a data table then markup must be used to associate data cells and header cells that have two or more logical levels of row or column headers. For example, use "thead", "tfoot", and "tbody" to group rows and "col" and "colgroup" to group columns. See section 1194.22 (h).
11. Message in line 15 at character 5: [5] The "TABLE" element is an HTML 4.01 element but may not be supported by older or nongraphical browsers. Furthermore, nongraphical browsers that do support tables may not support them the way that you expect. However, most browsers used today should support this element.
12. Warning in line 17 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
13. Error in line 17 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
14. Warning in line 17 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
15. Message in line 17 at character 7: [9] The "bgcolor", "height", "nowrap", and "width" attributes for the "TD" and "th" elements are deprecated in HTML 4.01 in favor of using style sheets.
16. Message in line 17 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
17. Message in line 18 at character 5: [44] Consider using a "caption" element to describe the nature of this table. Use this element immediately after the "table" start tag.
18. Warning in line 21 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
19. Message in line 21 at character 5: [71] If this is a data table then markup must be used to associate data cells and header cells that have two or more logical levels of row or column headers. For example, use "thead", "tfoot", and "tbody" to group rows and "col" and "colgroup" to group columns. See section 1194.22 (h).
20. Message in line 21 at character 5: [69] If this is a data table then row and column headers must be used. See section 1194.22 (g).
21. Message in line 21 at character 5: [46] Consider using a "summary" attribute with this "TABLE" tag to provide a summary of the table's purpose and structure for user agents rendering to non-visual media such as speech and Braille. However, this element is not widely supported.
22. Warning in line 23 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
23. Error in line 23 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
24. Warning in line 23 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
25. Message in line 23 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
26. Error in line 24 at character 1: The "width" attribute has an invalid attribute value "*". Try using one of the following values: a percent, a positive integer, or "0" (zero).
27. Warning in line 24 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
28. Error in line 24 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
29. Warning in line 24 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
30. Message in line 24 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
31. Warning in line 25 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
32. Error in line 25 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
33. Warning in line 25 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
34. Message in line 25 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
35. Message in line 26 at character 5: [44] Consider using a "caption" element to describe the nature of this table. Use this element immediately after the "table" start tag.
36. Warning in line 27 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
37. Message in line 27 at character 5: [71] If this is a data table then markup must be used to associate data cells and header cells that have two or more logical levels of row or column headers. For example, use "thead", "tfoot", and "tbody" to group rows and "col" and "colgroup" to group columns. See section 1194.22 (h).
38. Message in line 27 at character 5: [69] If this is a data table then row and column headers must be used. See section 1194.22 (g).
39. Message in line 27 at character 5: [46] Consider using a "summary" attribute with this "TABLE" tag to provide a summary of the table's purpose and structure for user agents rendering to non-visual media such as speech and Braille. However, this element is not widely supported.
40. Warning in line 29 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
41. Error in line 29 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
42. Warning in line 29 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
43. Message in line 29 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
44. Message in line 30 at character 5: [44] Consider using a "caption" element to describe the nature of this table. Use this element immediately after the "table" start tag.
45. Warning in line 33 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
46. Message in line 33 at character 5: [69] If this is a data table then row and column headers must be used. See section 1194.22 (g).
47. Message in line 33 at character 5: [71] If this is a data table then markup must be used to associate data cells and header cells that have two or more logical levels of row or column headers. For example, use "thead", "tfoot", and "tbody" to group rows and "col" and "colgroup" to group columns. See section 1194.22 (h).
48. Message in line 33 at character 5: [46] Consider using a "summary" attribute with this "TABLE" tag to provide a summary of the table's purpose and structure for user agents rendering to non-visual media such as speech and Braille. However, this element is not widely supported.
49. Warning in line 35 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
50. Error in line 35 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
51. Warning in line 35 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
52. Message in line 35 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
53. Error in line 36 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
54. Warning in line 36 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
55. Message in line 36 at character 10: [5] The "background" attribute for the "TD" and "th" elements is not an HTML 4.01 attribute. However, it works with Internet Explorer 3.0+ and Netscape 4.0+, but may not be supported by other browsers. For instance, Netscape 3.0 does not support this attribute.
56. Message in line 36 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
57. Error in line 37 at character 1: The "width" attribute has an invalid attribute value "*". Try using one of the following values: a percent, a positive integer, or "0" (zero).
58. Warning in line 37 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
59. Error in line 38 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
60. Warning in line 38 at character 3: [13] HTML 4.01 requires that the "alt" attribute be used with the "IMG" element. "alt" lets authors specify alternate text to serve as content when the image cannot be displayed. Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
61. Message in line 38 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
62. Warning in line 39 at character -1: Spaces found before the character '>'. Text should immediately end with the character '>'. Note that these spaces are valid according to the official specification but not as CSE HTML Validator is currently configured (see comment).
63. Error in line 39 at character 3: [66] The "IMG" element requires the "alt" and/or "longdesc" attribute(s) to specify a text equivalent. See section 1194.22 (a).
64. Error in line 39: Terminating validation due to too many warnings! Please correct the previous warnings and revalidate the document.
65. Message in line 39 at character 3: [7] You should use the "alt", "height", and "width" attributes with the "IMG" element. Using these attributes is considered to be good style. Using the "height" and "width" attributes may also cause pages to render faster and more smoothly (without "jumping"). Use alt="" when alternate text is not appropriate, such as when images are intended to format a page.
66. Comment: You are using an unregistered, evaluation version of CSE HTML Validator Professional and have validated 2 documents. You may validate up to 98 more documents.
67. Comment: You can allow spaces before a '>' character in tags. This option is in CSE HTML Validator's Validator Options. However, it is recommended that you eliminate these spaces for good style and to avoid possible problems.
68. Comment: You can change the maximum number of warning messages to display before the validation is terminated. This option is in CSE HTML Validator's Validator Options.
69. Comment: [8] <meta name="description" content="(actual description)"> should be used in the "head" section to provide a brief description of what is contained on this page. This information is used by many search engines when indexing a site. If you are using HTML Validator's integrated editor, you can add this from the Tags menu and/or from the Tag Inserter.
70. Comment: [8] <meta name="keywords" content="(actual keyword list)"> should be used in the "head" section to provide a list of keywords that are relevent to this page. This information is used by many search engines when indexing a site. If you are using HTML Validator's integrated editor, you can add this from the Tags menu and/or from the Tag Inserter.
71. Comment: [15] An ICRA label (a rating "meta" tag) was not found in the "head" section of this document. Browsers that are enabled with this rating system may not display documents that have not been labelled. If you have labelled this document by rating the section (directory) in which it is found, or if your site is a personal web space on a large Internet Service Provider, it is still recommended that you include the rating "meta" tag on all of your pages for performance reasons. For more information, please visit http://www.icra.org/.
72. Comment: [26] Although not normally necessary, you may want to include a "meta" tag similar to the following in the "head" section of your document: <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
73. Comment: [10] CSE HTML Validator Professional allows you to disable certain messages (like this example message). For instance, the [10] indicates that you can disable this comment by disabling validator flag 10. If you are using HTML Validator's integrated editor, you can simply use your mouse on this message to open the context menu (usually done by right clicking the mouse on this message) and select 'Disable Flag 10' to disable this message. For more information about disabling messages, please look at the Configuration section in the documentation.
74. Comment: [57] 6768 bytes; 4.7s@14.4Kbps, 2.4s@28.8, 1.4s@50, 1.1s@64, 0.5s@128, 0.2s@384, 0.1s@512, 0.1s@768, 0.0s@1.5Mbps, 0.0s@10Mbps.
75. Comment: [14] 0.21s, 13 errors, 21 warnings, 31 messages, 10 validator comments, 97 lines, 36 tags (19 closed), 19 document comments, 0 entities, 77 programs run.
