[Alg.] Wise Install opties/commando's
  • 125 views sinds 30-01-2008
  • 0 Henk 'm!
Anoniem: 35883
Instalshield heeft het handige -r commando als je een niet standaard silent install wilt uitvoeren. Bestaat er ook zoiets voor de Wiseinstaller? en zo ja hoe luid het commando dan?
de website van wise is meer gericht op de software om zelf installatie's te maken dan de installatie commando's/opties...
bvd.
  • 0 Henk 'm!
Anoniem: 3148
Gevonden in de help file ;)
Command Line Options
The executable program that interprets packages and installs products is Msiexec.exe. Note that Msiexec also sets an error level on return that corresponds to the Win32 error codes. The following table describes the command-line options for this program.
Option Parameters Meaning
/I Package|ProductCode Installs or configures a product.
/f [p|o|e|d|c|a|u|m|s|v] Package|ProductCode Repairs a product. This option ignores any property values entered on the command line. The default argument list for this option is 'pecms'. This option shares the same argument list as the REINSTALLMODE property.
p - Reinstall only if file is missing
o - Reinstall if file is missing or if an older version is installed.
e - Reinstall if file is missing or an equal or older version is installed.
d - Reinstall if file is missing or a different version is installed.
c - Reinstall if file is missing or the stored checksum doesn't match the calculated value. Only repairs files that have msidbFileAttributesChecksum in the Attributes column of the File table.
a - Force all files to be reinstalled.
u - Rewrite all required user specific registry entries.
m - Rewrite all required machine specific registry entries.
s - Overwrite all existing shortcuts.
v - Run from source and re-cache the local package.
/a Package Administrative installation option. Installs a product on the network.
/x Package|ProductCode Uninstalls a product.
/j [u|m]Package
or
[u|m]Package /t Transform List
or
[u|m]Package /g LanguageID
Advertises a product. This option ignores any property values entered on the command line.
u - Advertise to the current user.
m - Advertise to all users of machine.
g - Language ID
t - Applies transform to advertised package.
/L [i|w|e|a|r|u|c|m|o|p|v|+|!]Logfile Specifies path to log file and the flags indicate which information to log.
i - Status messages
w - Non-fatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
+ - Append to existing file
! - Flush each line to the log
"*" - Wildcard, log all information except for the v option. To include the v option, specify "/l*v".
/m filename Generates an SMS status .mif file. Must be used with either the install (-i), remove (-x), administrative installation (-a), or reinstall (-f) options. The ISMIF32.DLL is installed as part of SMS and must be on the path.
The fields of the status mif file are filled with the following information:
Manufacturer - Author
Product - Revision Number
Version - Subject
Locale - Template
Serial Number - not set
Installation - set by ISMIF32.DLL to "DateTime"
InstallStatus - "Success" or "Failed"
Description - Error messages in the following order: 1) Error messages generated by installer. 2) Resource from msi.dll if install could not commence or user exit. 3) System error message file. 4) Formatted message: "Installer error %i", where %i is error returned from msi.dll
/p PatchPackage Applies a patch. To apply a patch to an installed administrative image you must combine options as follows:
/p <PatchPackage> /a <Package>
/q n|b|r|f Sets user interface level.
q , qn - No UI
qb - Basic UI
qr - Reduced UI with a modal dialog box displayed at the end of the installation.
qf - Full UI with a modal dialog box displayed at the end.
qn+ - No UI except for a modal dialog box displayed at the end.
qb+ - Basic UI with a modal dialog box displayed at the end. The modal box is not displayed if the user cancels the installation.
qb- - Basic UI with no modal dialog boxes. Please note that /qb+- is not a supported UI level.
/? or /h Displays copyright information for the Windows Installer.
/y module Calls the system API DllRegisterServer to self-register modules passed in on the command line. For example, msiexec /y my_file.dll.
This option is only used for registry information that can't be added using the registry tables of the .msi file.
/z module Calls the system API DllUnRegisterServer to unregister modules passed in on the command line. For example, msiexec /z my_file.dll.
This option is only used for registry information that can't be removed using the registry tables of the .msi file.
The options /i, /x, /f[p|o|e|d|c|a|u|m|s|v], /j[u|m], /a, /p, /y and /z should not be used together. The one exception to this rule is that patching an administrative installation requires using both /p and /a. The options /t and /g should only be used with /j. The options /l and /q can be used with /i, /x, /f[p|o|e|d|c|a|u|m|s|v], /j[u|m], /a, and /p.
To install a product from A:\Example.msi, install the product as follows:
msiexec /i A:\Example.msi
Only public properties can be modified using the command line. All property names on the command line are interpreted as uppercase but the value retains case sensitivity. If you enter MyProperty at a command line, the installer overrides the value of MYPROPERTY and not the value of MyProperty in the Property table. See About Properties. To install a product with PROPERTY set to VALUE use the following syntax on the command line. You can put the property anywhere except between an option and its argument.
Correct syntax:
msiexec /i A:\Example.msi PROPERTY=VALUE
Incorrect syntax:
msiexec /i PROPERTY=VALUE A:\Example.msi
Property values that are literal strings must be enclosed in quotation marks. Include any white spaces in the string between these marks.
msiexec /i A:\Example.msi PROPERTY="Embedded White Space"
To clear a public property using the command line, set its value to an empty string.
msiexec /i A:\Example.msi PROPERTY=""
For sections of text set apart by literal quotation marks, enclose the section with a second pair of quotation marks.
msiexec /i A:\Example.msi PROPERTY="Embedded ""Quotes"" White Space"
The following is an example of a complicated command line.
msiexec /i testdb.msi INSTALLLEVEL=3 /l* msi.log COMPANYNAME="Acme ""Widgets"" and ""Gizmos."""
The following example illustrates advertisement options. Note that switches are not case-sensitive.
msiexec /JM msisample.msi /T transform.mst /G langid /LIME logfile.txt
