Het spontaan vastlopen van je systeem
Ik heb het volgende systeem:
K7S5A
SiS® 735 Chipset
Socket A for AMD® Athlon/Duron (K7) processors
Two 184-pin DDR DIMMs and two 168-pin DIMMs with DDR SDRAM or SDRAM
support, up to 1GB(DDR or SDRAM)
LAN: MAC integrated in SiS® 735 & PHY on board
AC97 Audio Codec on board
K7S5A has a Socket-A processor socket for an AMD® K7 type processors. You can install any one of these processors on the mainboard. The mainboard supports front-side bus speeds of 200/266MHz. This mainboard uses the SiS® 735 chipset which supports a 4X AGP slot for highly graphics display, DDR interface and Ultra DMA 33/66/100 function, provides outstanding high system performance under all types of system operations. The mainboard has a built-in AC97 Codec, provides an AMR (Audio Modem Riser) slot to support Audio and Modem application, and has an built-in 10BaseT/100BaseTX Network Interface (optional).
PROCESSORS
AMD® Athlon (K7) processors
Full series of Athlon/Duron CPU including the future Athlon processors
CHIPSET
SiS® 735 System Chipset
Super I/O and LPC - ITE8705F
System Hardware Monitor: Built-in ITE8705
LAN: MAC integrated in SiS735 & PHY on baord
AC97 Audio Codec
MEMORY
2 DDR DIMM sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin DDR SDRAM (DDR200, DDR266) or
Two 168-pin 3.3V SDRAM (PC100, PC133)
Maximum: 1.0GB (DDR or SDRAM)
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Full Support for ACPI revision 1.0 specification
I/O INTERFACE
Supports Plug and Play function
PS/2 keyboard and PS/2 mouse connectors
Dual USB Ports and LAN connectors
One - EPP/ECP mode parallel port
Two - 16550 high-speed serial I/O ports
Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port)
Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 33/66/100)
Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
ATX Power Supply Connector
ports, Headers and Others:
IrDA Cable header
Extra USB header
Two CD-In headers
Front Panel MIC/Line-out header
Green, HDD, Power indicator LED headers
CPU and Case Fan headers
Modem Ring Wake Up Header
RTC & BATTERY
SiS® 735 included 256 bytes of CMOS SRAM
With CMOS SRAM hardware clear jumper
EXPANSION SLOTS
5 PCI slots, 1 4X AGP slot, 1 AMR slot
FORM FACTOR
ATX (304mm*244mm), 4 Layers
Er zit een amd adlon 1600+ XP proccesor in.
Het maakt niet uit wat ik doe met mijn pc, of ik nou een game aan het spelen ben of als ik nou niks doe. Mijn systeem loopt spontaan vast en doet helemaan niets meer. alt ctrl del werkt niet en het numlock lampje blijft branden.
Heb zelf al geheugen, hardeschijven en flat kabels gecontroleerd.
Wie weet hier meer over of heeft dit ook zelf meegemaakt???
  • Tomaat
  • Laatst online: 13-05 13:50
Wordt ie niet gewoon te heet? Dat had ik eerst namelijk ook, paar dikke fanZ erin gemonteerd, en het probleem was opgelost! :D
  • OxiMoron
  • Laatst online: 23-10 17:33
Heatsink: Plastic of metaal? >:)
Albert Einstein: A question that sometime drives me hazy: Am I or are the others crazy?
Op maandag 03 december 2001 16:41 schreef da_man98 het volgende:
Nee dat help niet hij wordt zo'n 40 tot 50 graden
  • mkleinman
  • Laatst online: 30-10 11:29
mkleinman
8kWp, WPB, ELGA 6
Wat voor vgakaart met wat voor drivers?
ik had hetzelfde probleem wat uiteindelijk lag aan de detonator drivers.. ik draai nu met zeer oude detonator drivers en nu is mijn systeem weer stabiel.
Duurzame nerd. Veel comfort en weinig verbruiken. Zuinig aan doen voor de toekomst.
